Question about Sony FD Trinitron KV-32HV600 32" TV
Tv pops when turned on.
My KV_32HV600 pops when turned on, Been doing that for a while but getting louder and had to turn on twice to get picture because it would shut itself off. Now it permanetly stays off after loud pop. Sometime get 4 blinks after unplug then try, then goes to seven blinks.
  • junk tv Jun 03, 2008
    I went thru with a magnifying glass and flash light and alcohol swabbed all boards that had any dirt spots after airing/vacuuming the whole tv. Then checked all connections,wired, boards fitted correctly.You are partially right, it was a dirty spot on a board I'm betting because the tv works great now.That model is so huge and heavy because it had all the bells and whistles(right before the plasma craze) that the input/output, s cable jack outlets connected to the audio board was flexing because of weight/ design integrity issues.The tv is overkill, who needs seven outlets? Kept a couple screws loose too, something fixed it, who knows, maybe I have a couple screws loose,thanks for the help
  • 4,234 Answers
This unit most likely has a number of bad connections inside. The 4 blinks indicate a problem witht he vertical circuit and the 7 are with the horizontal high voltage circuit. I'd try looking for bad solder joints and resoldering them first. Report back if that does not resolve the problem. I suspect that the set will still fail but with only 1 of the listed blink codes. If that is the case, we'll start looking for faulty parts in that circuit.
Dan
Posted on Jun 02, 2008
KV-24FS100 TV shutting off
How many times the standby light flashes in between switch ON and going OFF?
For more details about this fault, visit this site, and call older posts.
Type in this link address, [without brackets] either to Google Search Box or into the Address Bar to your browser and press Enter. It has all the details about blinking codes of Sony Sets.
electronicshelponline(.)blogspot(.)com
In name [Electro-Help]
Apr 16, 2012 | Sony FD Trinitron KV-32HV600 32" TV
32 inch sony trinitron wega
It will most probably need an overhual of the power supply
Mar 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My Sony Trinitron Kv-32hv600 32'' WONT TURN ON
The signal board is your problem. If under warranty take this to your leader!
Oct 01, 2009 | Televison & Video
TV popped and shut off red light flashes 5 times then pauses
this specific type of TVs flash their standby light if the onboard testing system sniffed out a problem
so, as if your TV is trying to tell you "i have a problem and i need to be serviced"
i hope it goes well for you
:D
Aug 30, 2009 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony KV-32HV600 won't turn on.
If the blink repeats the same number of times (up to 6 or 7) between pauses, the number of blinks is a trouble code. Determine that number (count), then search this site and the web for your TV model and that code. Also look on the rear of the set for the chassis number, and search on that keyword.
Sep 15, 2008 | Televison & Video
On/off switch for 32"
the control panel ,in the front .
Dec 28, 2007 | Toshiba 32AF43 32" TV
Television will not turn on
My Sony KV 32HV600 will not turn on, unless I take it for a car ride THen it will turn on and is fine until it shuts off again. Which circuit board should I change or send in for repairs? definately there is a loose contact as you have ezplained. please check connector or some print loose or parts loose in power supply. if it is ok then check h/output section for loose or print break. it is not a major problem &can fixed ar home. no need to change board remove board &check for print. it requires tech knowledge.
Oct 04, 2007 | Sony FD Trinitron KV-32HV600 32" TV
Sony kv-32hv600 picture problems
Problem 1. Color patches at lower corners. These are caused by magnetic sources close to the TV. Do you have any Speakers close to the sides of the TV? Are they Magnetically sheilded? No? Move them away from the TV. Problem should then resolve itself in a couple of days. Problem2. Screen Slumping. Most likely a problem with the Pin cushion correction ckts. Get a good technician to have look. cost should not be much. Under 100$ plus Technician fees.
Aug 18, 2006 | Sony FD Trinitron KV-32HV600 32" TV
Sony FD Trinitron KV-32HV600 32" TV Logo
237 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
