Question about Microsoft Computers & Internet
I just built my computer with windows 7, how do I format my 2 hard drives? I also have an SSD that does not need formatting
  • Marcus
    Marcus Oct 15, 2010
    This seems an odd question to me (not being critical of you), because I'm not aware of how you can biuld an Operating SYstem without it having formatted the drive it's on. Could you clarify if you mean you have installed Windows 7 on one hard drive and now wish to forat the other 2 drives you have installed? Am I getting close?
    Guru:
  • 158 Answers
Hi,go to start and left click,look for Computer and Right Click that,now left click Manage.A new window will open look to the left side you'll see Disk Management left click that.Opening this could take a minute so wait..When the new window opens all drives will be listed,just mouse over the drive you want to work with and right click for most options.
Hope this has helped,don't for get to rate:-}
Posted on Oct 15, 2010
My SSD (ata ts256gssd720) is not recognized when I try to install win7, I had ubuntu earlier (only ubuntu from the beginning)
When you say "not recognized", do you mean that the drive does not show up under "My Computer" with a drive letter? Or that the OS does not even know the drive is there? It is possible that the SSD was formatted using an Ubuntu-specific file system that Windows does not recogize. In this case, the drive may be seen as "Not Activated". To check this in WIN 7, click on START, then right-click on COMPUTER and select MANAGE. When the Computer Management window appears, under STORAGE, select DISK MANAGEMENT. Wait for the window to populate, then scroll down looking for the SSD in the list. It should list a disk number, size, and status of the drive. If it is not ONLINE, then there is a problem. You will probably have to initialize it, partition it, and format it to have WIN 7 see it. Be advised however, that this will remove all data previously stored on it.
Oct 30, 2013 | Transcend Computers & Internet
I was running windows 8 and having trouble with it. So I decided to go back to Windows 7 pro, when doing this I inadvertently put the windows 7 on my second internal SSD drive. now computer is...
Hmm..interesting, so let me get this straight:
You have 2 drives, C drive with Win8 and SSD drive with Win7?
You want to revert back to only having one OS on one drive?
Why can't you just erase everything on the SSD drive? I thought you already had Win8 on that drive? If you don't have anything that you need to keep on the SSD drive, I would just format it and start fresh. Although you always want your OS to run on the SSD drive so that your machine will boot up faster.
Oct 19, 2013 | Computers & Internet
Ssd won't show up as destination drive.
I'm not sure this is your problem, as you question isn't descriptive enough. But here's a solution if I do understand your question correctly.
When I have installed new hard drives in the past, I did the physical install, turned the computer on, and they just worked. Not so with SSDs I've installed. After the physical install, the SSD does not show up in the "Computer" window with all the other drives; because it's not FORMATTED.
Solution:
Navigate through:
Start > right-click on "Computer" in the right pane > select "Manage" > in the left pane select "Disk Management"
All the drives will show up in the main window, including the SSD you just installed. If it does not show up, there's a problem. Maybe one of the cables isn't fully inserted, or there's a defective cable, or a defective SSD.
You can tell the SSD from the other drives by the Gigabyte capacity, and also by the fact that it does not have an assigned drive letter (e.g. C:). Also, it's named something like "New Edition".
To continue to formatting, navigate:
Right click the SSD > select "Format" > select "Quick Format"
A drive letter will be assigned. You are given the option to change this letter if you want. Also, you are given the option to name this drive. This name will appear with the drive listing in the "Computer" window. I simply used the name "SSD", however if you want something more discriptive or colorful, it's your computer, it's your SSD, you can name whatever you want.
The other format option is for when one is installing a used HD which may have bad sectors. That option scans for bad sectors, and takes a LOT longer to format. Not necessary for a new SSD. Plus, you can scan a drive for bad sectors anytime with the "chkdsk" command.
The SSD is now ready for use, including for use as the main drive. Windows will happily load onto this drive.
Nov 10, 2012 | Samsung 830-series Mz-7pc128n/am 128gb 2.5...
I think my hdd is broken, windows does not recognize it.
I have the same problem. It's too late, I know, Diego, but I found this silly solution that I am posting that might work for others. Plug the Toshiba HDD into another USB Port: (Probably Windows OS retains each stream that it has started, and these streams need to be deleted, in the same sense that some apps won't open the file it has open currently.) I read in another forum that the computers USB ports had been fried after a power surge!
Might work for someone.
Jun 11, 2012 | Toshiba HDD2H92) 500 GB SATA Hard Drive
How to format an external hard drive in windows
if its not your primary drive
click start click on my computer you should see your drive
right click then select format
another way is to control panel administrative tools computer management disk management right click on your drive select format
hope this helps
Apr 12, 2012 | OCZ Computers & Internet
I have a 8gb UltraSpeed flash drive. I cant access it.windows says I need to format it before I can use it.I had try alot of solution But it says it is write protected.I try to format it using different...
I think you should try this out(In your windows operating system lyk.WIN 7) follow the steps:- 1. plug in your flash drive 2. ON DESKTOP OF YOUR COMPUTER OR LAPTOP 3. right click on my computer > then click on manage option 4. THEN A NEW WINDOW(computer management) WILL BE OPENED 5. then choose DISK MANAGEMENT in storage 6. then you'll see your hard disk partition and a separate partition of your 8GB flash drive 7. that (8gb partition will be unallocated) 8. right click on that partition(unallocated one) 9. then create a simple new volume..... by following these steps you'll be able to fix your problem HAVE A NICE DAY
Aug 15, 2011 | Transcend 32GB ExpressCard SSD, MLC 32 GB...
When I am put my 8 gb Transcend usb deive into pc, the message come ''u need 2 format the disk in drive I:b4 u can use it'' ,ten I click on format disk, a message come ''windows was unable 2 complete the...
First I would advice to try to format it via disk management.
Second is try to format via CMD menu.
ok
try this.
To open disk management go through:
Control panel>administrative tools> computer management> then disk management on the left> then right click and format fat file system or as per to your convenience...
Mar 19, 2010 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
I am getting problem from my transend 8GB pen drive which is displaying message that the pendrive is write protected and the data writing is delayed by windows
Your pendrive is infected with Autorun.inf virus
to remove this virus install malwarebytes (It is antimalware software)and scan your whole computer as well as your pendrive when you scaning finish remove all threats
IF the above method is not work
Try to format in other operating system like windows vista or in windows 7 because in vista and 7 you can force format your pendrive
Dec 30, 2009 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
Pendrive not work
Jan 30, 2009 | Transcend 32GB ExpressCard SSD, MLC 32 GB...
Computers & Internet Logo
50 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
