Question about T-Mobile Dash Smartphone
Help me please!!!!!!
I have a tmobile dash and my screen doesn't work...when I cut it on it shows a little bit and fades away and the screen shuts off but the phone is still on!!!!!
If the entire phone still works (make and receive calls, recharges, etc), then you probably just need a new screen. Two basic options:
  1. Buy the screen and do the replacement yourself. Usually about $50 or a little more (depends on your shipping and if they include the tools). You can find videos online for how to do the repair.
  2. Have someone do the replacement for you. When my phone broke, the following place did the repair: http://www.mobile-device-repair.com. They had it fixed in under a week, did a great job, and it was just $75 total. A lot cheaper than buying a new phone and I didn't have to worry about screwing it up by doing it myself.
Hope that helps.
Posted on Jun 03, 2008
Why is my acer touch screen laptop messed up? It only got a Little bit maybe 5 little drops of water & i took them off right away. But when i swipe the screen the middle gets all scratchy. It...
Depending on what you wiped it off with? Paper towel, Bad. Microfiber cloth for computer screen, good. Shut down the machine, unplug, remove battery, Use the proper cleaning fluid and Microfiber cloth to clean. OR, this: http://www.amazon.com/3M-9027-High-Performance-Cloth/dp/B00006IBLQ
Feb 01, 2013 | Computers & Internet
My tmobile dash freezes every time i try to start.
Turn the handheld off, hold the two soft keys (the dashes to the left and right of the phone buttons) hold the power button for 1-2 seconds and then release the soft keys. It should prompt you to clear storage. The “send” button is considered as the green phone button.
How to Hard Reset a T-Mobile Dash with operating system: 1. Select Start
2. Select Accessories
3. Clear Storage
4. Type in 1234
5. Select Yes
if this helps please rate the posting..thanks
Mar 02, 2009 | Cell Phones
My tmobile dash lcd screen.
im trying it now i will post again if it works thanks
Jun 23, 2008 | HTC S620 Smartphone
My screen is black
I just posted for someone else with the same problem. My suggestion: have the following company fix it for you: http://www.mobile-device-repair.com. They repaired my phone in under a week and it was just $75. The other option is to spend some time finding a screen online, get the tools, and repair it yourself. That solution will be a bit cheaper but also a little more risk.
Hope that helps.
Jun 01, 2008 | T-Mobile Dash Smartphone
T-mobile dash
I tried using a the google mail java app on my tmobile dash. It froze up on me, and when i turned it back on it just stays at the "tmobile" splash screen. I have tried using the soft key and power button reset but it doesnt work. What's weird is that it wont power down unless I take the battery out. It powers on, shows the tmobile splash screen, then freezes. Is there any other way to reset it or is it totally bricked? I bought it new off craiglslist so tmobile wont replace it for me cause I'm using it unlocked on cingular.
Ok bro I know I am a bit too late to help you with this problem but someone else may benefit from these directions. I see most places online only have half advice about this very common problem with T-mobile Dash.
This is what you need to do, you have to do a hard reset exactly like "reviel" mention. Also like he said timing is essential but the trick is that you need to show some patience through the process.
Note: Please read the directions completely before doing anything for better results.
Step 1: Take your battery out and shut off your phone
Step 2: Press and hold the two soft key buttons.
Step 3: Press and hold the power button for exact two seconds, 1001, 1002 and release, but continue to hold the two soft key buttons.
Step 4: Within seconds a black screen with some text will come up asking you to confirm if you wanna delete everything; and right then you let go of your soft key buttons and press the green call button (also known as the "send key").
Step 5: You are done but not really, your job now is to find something else to do and leave your phone alone for at least 2 minutes. Eventually if you don't have a SIM in it, it will prompt you for it and you click the soft key to choose "OK"; also, it will ask you to confirm to restart and you click the soft key to chose "Done" for it.
Wait a minute for it boot up and overall it should do it.
May 31, 2008 | T-Mobile Dash Smartphone
Tmobile dash is getting me p'd off
Mine does the samething. I'm running 6.1 and have found the problem to be the system fails to read the sd card on boot. When I reset my memory I don't put the sd card in until the system has booted back to the start screen. Works fine everytime.
Apr 15, 2008 | T-Mobile Dash Smartphone
Tmobile dash won't read my sim card
Have you inserted the Sim correctly. The Sim goes in with the gold plated contact facing down and the cut corner of the sim on the bottom right corner showing when inserted.
Feb 26, 2008 | T-Mobile Dash Smartphone
Faded Picture
I would have to say it does sound like the CRT is reaching its end. The thing that points this out that the picture gradually gets a little bit better as it warms up. It most likely isn't worth the cost to fix it.
May 07, 2007 | JVC AV-27230 27" TV
T-Mobile Dash Smartphone Logo
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
