Question about Samsung Microwave Ovens
INFORMATION ON HOW TO USE SAMSUNG M C 1O15 BB MICROVAVE OCEN HOW TO BAKE ON IT
    Genius:
  • 1,417 Answers
Here are solution to baking problem below
Making using of your samsung microwave for more than a oven timer and a glorified popped corn maker. Use it to bake a cake and also with poteto . A quick way to have desert for any occation.
  • Find a space to work in your kitchen to place all the ingreedience and tools you'll need. Use the non stick spray to coat inside of Microwave safe bowl.
  • 2 Prepare in a mixing bowl cake mix as stated on the box. excluding the baking in oven part. I usually use a wisk to make sure it's completly mixed.
  • 3 Once mixed pour the mixed cake into microwave safe bowl. Set the bowl in your microwave and set on high for 8 minutes. Push start. If your microwave doesn't have a turning table you'll needt to give the cake a quarter of a turn every 2 to 3 minutes.
  • 4 After the 8 minutes is up the center should look a bit shiny, but not watery the edges of the cake should be coming away from the sides of the bowl. If center is still runny give it another minute to cook.
  • 5 Using oven mits to protect your hands remove the cake to a heat safe surface and let stand for about 15 minutes. this gives the cake time to finish cooking process and cool a bit.
  • 6 When cooled a bit put a decorative plate over the top of the cake and flip over cake onto the plate. Frost, decorate, and enjoy
  • Thank you and thanks for using fixya.
    Posted on Oct 15, 2010
    No power checked outlet and power is on
    HELLO.
    This is the way out of the problem.
    The outlet is on power,the power problem is from the microwave.
    check on the back of the microvave to locate the fuse that control the supply of power to the microvave.
    Change the fuse because it is unable to control power supply.
    Then plug the microwave to the outlet.
    Thanks .
    Sep 19, 2011 | GE JVM1790SK Convection/Microwave Oven
    No power to microwave JVM1790SK ...checked outlet and it is live
    HELLO.
    Since the outlet is live,the power problem is from the microwave.
    Thanks .
    We have a Samsung MT1044WB/BB/CB. It is a Toast & Bake Microwave Oven. We have never used any function except the microwave oven over the 8-10 years since we bought it new. We have not used it in...
    The computer died. Not much you can do with it. After ten years it doesn't owe you anything.
    Of course you could bypass the whole timer with a toggle switch if you were MacGyver.
    Apr 10, 2017 | Samsung MT1044 1000 Watts Convection /...
    When i switch ON the microvave then the turntable moves clockwise and when again after a while it is again switched ON then it moves anticlockwise,so is this an abnormal situation or a normal one?
    Totally normal as the motor will turn in either direction, it depends purely on the position of the motor's poles and the AC mains at the exact time of power up.
    Dec 19, 2010 | Samsung Microwave Ovens
    Our Microvave oven build in over the range , Model # JVM1630WB is not heating anymore; the Microvave also makes an unusual noice. Please help with a solution. Do you recommend repair or a complete new...
    Hi, Most microwave problems are not worth repairing...espec. one like this that sounds like it will be rather expensive to repair...
    Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
    Microwave Oven Basic Troubleshooting Tips
    heatman101
    Nov 25, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
    I have samsung CE103VD microwave.could you plz tell me what temperature n what time should i set to bake a cake on convection mode?
    I too have the same problem i try to bake cake and it turns to become biscuit or it dosnt cook in the centre
    Sep 17, 2010 | Samsung MT1066SS Convection/Microwave Oven
    The microvave does not heat anything up. The light works, turntable works, the 'oven' goes 'on', but neither the food nor the liquid heats up. It was working one day and then not, the next!
    At minimum, it'll be a High Voltage fuse blown. There could have been a power surge, or it could be an indicator of something more wrong with the microwave. Not that expensive to fix.
    At maximum, it'll be the magnetron (the component that creates the microwaves). This could be an expensive job.
    Refer to your manual or to the manufacturers website for information about repair locations.
    May 16, 2010 | Microwave Ovens
    Cooking temp to bake cake inn convection mode samsung model
    Hi I guess you are cooking usng the combination setting? if so The cake will be hard due to increased microwave energy, I would suggest reducing the microwave energy on the Samsung unit when using the combination setting.
    Hope this helps
    Jan 07, 2010 | KitchenAid KHMC107BT Convection/Microwave...
    To set clock on microvave
    [Clock]
    [Clear]
    [<time in 12 hour format>]
    [Clock]
    May 06, 2009 | Microwave Ovens
    Microwave Ovens Logo
    182 people viewed this question
    Top Samsung Microwave Ovens Experts
    William Miller
    William Miller
    Oscar Netto
    Oscar Netto
    Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
