Question about Vulcan Ovens
I have a Vulcan Condor Multi-Function Oven model no. 075D11D16, which a friend gave to us. We are in the process of installing it, but would like to know how much space we need around it for good ventilation. Also, if you could let me know if there is somewhere where I can download a manual, that would be great. Many thanks in advance.
bigg t
  • 640 Answers
SOURCE: Why won't my oven ignite? Vulcan model GC04c
i can get you the error code but dont have my manual at the time.a couple things to check.do you here the clicking sound of the ignitor that ignites the gas?when you installed the regulator are you sure its on right?you should see an arrow on the regulator body and it should be pointing to the oven.also you need 10 inches of water colum (gas pressure)with a propane system where as natural you need less,regardless ill be in touch.
Posted on Jan 17, 2008
SOURCE: vulcan space heater lighting instructions
turn the round knob to left "the ignitation" spot, then push down the button to light the pilot.
Posted on Oct 28, 2008
SOURCE: lost my manual for chef condor integra oven - need
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Posted on Sep 19, 2009
  • 189 Answers
SOURCE: Hi, I only just installed Baumatic single built in
Hello- This is a brand new model, but it works the same as the rest. Heat is produced by the elements. The fan has an element that glows when heating the air. --Convection oven glass gets hotter than normal fanless models.-- This is all normal operation of the oven.  To ensure full life of oven, avoid using the 'self-clean' feature. Techs call this the 'self-destruct' cycle. Please reply to this post if info is helpful- have more if needed- Thanks- Ed
Posted on Mar 19, 2010
SOURCE: i have a defy gemini petit chef multi function
i have a defy gemini petit chef thermo fan oven.I only used it for about 20 times the warranty is over the fan works but the elements are not getting hot both the grill and bake.could you please tell me what the problem could be
Posted on Jun 21, 2010
I need instructions for chef condor convection oven-having trouble with timer
i have a chef condor wall oven and the door wont shut properly as the latches have gone loose or broken
Jun 09, 2010 | Electrolux Ovens
Locked oven door to clean. Need instructions to
These might help you get the door off
These Videos will help with your cooker problem.
If you need more video help on appliance repairs visit our Video Tutorial Library at our website
1 how to remove your oven door for cleaning or repairs and how to reseat the door when finished.
2 How to change and fit oven door hinges.
We can not allways cover Every model but hope this helps. Remember to send us an email if you can’t find the part you need.
We also supply all the Parts you need for Repairing your cooker oven Door.
Oven Door Hinge Spare Parts
Oven Door Glass panels
Cooker Door Handels ETC
Cooker Door Catches ETC
Cooker & Oven Door Seal / Gaskets
Remember to Leave feed Back and pass our site on to your Friends:
Our Shop http://www.apart4u.co.uk
Our Video Help Section http://www.apart4u.co.uk/video-tutorials.html
Mar 04, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
My vulcan burners lit but I can't get the OVEN pilot to light . What are the steps to light the oven ?
use matches,the pilot ligth is hard to replace unless in the tecnician can do,and hard to find the parts.
tnx.gerbee
Jul 04, 2009 | Vulcan GCO2D Gas Single Oven
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
1. Set time of day.
Happy cooking!
Jun 14, 2009 | Ovens
Problem again with the Vulcan GCO4C
i wasnt in on this from the begging but have you changed the safty valve on the burners and what code is er-5 havnt had no experence with vulcan but the regulater dont run the gas the safty valve does and have you checked the probe in the oven at 70 degrees it should be 1200 ohms
Jan 30, 2008 | Vulcan GCO2D Gas Single Oven
Ovens Logo
48 people viewed this question
Top Vulcan Ovens Experts
John Tripp
John Tripp
Treefrog15
Treefrog15
Are you a Vulcan Oven Expert? Answer questions, earn points and help others
