Question about Toshiba Televison & Video
I have a Toshia TV - Model 19A24 - Made in Thailand - Dated Nov. 2004 # 7961C2877 A. With it, I have your manual control unit: CT-859. I accidentally pressed "menu" on the control unit. Now I get English subtitles with all programs on the TV. Would you explain how I can remove the "titles" option.
    Novelist:
    Champion:
  • 203 Answers
Your closed caption is turned on. Go into the menu and set captions to off or look for captions button on remote. Sometimes identified as cc. Press it until "captions off "appears on screen. That should do it. Good luck.
Posted on Jun 02, 2008
Where is the input/source button
The TV/Video button at the bottom left of the Toshiba CT-859 remote toggles between the TV and external video sources. This button is below the Reset button. The CT-859 remote works for several Toshiba TVs, including the 19A24. The manual for this TV describes the remote buttons on page 6. The manual is available online at Sears Parts Direct here: http://www.searspartsdirect.com/partsdirect/user-manuals/19A24-Toshiba-COLOR+TELEVISION-manual . The direct link to the manual is http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0407309.pdf .
I hope this helps.
Jan 04, 2016 | Toshiba CT-859 Remote Control 72795473
Toshiba Remote Control ct-859
what is the 4 digit number for universal remote for toshiba TV
Jul 03, 2012 | Toshiba Televison & Video
Won''t turn on the tv also cannot change the settings manually on the tv
Thanks for stopping by.
What is the model number and manufacturer of the TV you are trying to control with the CT-90157 remote?
Not all IR codes are programmed into all remotes.
Sep 26, 2011 | Toshiba CT-90157 Remote Control
How do I get a manual for Toshiba remote controller model CT 90302
Hello
This remote control is for use with Toshiba 22AV500U TV. It is originally coded to use with this TV, yet other TVs also can be programmed with this remote contorl. There si no specific user manual for this remote control itself. All codes and proceedings are with the user manual for the above mentioned model Toshiba Tv. If you haven't that manual, send your email address to me by Fixya. I'll send a copy of that manual to you by return mail. Or go tho this link from where you can download the above said TVs manual for as PDF format. OK
a248.e.akamai.net/pix.crutchfield.com/Manuals/052/05222AV500.PDF
Sep 01, 2011 | Toshiba Ct-90302 Remote Control
Panasonic CT-27SL15 has scan lines on top 4 inches of screen, what is problem and how to fix?
Nov 2011 - Comment
Have similar problem on a Panasonic Tau model CT-27SL15.
It's a 27" CRT TV manufactured around 2005.
Other posts / solutions on this problem say possibly a capacitor going bad in the vertical circuitry / near the vertical IC / vertical blanking circuitry. Telephone call to a TV repair person mentioned something similar - "possibly a bad capacitor in the vertical circuitry".
Found a service manual online w/schematics and board layouts.
Panasonic Service Manual
http://dl.dropbox.com/u/35219914/PANASONIC%20CT27SL15.pdf
See pg 25 (of 42) - Deflection Schematic Diagram (Main PCB)
Shows: V Output IC - IC401
Finding the actual bad component(s) may not be so easy.
Anyway ... just wanted to add this comment.
Feb 11, 2010 | Panasonic CT-27SL15 27" TV
Toshiba TV model 19A24
THAT IS AN ANALOG SET. YOU NEED THE CONVERTER BOX. FOR TRANSITION TO DIGITAL.
Jan 22, 2009 | Televison & Video
19a24
This could be anything, check fuses inside would be the only thing i could suggest
Dec 02, 2007 | Toshiba 19A24 19" TV
Toshia CT-90157 remote is not working!
Here is the product information for your remote: MODEL: CT90157 PN: 23306517 MODEL: CT-90157 PN: 23306517 23306495 this remote has the pic size button Originally supplied with models: 32A33, 32A43, 32AF43, 32AF44, 35A44, 35AF44, 36A43, 36AF43, TOSHIBA Used with models: 13A21, 13A21C, 14AF43, 19A21, 20A42, 20A43, 20A44, 20AF43, 20AS21, 24AF43, 24AX61, 27A43, 27A61, 27A62, 27AF43, 27AF44, 27AX61, 27AX61C What is the correct model# for your set?
Sep 22, 2007 | Toshiba CT-90157 Remote Control
Remote help
What is the model# for your set? Find your TV set below: MODEL: CT90157 PN: 23306517 MODEL: CT-90157 PN: 23306517 23306495 this remote has the pic size button Originally supplied with models: 32A33, 32A43, 32AF43, 32AF44, 35A44, 35AF44, 36A43, 36AF43, TOSHIBA Used with models: 13A21, 13A21C, 14AF43, 19A21, 20A42, 20A43, 20A44, 20AF43, 20AS21, 24AF43, 24AX61, 27A43, 27A61, 27A62, 27AF43, 27AF44, 27AX61, 27AX61C
Feb 27, 2007 | Toshiba CT-90157 Remote Control
Televison & Video Logo
132 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
