Question about Hoover Ultra U6430-900 WindTunnel Bagged Upright Vacuum
Installing belt on hoover self propelled upright vacuum
Need help installing belt on hoover self propelled upright vacuum
  • 1 more comment
  • Anonymous Mar 13, 2014
    using Hoover helpmate hand vacuum and cannot open the dirt capsulto empty it? what does one press?
  • Anonymous Mar 18, 2014
    directions to clean inside the vacuum
  • Anonymous Mar 27, 2014
    Charge light will not illuminate and vacuum will not operate when switched on - the battery is charged
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=40544&thid=641399
Installing belt on Hoover self propelled upright...
Posted by Fryeburger on Jun 02, 2008
Need help installing belt on Hoover self propelled upright vacuum
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Ultra U6430-900 Wind Tunnel Bagged Upright. The best way to install the belt on a Hoover to replace one or both of the belts @ the same time for the best cleaning. The average belt change is every 4 to 6 months for best results. There is a tool that looks like a screwdriver that has a right or left angle on the end that serves as a belt puller and to hook the belt(s) onto the brushroll 1st and then take your puller and then pull or stretch the belt onto the motor pulley. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 02, 2008
Unit does not self propel
You need to replace the belt that propels the vacuum. This is the belt you need:
Hoover 38528035 Belt
Feb 15, 2010 | Hoover U6616-900 WindTunnel Bagless...
Self propulsion doesn't work on my upright. Vacuum works fine otherwise
You will need to look @ your owners manual to see where the self propell belt is located i am sure yours is broke and need to replace,- it will not be hard to replace-Lance
Oct 21, 2009 | Hoover Vacuums
Self Propel doesn't work on Hoover Wind Tunnel
Your self propel wire could be broken. Lean the vacuum back like you were using it. If you stand in front of the vacuum look down and to your left. When you move the selp propel button you should see a wire move. If not then it's broken.
Oct 06, 2009 | Hoover Self-Propelled WindTunnel Bagless...
How to install the belt on the hoover self propelled vac
Video Repair instructions on installation of Hoover Windtunnel Self-Propelled vacuum ;
If you found the video helpful, please be sure to rate it by clicking the thumbs up icon below. If you have any questions about this repair, please request a clarification below.
Thank you,
Chris
Jul 03, 2009 | Hoover U5753-900 WindTunnel Bagless...
Hoover wind tunnel upright self propelled. U6473-900. Brush does not work. Heard it was a 'brush controller' problem and can be fixed. Please tell me how.
Most likely the flat belt has stretched enough so as to not turn the pulley that in turn turns the brush roll using a V belt. Also there is a small idler wheel, if hook up, then it won't engage the V belt.
May 20, 2008 | Hoover Self-Propelled WindTunnel Bagless...
How to change the belt on a Hoover High Performance upright vacuum cleaner
Generic problem for all Vacuums
Most of the Hoover upright vacuums service from the bottom and to start remove the bottom plate, that should expose the belt – if this is the case, some Hoover’s might be self propelled, if not the self-propelled vacs have 2 belts and the non self propelled models have one belt – so remove the belt(s) and then lift up on the brushroll and slide the belt onto the belt pulley then take a screwdriver tool with a hook on the end and stretch the belt onto the motor shaft – once this has been done the track the belt(s) and it should straighten out and run straight, re-install the bottom plate, plug in and test. If you cannot get @ the belt from the bottom the look for 2 or 3 screws – remove the screws and the top cover will lift off and then follow the procedure mentioned above… Questions? Please feel free to contact your local vacuum dealer in your area or in the yellow pages or contact the Hoover factory for more details.
8 a.m. - 7 p.m. EST
Apr 22, 2008 | Vacuums
Replace the belt
Take off the bottom plate, put the new belt on the motor shaft first, then stretch it to go over the pulley, it is hard, but it will stretch to go over it.
Mar 27, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Hoover Ultra U6430-900 WindTunnel Bagged Upright Vacuum Logo
2,084 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
