Question about Insignia NS-LCD19 19 in. LCD TV
I have a ns-lcd19 TV that will work for five minutes, then makes a click and loses video and audio. A small box appears on the scrren and reads, "Please wait..."The green pilot light remains on. Turn it off and light goes back to yellow. Turn it on and the pilot light changes to green again, but screen remains dark. The problem occurs regardless of what type of input I use, all do the same thing. Thanks! Frank
  • frankw308 Oct 16, 2010
    That must be for a different model. This particular set uses 8 similar capacitors, all 470 uf at 25v and (unfortunately???) none of them appear to be bad in the manner you described.
    Genius:
  • 1,622 Answers
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your TV and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Posted on Oct 15, 2010
Setup insignia NS-LCD19. I get a "signal not
Your computer video output resolution is not compatible with the TV. Try adjusting your video card output settings to 800x600 at 60 hz to begin. Once the desktop displays on your TV, you may continue to adjust the settings to meet your needs.
Oct 12, 2011 | Insignia NS-LCD19 19 in. LCD TV
I need the drivers for my Insignia 19" LCD TV 720p (model NS-LCD19-09). Can you assist?
Hi There are no specific drivers for the TV / monitor. If you are planning to use it with a PC , please check the drivers of the graphics card. (right click anywhere on the desktop , go to properties and settings there you should see the second monitor if the pc is able to connect to the TV otherwise you would need to use a standard driver
please specify what you are planning to do , for example PC make , operating system what connection etc
May 05, 2011 | Insignia NS-LCD19-09 Monitor
I need a remote code for my insignia tv model NS-CL19C Serial # DC0UEOEO300DW78X0288
Many remote control codes can be found at InsigniaProducts.com. Just search for your TV model number and click Support!
Jun 29, 2010 | Insignia NS-LCD19 19 in. LCD TV
Plugged in no power light or picture cord checks out good
replace power supply. multiple components died on power supply to many to replace and some to small for hand solder. cause cheaply made power supply
Apr 27, 2010 | Insignia NS-LCD19 19 in. LCD TV
I have an insignia NS-LCD19. I get a "signal not support" error when connecting to my P.C. Is there a fix?
Usually this is because the video card settings and the TV settings do not agree. Here is a resolution that has worked for others.
Mar 12, 2010 | Insignia NS-LCD19 19 in. LCD TV
REMOTE CODE FOR NS-LCD19 INSIGNIA
Many remote control codes can be found at InsigniaProducts.com. Search for your product model number and click on the Support tab.
Feb 02, 2010 | Insignia NS-LCD19 19 in. LCD TV
Insignia TV model NS-LCD19. TV shuts off
Unfortunately your TV will need to be serviced. You may take the unit back to the retailer of purchase to arrange for repairs.
Sep 17, 2009 | Insignia IS-LCDTV32 32 in. Television
Insignia NS-LCD19 19 in. LCD TV Logo
152 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
