Question about Philips 19PR19 19" TV
SOURSE PROBLEMS - Philips 19PR19 19" TV
    Top Expert:
  • Philips Master
  • 75,311 Answers
What do you mean by this "Source problem"?
Give us details.
Posted on Oct 15, 2010
How can Toyota code p1600 be fixed
hi i wish i knew if the car had more codes or if it runs good with this code you should be having some other problems because this the main battery supply to the ecm and the memory retention voltage sourse for the computer that is fed by a fuse in the fuse box so i would check all of my ground wires and check to see if any wire is damage or threding
Feb 24, 2015 | 2002 Toyota RAV4
I have just bought a new Toshiba Laptop running windows 7. I have a BT router and have connected it by cable not wireless. At first it connects to the internet automatically with no problem, but...
Try to acess internet form a differnt sourse,see if problem repeats,next make sure your wireless is off if you are connected hard wire.If you connect ok from a differnt sourse no problem,your problem should be with isp provider
Jan 11, 2011 | Computers & Internet
Conecting my equalizer to amp'
What kind of EQ?
Typically you would place an EQ or any processor in a Tape Loop:
Tape Rec/Out to EQ In; EQ Out to Tape Play/In on the amp. Select Tape Monitor on the amp to place the EQ in-line with whatever source you're playing. Use it's ability to modify the sound sparingly.
Feb 23, 2010 | Audio Players & Recorders
Transmission does not come out of firstgear until i let off the excellarator at 23-25 miles an hour.whats causing this?
See if there is an adjustment on the throttle,or on the transmission,that is loose,or needs adjusting.Also,check for vacuum problems,and look for any fuses that may have blown.If you have instaled a radio,or any ***.and wired it to the wrong power sourse,this would cause the problem also.
Oct 30, 2009 | 2000 Nissan Maxima
My laptop is only 4 months old and my screen is very dark. I can hardly read the screen.
The connector that goes from the mother board or the invertor may be bad. Or the inverter board itself.
The wire is very delicate and goes from the motherboard and the invertor wire is also delicate. Repeated opens and closing of the screen can make the conections at the plug get weak and break.
Try connecting a LCD monitor alongside the laptop. Select the LCD and see if you get a video feed. If so then the wire connector and / or inverter is probably the sourse of your problems.
Sep 13, 2009 | Toshiba Computers & Internet
Why does my radio get poor reception
The radio has a built in small power sourse to increse reception. A reception booster..
That power sourse may be failing..
Very common on the stock stereos..
In my opinion - it it worth wile to have a brand name stero installed.. It is not real expensive to do..
Note;
Thank you for posting your question on FixYa.com
We are helping people on a points system.
If the information provided here was at all helpful,
please be kind - rate well and close the post.
Thank you – and enjoy your day ;o)
Aug 01, 2009 | 1995 Lincoln Continental
Blue screen, dvds wont play. cant change the sourse.
check you wire connections if not then you can get a originald remote from partstore.com good luck.
Jul 12, 2009 | Televison & Video
My computer have Asrock K7S41GX,amd athlon 1.16GH,nvidia geforce fx5200 128 agp 1,5v video card,and 2 hard disk and one dvd-rw i keep getting problems with "him",its keep getting close up,like a shut down...
You may want to set all your drives (hard drives and DVD-R) to cable select setting. Sometimes this helps because it will enable Windows to designate drive sequence for you. Just a thought.
Dec 28, 2008 | Asrock K7S41GX Motherboard
Bootup,hardwere,,or some problem....
Sudden shut downs are often heat related. Modern motherboards have a sensor under the CPU that cuts off the power when the temperature gets above a certain point (sometimes this point can be set in the BIOS). Usually the CPU fan will spin up very fast trying to cool off the processor just before it shuts down. Often you can feel the heatsink being very hot as well.
I suggest you check your vent holes for clogging (hair, dust, etc.) to make sure you are getting good airflow. Next, peek into the CPU fan to see if there is dust accumulated underneath blocking the heatsink from expelling heat (the dust layer acts like a blanket and keeps the heat in). Finally, if you are technically inclined you can try removing the heatsink/CPU fan and reapply thermal paste to the processor.
Dec 27, 2008 | Asrock K7S41GX Motherboard
Blue vertical line on the LCD/EVF/Tape
If this camera is 4-5 years old or more, you need to replace its Capacitors, may be all Elecrolytic Capacitors.
Jul 31, 2008 | Panasonic NV-MD10000 Camcorder
Philips 19PR19 19" TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
