Question about Faber Perla 602599 Kitchen Hood
I cannot figure how to remove the halogen lamp from the holder. It appears that the bracket which holds the plg and lamp should slide off but doesn't so there's no clearence to remove the lamp.
2 Suggested Answers
SOURCE: Problem changing halogen bulbs on perla rangehood
The more I worked with it, the more I discovered that the real problem was that a screw was not all the way screwed in and it was preventing the panel from sliding. Another problem I may have is finding the glass covered halogen bulb.
Posted on May 14, 2009
How do i get the hard drive out?
Gateway GT5056 Desktop Hard Drive Caddy Bracket Holder Mount HDD 2JB35 005
Look at this picture. It should look like the bracket your drive is mounted in. You must remove this caddy to get at the other 2 screws. above where you removed the 2 screws from the side of the drive, there should be a screw that holds this bracket to the frame. You must remove this screw. ALso there may be a spring loaded clip that stops the bracket from sliding out, you must lift or press this before sliding bracket.
good luck
May 03, 2014 | Gateway GT5056 PC Desktop
Rollei 35A slide projector - halogen lamp problem
Most all projection lamps of 1970 vintage are still available on the internet. There should be a 3-letter code on the lamp. Try using Google to search that lamp code. There are multiple vendors in the USA that have an amazing inventory remaining. Good Luck !! Jim
Nov 19, 2013 | Office Equipment & Supplies
Replace bulb in hyundai curved glass fire
Two people required for this
Remove fire from wall
Lay fire on its back
Gently slide glass panel towards top of fire and remove. Store glass safely
At the bottom of the fire there is a lamp cover fixed by 8 Philips head screws.
Remove screws and lift off the lamp cover
Slide the flexible rotisserie to one side ensuring you don't lose the rubber grommet
Remove bulb by pulling it out of the holder (force may be required)
Replace with 40 watt G9 halogen bulb. Take care not to touch the bulb with your bare hands
Push the bulb fully home
Refit the rotisserie making sure the rubber grommet is carefully pushed into the slotted hole in the axial bracket
Refit the lamp cover
Lift the fire back onto the wall and replace glass front by lifting onto the lugs either side of the fire.
Oct 22, 2011 | Hyundai Heating & Cooling
Got projector out after several years of non use. Lamp would not light. We purchased a new bulb and installed it. Still doesn't work. Fan runs and all, but bulb will not light.
Check the internal power and lamp fuse. Sometimes, when a projector is stored, an area of corrosion develops around the lamp pins and lamp holder. If you carefully clean both the holder and the pins on the original lamp you may find it works OK!
May 21, 2011 | Kodak Ektagraphic III-E-Plus 35mm 140...
How to change a front turn light in a 1996 taurus.
Lamps, Parking Front Lamp-Lamp Assembly, Taurus
Removal and Installation
  1. Remove Headlamp (13008) as outlined.
Headlamp Assembly
  1. ani_caut.gif WARNING: THE REPLACEABLE HALOGEN HEADLAMP BULB CONTAINS GAS UNDER PRESSURE. THE HALOGEN HEADLAMP BULB MAY SHATTER IF THE GLASS ENVELOPE IS SCRATCHED OR THE HALOGEN HEADLAMP BULB IS DROPPED. HANDLE HALOGEN HEADLAMP BULB CAREFULLY. GRASP HALOGEN HEADLAMP BULB ONLY BY ITS PLASTIC BASE. AVOID TOUCHING GLASS ENVELOPE. KEEP HALOGEN HEADLAMP BULB OUT OF REACH OF CHILDREN.
    Position headlamp switch (11654) and headlamp time delay switch (13736) in the OFF position.
  1. Remove two bolts retaining headlamp (13008) to upper support assembly and loosen pinch bolt. Remove headlamp assembly from vehicle.
  1. Remove park lamp bulb and socket (Sable only) and headlamp bulb and socket from Headlamp Assembly as outlined.
    Headlamp Assembly (Taurus Shown, Sable Similar)
  1. Turn lamp socket and wiring (13410) assembly 1/2 turn counterclockwise and remove from parking lamp (13200) housing.
  1. Remove screw from park/turn signal housing.
  1. Using 1/4 inch drive socket extension and swivel, insert tool through two access holes in upper radiator support. Remove screws from park/turn signal housing.
  1. Remove parking lamp from vehicle.
  1. To install, reverse Removal procedure.
Nov 19, 2010 | Ford Taurus Cars & Trucks
Can i replace the bulb only on the low beam lights or have to buy the whole casing for it...
Yes, you can replace just the bulb. It's not a sealed unit. There's one phillips head screw that holds in the corner lamp. Then you'll see the outer screws to remove the headlight. On the hood side, carefully peel the rubber off the teardrop shaped plastic holders. Remove the 10mm bolts and the whole assembly should slide right out. Twist the retaining ring (unplug the bulb first) that holds the bulb in. Pull the bulb out. Don't touch the glass on the new bulb as it's halogen and the oil on your fingers will damage it as the bulb heats up. If you do, clean it with rubbing alcohol.
Mar 13, 2010 | 1997 Dodge Ram 1500 Club Cab
How do I change the back turn signal on my 2001 ford taurus
DIY - 5 Minute Turn Signal Bulb Replacement This is very simple to do. First you will need an 8mm socket and wrench to loosen one bolt. Second a good long flat head screwdriver. There are two black metal folded tabs behind the headlight assembly and one 8mm bolt holding it in plae at the center point of the front of the car. Loosen the bolt and remove. Use the screw driver to pull up the metal straps and then slide forward the entire assembly. This will slide easily unless your front bumper has been bumped! That will make it a little difficult to slide if it is out of alignment. If it was never bumped than this should take all of 5 minutes.
Replacing front parking lamp/turn signal/cornering lamp bulbs
  1. Remove headlight / lens assembly per below steps mentioned later
  2. Rotate the bulb socket of the offending bulb counterclockwise and remove from the lamp assembly.
  3. Carefully pull bulb straight out of the socket and push in the new bulb
  4. Install the bulb socket into the headlight assembly by rotating it clockwise
  5. Re-install headlight assembly - hold snugly into place until the brackets line up and retainer pins can be pushed down
To replace headlight bulb:
  1. Make sure headlight switch is turned OFF.
  2. Remove the bolt at the end of the headlamp housing.
  3. Pull the two black tabs with the L shaped bracket toward the back and then up and pull out(Located at the back of the headlamp) to release the headlamp assembly from the vehicle and pull headlamp assembly forward.
  4. Disconnect the electrical connector from the bulb by pulling it.
  5. Remove the bulb socket retaining ring by rotating it counterclockwise.
  6. Remove the bulb from the lamp assembly by pulling straight back.
    Do not twist, as there are alignment slots built into the lamp assembly socket.
    It may take some effort to remove the lamp because it has a rubber o-ring type seal - try a bit of wiggling side-to-side
  7. Insert new bulb into headlight assembly - don't touch the glass - use gloves, paper towel, or similar
    Make sure that the flat surface of the bulb socket is facing upward, and is firmly seated
  8. Re-attach retainer ring by rotating clockwise
  9. Reconnect the electrical harness
  10. Re-install headlight assembly - hold snugly into place until the brackets line up and retainer pins can be pushed down
NOTES
  • Do not touch the glass of the new halogen bulb - the oils in the skin will shorten the life-span of the new bulb, or possibly cause the bulb to explode when first turned on
    If the bulb is accidentally touched, it should be cleaned with rubbing alcohol before being used.
Additional Information1996-2005 Bulb Numbers:
  • FRONT Turn-signal - 3457 AK (amber)
  • Headlamp - 9007 QL (9007LL optional)
  • Tail lamp/brake/turn lamp 3157
  • Tail lamp/brake lamp (wagon) 3157
  • Rear turn lamp (wagon) 3456K
  • Backup lamp 921
  • Backup lamp (wagon) 3156
  • License plate lamp (2) 168
  • High-mount brake lamp (2) 912
  • Rear side marker lamp (wagon) (2) 168
Feb 24, 2010 | 2001 Ford Taurus
I have 2006 Grand Prix How do I change head lamp?
Caution Halogen bulbs contain gas under pressure. Handling a bulb improperly could cause it to shatter into flying glass fragments. To help avoid personal injury:
Turn off the lamp switch and allow the bulb to cool before changing the bulb.
Leave the lamp switch OFF until the bulb change is complete. Always wear eye protection when changing a halogen bulb. Handle the bulb only by its base. Avoid touching the glass. Keep dirt and moisture off the bulb. Properly dispose of the used bulb. Keep halogen bulbs out of the reach of children.
Raise the hood.
Remove the headlamp assembly bolts from the upper fascia support.
Slide the headlamp assembly outward enough to release the headlamp bracket tabs from the slots in the upper fascia support.
Position the headlamp assembly away from the vehicle body to access the electrical connector.
Disconnect the electrical connector from the headlamp assembly.
Remove the headlamp assembly from the vehicle.
Disconnect the electrical connector from the headlamp bulb/socket.
Remove the headlamp bulb/socket retainer ring from the headlamp, by turning counterclockwise.
Remove the headlamp bulb/socket from the headlamp assembly.
Jun 13, 2009 | 2006 Pontiac Grand Prix
3M model 45CG Thermofax Machine how to change bulb?
On either side of the drive table are single wires that go to each end of the lamp. Remove one screw on each side of the snap-in levers. Turn red handle on left side of unit as you are looking at it. Lift up each lever (screws you just removed) carefully. You can slide the entire unit out from under the clear plastic, then you will be able to see the lamp. It is a long halogen lamp. Do not touch the lamp with your fingers!! The oil on your skin will cause that area to overheat, boil, and blow. Disconnect wires on each side. Loosen bracket screws (2 on each side). Lift lamp out of heatsink tray by porcelain ends and slide out. Replace in reverse order. REMEMBER: DON'T TOUCH LAMP WITH FINGERS. USE GLOVES OR HANDLE BY PORCELAIN ENDS. GOOD LUCK!!
Apr 05, 2009 | Office Equipment & Supplies
REPLACEMENT OF [LOW BEAM] HALOGEN BULB IN 2004 Buick LeSabre
I just Replaced a Low Beam Light bulb on a 2005 Buick La Sabre.
If You use a Metric socket and Remove the Two Silver bolts Attaching the headlight Assemble onto the metal surrounding the the lamp assembly it comes out to the front. This makes it much easier to access the bulb. Twist it counerclockwise & it comes out by pulling gently on the bulb. Then by realeasing a tab that is the socket holder bulb can be removed & replaced with a New #9006 low beam halogen light bulb. Wrap a Paper towel around the bulb & do NOT touch it with your bare hand as this wiil ruin a halogen bulb,
Jan 22, 2009 | 2004 Buick LeSabre
Faber Perla 602599 Kitchen Hood Logo
51 people viewed this question
Top Faber Kitchen Ranges Experts
Steve
Bill Boyd
dik stukkien
dik stukkien
Are you a Faber Kitchen Range Expert? Answer questions, earn points and help others
