Question about Apple HP DeskJet 840c InkJet Printer
Jammed deskjet 840c
The paper is jammed and I can't get it out.
Thank you
Posted on Jul 28, 2008
    Master:
  • 638 Answers
IT IS VERY EASY TO REMOVE THE PAPER JAM. YOU JUST SEE THE BACK OF THE PRINTER A WHITE COLOUR ROUND NOB IS LOCATED JUST UNLOCK THAT NOB (LOCK AND UNLOCK ICON IS SHOWN BESIDE) PULL THE DOOR SLOWLY OUTSIDE REMOVE THE PAPER JAM GENTLY.THEN AGAIN FIT THE DOOR AS IT WAS AND REWIND THE NOB TO LOCK IT .DO THIS CAREFULLY AND U WILL GET SUCCESS.
Posted on Jun 03, 2008
Printer hp deskjet 840c blinking green and red light why
Depends which red blinking light. I assume the red light is the resume light. The green light is the power light. If the Power and the Resume light are blinking alternately, then you have a paper jam somewhere in the printer. remove the paper jam and you should be fine.
Mar 18, 2011 | HP DeskJet 840c InkJet Printer
I have a hp deskjet 3940 colour printer,there is paper jam error,so what i could do to solve the problem
Follow these steps :
1.1
Take out any paper that is not jammed. Remove the loose paper from the in and out paper trays to prevent any more paper from being pulled into the jam.
2.2
Open the cover of your HP laser printer. This will give you access to the inner machinery of the printer and should unveil the jammed paper. If you do not see jammed paper, you may have another type of malfunction.
3.3
Gently pull on the jammed paper. In many cases, it will come out easily.
4.4
Move the rotors on the inside of the printer by pressing the flashing button on the housing of the printer. This may help to loosen any jammed paper.
5.5
If the jam persists, unplug your HP printer. You'll be able to pull more firmly on the paper with the power turned off. Be careful not to rip the paper.
6.6
Attempt printing again. Refill the trays with paper and plug your printer back in to test its functionality.
Oct 30, 2010 | Office Equipment & Supplies
Paper jammed and torned.cannot remove the paper
If paper is jammed internally, you may need to remove the rear access door to clear the problem.
1) Press power to turn off the printer
2) Follow manual to remove rear access door
3) Remove the jammed paper or any little bits that might interfere with the paper path.
4) Replace rear access door.
5) Power on
Try printing again. I hope this solution helps!
Dec 26, 2009 | HP DeskJet 2600 InkJet Printer
My printer jammed and now it won't start at all
My 1220C printer jammed I got the paper out by pulling and now it won't turn on for printing
Apr 15, 2009 | HP DeskJet 1220c InkJet Printer
Hp deskjet d2360 paper jam
dear sir
I miss my Driver CD so I want this Deskjet D2360 Driver
Jan 19, 2009 | HP Deskjet D2360 InkJet Printer
Paper is jammed in the printer HP Deskjet 4280
go to HP solution Center - Help - Open library - Clear paper jam
Jan 07, 2009 | HP DeskJet F4280 All In One Printer InkJet
Blinking lights on my hp deskjet 840c printer
There should be some error .So you know how to remove the catridges just remove it n re insert it properly.If there are any paper jams try removing it also.and by the way if you haven't installed the drivers for HP deskjet this problem may arise.So make sure you ahve don this.Also this can be happened if the printer have some hardware problems.So none of this solutions are working its better to consult it with an expert.
Dec 18, 2008 | HP DeskJet 840c InkJet Printer
Paper Jam
I have exactly the same printer, here's how to remove jammed paper.
1. Unplug printer from mains and your computer. 2. Turn Printer around 3. There is a darker-grey panel with a knob in the middle of it. Turn the knob anti-clockwise to release the panel 4. The jammed paper should loop around the roller. Gently pull on the loop slowly until it has released fully. 5. Put the panel back on the printer and turn knob anti-clockwise to lock it into place.
Hope this helps.
BurntLime
Oct 29, 2007 | HP DeskJet 960c InkJet Printer
Apple HP DeskJet 840c InkJet Printer Logo
5,059 people viewed this question
Top Apple Office Equipment & Supplies Experts
jasbo
jasbo
Don  Farrell
Don Farrell
neOen
Level 1 Expert
Are you an Apple Office Equipment and Supply Expert? Answer questions, earn points and help others
