Question about Akai PT5492S 54" Rear Projection Television
I have a 56'' AKAI PT5492 projection screen i turn it on and have green bowed lines on top of screen
  • Akai Master
  • 3,459 Answers
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
To get fixed either call in a local TV repair company or goto sites such as www.TvRepairKits.com to get a repair kit with instructions.
Posted on Oct 15, 2010
Just got this t.v from my dad. It is a pt5492 model. It has kind of dark yellow picture with alot of red. He was told it might be blue light is bad? Can I fix this myself?
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 16, 2011 | Akai PT5492S 54" Rear Projection...
Picture looks like 3d i have ajusted screen but keeps going back to 3d and picture is bowed
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Aug 25, 2010 | RCA P56923BL 56" Rear Projection...
56" sony rear projection picture problem
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 12, 2010 | Sony KP-57WS500 57" Rear Projection...
I have a HCN4727w samsung. Red/green shadowing. Bowed image
*Screen Looks 3-D
*Colors wont align
Jan 17, 2010 | Samsung HCN4226W 42" Rear Projection...
Akai tv model PT5492 has real bad orange tint that will not go away, with any adjusting.
it souds like your blue and green tube are getting weak and will need to be replaced
unfortunately they are no longer avail I would think about retireing that set
Dec 10, 2009 | Akai PT5492S 54" Rear Projection...
Rca 7302rd5 56"hdtv tv looks like a 3d moive
•Screen looks 3D
Jul 03, 2009 | RCA R52WM24 52" HDTV Projection Television
Akai model pt5598hdx/sms
it would sound like your convergence amp power board has failed at the shop we would replace then it would need a serviceman alignment
Jun 17, 2009 | Akai PT5598HD 55" Rear Projection...
I have a 53 in. sony projection tv,. bowed picture tubes?!?
Replace Both STK convergence ICs will have part number on them STK392-560 use same part number on your STKs. Also around ICs ck pico fuses 5/6amps they are green or yellow.
Jan 07, 2009 | RCA P56930BL 56" Rear Projection...
Green color convergence
make sure you hooked everything up properly and that all connections are tight
Aug 26, 2008 | JVC AV-56WP74 56" Rear Projection...
Red lines
The top of my screen is pink and the color kind of bows down. The images are kind of distorted. Thanks for any help.
Sep 28, 2006 | Akai PT5598HD 55" Rear Projection...
Akai PT5492S 54" Rear Projection Television Logo
151 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
