Question about Mitsubishi WS-65613 65" Rear Projection HDTV
I have a Mitsubishi Medallion HDTV Integrated 1080 WS-65615 and the speakers wont work. I've tried the the whole speaker/audio stuff but it wont let me select tv speakers.... help please!
  • John Uhrlaub
    John Uhrlaub Jul 26, 2012
    my audio digital doesnt work with my hdmi input
That's what I have going on. It was connected to a surround sound, now that I moved it downstairs the regular speakers won't turn on at all. Ill get the picture and do the audio things to turn it on and still nothing when i press volume. it say tv speakers are off.
Posted on Dec 04, 2012
  • sureshdatar
    sureshdatar Dec 04, 2012
  • sureshdatar
    sureshdatar Oct 21, 2013
    There should be a net command option in the menu that you can turn off... i hope
    Genius:
  • 1,030 Answers
Hummm if i may suggest something... do you have net command enabled this would disable the speaker selection giving control of audio to other devices.
Posted on Oct 15, 2010
How do you take it off net command? My tv keeps telling me to switch to net command
Posted on Oct 21, 2013
  • sureshdatar
  • sureshdatar
    sureshdatar May 15, 2014
    It will say on and off, just turn it off then the speakers will work :)
I need to be able to connect DVD player to output 3 on Mitsubishi Medallion hdtv 1080 we can't seem to get it to work
It needs to be input if you want to display some on the TV from the DVD player. HDMI is the easiest as it's both audio and video.
Jun 01, 2015 | Mitsubishi LT55164 Unisen Medallion 55...
Mitsubishi medallion 1080 HDTV integrated model # ws-65615. No sound at all please help
Look for any jacks that you plug auxillary sound devices into and see if you have any sound from them. Check the menu for setup and make sure that nothing in the audio is set to be off or set to external. If that is all ok, look online with that model number for audio boards.
Oct 21, 2013 | Televison & Video
Mitsubishi Medallion 1080 WS-55413 - colors not aligned
There is no "reset" as the set has in the customer and tech menus ways to attempt to manually adjust this.
under convergence in the customer menu select advanced and follow the instructions on the screen.
If Red or Blue or Green are skewed and will not adjust it means one of the two STK-394-250 CONVERGENCE chips this set uses is bad.
Depending on where you buy them they will range in price from about 12 dollars each to nearly 35 dollars each.
Let me know what you find; this may or may not be a do it yourself repair as some real expertise is required to correctly get at and replace the chips.
SD TECH
May 11, 2010 | Mitsubishi WS-55413 55" Rear Projection...
How do i take the parental code off of my Mitsubishi WS-65615 65" TV?
I can help you unlock your Mitsubishi HDTV V-Chip.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Jan 07, 2010 | Mitsubishi WS-65615 65" TV
How do we turn off the internal speakers to use a surround sound system on our Mitsubishi HDtv 55" 1080 SERIES TV?
IF it is a Mitsubishi WS-55613 rear projection set---
You with the Mitsubishi remote go into the customer menu and select Audio(it should be a separate item) and look for a setting for speakers--right cursor to it and up or down cursor to change it.
Some models may have this feature in the SETUP part of the menu.
if you have questions or need help let me know--I am here to help people.
If this information helps rate this solution as I do this here for free.
SD TECH
Nov 05, 2009 | Mitsubishi WS-55613 55" Rear Projection...
My t.v. wont turn on. I have a Mitsubishi, Medallion HD 1080. Model ws-65819.
hold down the menu + device for five sec what is the error code?
should be like 1 pause then a 2 or something
Jan 12, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi 1080 HD Medallion
If the LED doesnt light. Check the fuses. the fuse many be blown. Unplug the set before you check the fuse.
Jun 14, 2008 | Mitsubishi WS-55613 55" Rear Projection...
My xbox360 Wont work on my WS-55513 MITSUBISHI COMPONENT
Try changing the settings on the Xbox under display to 1080i. If it is 1080 p, or 720p, the image will look funny so make sure it is at 1080i.
Your welcome
Your friend from down the lane!
May 21, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Medallion ws-65615
When this type of Mitsubishi flases the timer light constantly it means The DM board has some power but has not booted up. This problem is becoming more common in these sets, There are Four capacitors that fail in the DM board but if your soldering skill are weak you may want to take this somewhere to get it fixed
Feb 15, 2008 | Mitsubishi WS-65615 65" TV
Mitsubishi WS-65613 65" Rear Projection HDTV Logo
335 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
