Question about MXL 990 Professional Microphone
I buy a mxl condenser mic,when i hook it up i hear a rumbling sound like thunder,i try different cable,and mixer and i still hear the sound.any know whats the problem?
    Genius:
  • 1,325 Answers
Perhaps there is agrounding issue or the impedance matching is not set properly for this type of condenser mic
look at these reviews
http://www.soundonsound.com/sos/aug05/articles/mxl.htm
http://homerecording.com/bbs/showthread.php?t=163441
hope this helps
Posted on Oct 15, 2010
My MXL v63m doesnt have sound coming out when plugged in to the amp
It could be any of a number of issues, but when you say "plugged into the amp", this is a condenser mic which requires power from a power supply or phantom power from a mixer. If your plugging it directly into an amplifier, it defiantly won't work.
Oct 15, 2016 | MXL Audio Players & Recorders
No sound from my mxl v67 condenser mic
These things use Phantom Power, from your mixer. If it HAS it.
If not, now you know, get an external supply ($$!).
Peace-
Jul 27, 2014 | Marshall MXL V67i Microphone
My marshall MXL V67 MIC doesn`t work
If this is a condenser micrphone it will require Phantom Power from the mixer you are trying to use it with. If Phantom Power is provided, check the cable to ensure proper wiring.
Jul 27, 2014 | MXL Audio Players & Recorders
Mxl 770 won't pick up sound
Condenser microphones require Phantom Power from and external source, such as a good mixer. Make sure your mixer has it available and it is turned on. Then make sure you have a good and properly wired mic cable. If these suggestions do not help I would contact the manufaturer or retailer where the mic was purchased. Take the mic to a music store and ask yhem to hook it up to see if it will work.
Dec 03, 2013 | MXL 770 Professional Microphone
Anybody knows mxl 990 works with behinger usb 302 mixer??
The user manual says Phantom Powered Mic input which means you should be able to use a condenser microphone requireing Phantom Power.
Mar 24, 2013 | MXL 990 Professional Microphone
No sound from mxl 990 condenser mic
From the Micropower PS400 product description it states:
"routes the microphone signal to a mixer or a microphone preamplifier."
• these is just a phantom power supply.
One reason your former setup is OK , is that
tascam m-50 is a mixer preamplifier.
• phantom power supply is just a part of the mic preamp of the mixer
to power up your mxl 990 condenser mic
• What you may need is something like these:
X2u XLR to USB Signal Adapter
Sep 29, 2012 | MXL 990 Professional Microphone
When i record thru my mxl genesis mic with the mixer i get like a loud distorton. Im using magix 14 ,and i have downloaded the audio driver off the disc that came with the mixer....Help
It is likely you do not have the levels set correctly and are over driving the mixer. Reduce the trim settings using the PFL buttons and monitor the level indicators to insure you are not clipping.
With a condenser mic you CANNOT have any speaker in the room that the mic can hear of course. These mics are so sensitive. Your mixer and monitor speakers and recording will be in a separate room from the soundproof studio typically.
To monitor the system anywhere in the same room as the mic you MUST use headphones that do NOT leak sound or you will get feedback and distortion.
Mar 14, 2011 | Behringer XENYX 2442FX Mixer
I am trying to record with my mxl 990 micrphone onto my laptop but when i try to record no sound is heard
you can't just plug and play with these high end mics. You require a +48v phantom power source from something such as a mixer. Then plug the mic into the mixer and the mixer into the LINE IN on the PC
Jan 07, 2011 | MXL 990s Professional Microphone
Can't operate my MXL 990
If it is an MXL 990 Condenser that comes in the grey case with a shockmount and a black hard mount I can solve your problem. (If it is USB I know nothing about that unit).
This MXL 990 microphone MUST have 48v phantom power in order to operate. If you aren't familiar with the term phantom power read the first link:
Phantom power - http://en.wikipedia.org/wiki/Phantom_power
MXL User Guide - http://www.mxlmics.com/support/guides.html
If yours is one of the older MXL 990's it should have an XLR connector on the bottom -
XLR Defined - http://en.wikipedia.org/wiki/XLR_connector
Your mixer (I am guessing its a Peavey, Tascam, Mackie) or something entry level like that may or may not have phantom power. I am guessing not. But if it does, it will have a switch that says 48v phantom power and most likely a green or red LED next to it to show you when its on. This mic will NOT work without phantom power.
Best suggestion: Verify that your mic is the MXL 990 Condenser, if it is it needs 48v phantom power. Check your mixer and see if it has 48v phantom power. The only computer soundcard that I know of that is used by a lot of folks is the M-Audio Delta 1010LT. It has XLR inputs but NO phantom power on it.
There's your answer.
Ray
Feb 09, 2009 | MXL 990s Professional Microphone
Pls help
The MXL 990s requires 48 volts to operate. If your mixer does not have a phantom power option, you will need to purchase a microphone pre-amplifier with phantom power to interface the microphone to your mixer.
Nov 19, 2008 | MXL 990s Professional Microphone
MXL 990 Professional Microphone Logo
673 people viewed this question
Top MXL Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
drivealot
Are you a MXL Audio Player and Recorder Expert? Answer questions, earn points and help others
