Question about GE Profile JTP56 Electric Double Oven
Just bought a house that has the JTP56 Double Wall Oven. Attempted to Self Clean, the top worked just fine, but about 40 minutes in the bottom tripped the circuit breaker. Allowed the oven to cool, reset the circuit breaker, tried one more time with no luck. After resetting the circuit breaker a day later, while the oven was off, it started warming up. Started and cancelled a self clean, still did it. Have been keeping the breaker off while not in the house working on it. Turned it on to try diagnosing it today, tried starting just a regular bake cycle. The circuit breaker tripped after a few minutes, no noticeable change in temperature, top worked just fine. Any ideas?
  • Michael Oct 15, 2010
    So it would serve to follow that the burned up wire is in the vicinity of the lower oven. Is there an "easier" way to access behind it (looked between the top and bottom ovens with no joy)? I'd rather not have to pull the entire double oven out of the wall to get at it.
  • GE Master
  • 3,247 Answers
You have to be aware that the self -clean function whilst very convenient, tends to heat up the oven tremendously. Depending on the age of the oven it can be detrimental to it.
I am assuming in your case the lower oven has suffered some damage due to the heat generated during self clean. Generally the first one to suffer is the heat sensor or the heater. If the circuit breaker is tripping then the heater may have fused or the wires feeding the lower oven are shorting due to insulation breakdown.
Not sure how much comfortable you are with electrical repairs. May have to test out a few things before deciding whether to buy the components yourself and fix or get someone to do it.
You can checkout the location and description of the parts in these diagrams. Please turn the mains power off before attempting anything.
Please rate this solution if you find it useful else post a comment. Please note that if other fixya consultants have given you some suggestion then I cannot see this at this stage. cmmiuser01.
Posted on Oct 15, 2010
  • GE Master
  • 43,501 Answers
The self clean also burned up a wire inside and it is now shorting out...
Finding out where and what wire is tricky... you will need an OHM meter and then start to trace down the wire that is shorted and causing the breaker to trip...
Could also be the element but not always...
This is a hunt til you find the problem kind of deal... and that can be very time consuming...
If only the PR people didn't think they needed that stupid self clean feature to sell the product.... (sigh)
Self Cleaning Oven Problem
heatman101
BOTTOM DOOR WONT LOCK FOR SELF CLEANING. The motor is making a noise but lever doesn't move
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
heatman101
Oct 21, 2010 | GE Profile JTP56 Electric Double Oven
My bottom oven ( non-confection) will not go on-it will just sat 100 degrees but won't get warm or hot. Top seems to be working fine. This started after I tried to use the self cleaning feature.
If broil and bake do not work on your bottom oven, it is probably your lower thermistor or control board. If the bake works but broil doesn't or broil works and bake doesn't, it is very likely your heating element. With an ohmmeter, the heating elements should be about 40 ohms. Much higher or lower signals a problem. If you suspect the control board is the problem, they can be repaired quickly and reliably at www.fixyourboard.com
Oct 11, 2010 | GE Profile JTP56 Electric Double Oven
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
Self-Clean gets too hot on JTP56 double-oven
Your husband is correct, kind of. You should not try self clean again until you get the oven repaired. You have a temp sensor going out. I doubt that the oven actually got too hot, most likely the resistor in the sensor is failing as it heats up and giving a false temp reading.Since the lower oven was operating at the time, it is probably the sensor in the lower oven. Don't use it for baking until you get it repaired. It will go out completely and shut down both ovens. You should be able to get a new sensor for around $30 and they are not hard to replace.
The oven won't set your house on fire during clean mode if the cabinets were built with the correct air space and dimensions, but they do get very hot, about 800 degrees F. Most ovens give no trouble during the clean cycle, but if there is any weak components in the electronics system it will show up then. It will give you less trouble over time if you don't use the self clean mode and just manually clean it.
Jan 18, 2008 | GE Profile JTP56 Electric Double Oven
GE JTP56 Double Oven
Hello there,
This may be related to the F7 problem even if you are not getting an error message. Go to my web site at the following link:
http://fp1.centurytel.net/Powerman/Dreaded%20F7%20Problem.pdf
Please let me know if this works for you. I have sent my fix to over 1300 folks.
Good Luck,
Powerman
Oct 20, 2007 | GE Profile JTP56 Electric Double Oven
Self clean
You should have detailed instructions in your owner's manual. Make sure you are moving the door latch (if equipped) from left to right to lock the door.
Sep 26, 2007 | GE Profile JTP56 Electric Double Oven
GE Profile JTP56 Electric Double Oven Logo
85 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
