Question about RCA R52WM24 52" HDTV Projection Television
My Rca hdtv keeps having a 3 screen view How do i Fix it?
  • RCA Master
  • 3,459 Answers
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
To get fixed either call in a local TV repair company or goto sites such as www.TvRepairKits.com to get a repair kit with instructions.
Posted on Oct 15, 2010
    Genius:
  • 1,030 Answers
Is this picture 3 d looking.. is it bowed in at top and bottom. if this is the case it sounds like a convergence issue. if it was in my shop with these sympton the first thing i look at is in the customer menu under setup do you have the convergence option. if you do not then what is suspect is the fl231 fuse a very common problem then read the article fl231 fuse problem in the tips and how to section of this website http://www.fixya.com/support/r1062030-fl231_problem_convergence_not_in let me know if this helps if not i help dig in a bit deeper
How do i fix my rca lcd tv that keeps flickering
Flickering can be adjusted after enter its service mode option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sep 17, 2016 | RCA L46WD250 46-Inch LCD Scenium Flat HDTV
RCA 24" Class LED-LCD 1080p 60Hz HDTV 1.7" ultra-slim, LED24A45RQ USB input
One use for the USB inputs on flat screens is to allow you to connect a USB stick or external hard drive and watch or view any external files you have.
Hope that helps!
Aug 11, 2014 | RCA 24" Class LED-LCD 1080p 60Hz HDTV 1.7"...
The menu screen keeps popping off and on during regular viewing....I cannot make it stop
Thats a very common problem with that chassis which is indicating the signal board needs rreplacement
Aug 02, 2011 | RCA R61WH76 61" HDTV
The picture has a triple image
Very common and easy fix. Install the RCA repair kit called ' ITC222 and ITC222A convergence option missing repair kit. Its available from www.tvrepairworld.com and contains the parts and the CD with repair instructions.
Jul 11, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
How do you fix a 52" hdtv ready when its in 3D blurry format
This tv doesn't have 3D capabilities - the image appears blurry because both images are displayed on the same screen at the same time. Just don't use the 3D option from the BluRay player, view the movie normally - 2D.
Jun 13, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
The Red,Blue,Green do not line up and keeps blowing fuse
you need to replace 3 items FL231, DL231, CL230 then resolder the vertical IC and flyback conections. You can get the three components under the RCA parts category at this link.
http://servicemanuals.vstore.ca/
Jan 25, 2009 | RCA Scenium D40W20 40" Rear Projection...
Convergence
In rear projection, there are 3 small crt's in the rear projecting off of a glass for viewing. All have a set of convergence rings on them, fined tuned so be careful not to rough handle them. You'll have to find the one that is bad, possibly by lightly trying to move the rings.This is a very long and drawn out process but to make it short. These are polarized rings, each ring will move a diff. color on your screen. There is a tighten ring on all three, it should br in the front of them all. Be careful. Have problems call 812-207-4521
Sep 11, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA D52W20 52" TV SHUTS DOWN AFTER A FEW MINUTES
this is the filment circuit having a problem. i think you will find it is a loose connection on a solder joint. Goodluck
Jan 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA R52WM24 52" HDTV Projection Television Logo
57 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
