Crossover board for vp2520 - Audio Players & Recorders
    Genius:
  • 1,325 Answers
Get in contact with this company -- i am certain they can direct you in the right path
http://www.mwrf.com/Articles/Index.cfm?Ad=1&ArticleID=13008
Posted on Oct 15, 2010
Whats the correct order to run my mackie mixing board EQ and crossover together
You didn't mention any model #s, however, a typical set-up would be the following:
  • A Crossover is the last processor in-line before your amps. Always use a proper protection capacitor on your high end (horns, mid horns, tweeters, Piezos or High Horns to protect the diaphrams)
  • The equalizer can be placed anywhere between your mixer and crossover but should generally be placed after all other processing equipment and before your crossover.
Hope this helps.
Jun 26, 2016 | Audio Players & Recorders
KRK Rokit monitor has no sound from bottom speaker (the larger speaker for lows and mids) the unit powers up fine and i get sound through the tweeter.
What you are describing is a total component failure of something in the crossover board. You cannot really check a crossover without an oscilloscope and a frequency generator. In a lot of cheap speaker systems, there is no crossover board attached to the woofer. In your case it appears that a low pass filter is present on the woofer. http://circuitdiagram.net/loudspeaker-system-crossover-network.html
Sep 27, 2015 | KRK RP5G2 Pair Rokit G2 Powered 2-way...
Sp 3g crossover wiring color code
Horn is red +, black -, mid is white +, blue-, lows are yellow+, blue-. If you look at the crossover board, you'll see the treminals are labeled what goes to where.
Apr 21, 2014 | Peavey Music
I have a pair of jamo R909 speakers that need crossover / board replacement--- any thoughts or suggested repair options? The company has been horrific. Love the speakers, but the company doesn't s
Hi Katrina,
Yes parts are available for your R909 speakers.
firstly I am surprised that you have managed to blow both tweeters and crossovers.....there must of been some serious distortion/amplifier clipping involved there???
So a couple of things.
Can you actually see damage to the crossover boards? If so what components have been damaged? i.e board loactions and parts.
The crossover is available but they are not cheap. $1560 each (AUS)
So it would be preferable and much cheaper to repair them at board level.
Tweeters are also available.. $745.00 each (AUS)
Regards John
jb@qualifi.com.au
May 15, 2012 | Audio Players & Recorders
I would like to know I have 2 subwoofer with amp how can I connect it the best way thank you
first, you will need a passive crossover, i do not believe that the mono out of the mixer has a crossover., if the amp does not have a crossover. you could use the "mono" output, and split the signal, with an adapter, to both channels of the crossover, then run both of the low outs to the 2 channels of the amp. or, you could hook the crossover to the main laft and right outputs of the board. send the 2 low outs, left and right, to the subs' amp, and send the two high outs, left and right, to the main speakers' amp.
Nov 24, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
My wharfedale titan 15 passive loudspeaker only sounds the tweeter but not the driver
If you have never overdriven the speaker, it'll probably be a dry solder joint in the crossover. Take all the screws out the back panel, the crossover is mounted on that. Unscrew the crossover board, redo all the solder joints, finaly make sure the cheap spade terminals are connecting to the speaker properly, then put it all back together. You can check all the connections if you have a multimeter. Same happened to me.
Dec 23, 2009 | Audio Players & Recorders
Where is the crossover located in the mackie srs 1500and does the crossover have a fuse.
The Mackie SWA1501 has an active electronic crossover on its main circuit board.
Jul 15, 2009 | Mackie SWA1501 Subwoofer
I have a 400 watt speaker and the board in not working and the the speakers and everything else is working good but i think that it the board inside the speaker.
the board that you are talking about is the crossover, does any of the speaker work the woofer or tweeter or midrange drivers? If the woofer does not work then take out the woofer and take the wires that attach to the speaker on the back and hook them directly to the speaker that you took out if it plays you need to replace the crossover in the speaker, this should be easy, just call the company that makes the speaker and order a new crossover, you can do this also with the speaker if there is no sound when you hook it up direct.
Aug 19, 2008 | Audio Players & Recorders
Blown crossover
Sounds like the crossover is smoked. Unusual, but it happens. Just call a Peavey service center for the part number and you should be able to order direct from Peavey. If you have problems getting the number, let me know and I'll try and get it for you.
Dan
Aug 18, 2008 | Audio Players & Recorders
74 people viewed this question
 Grubhead
Grubhead
