RCA DLP Model # M50WH74S Problem: Replaced blown lamp, when plugging it into AC, blue LED lights up right away for 2 or 3 seconds, then shuts off. Waited for a few seconds, and relay will click on and off ( blue LED indicator is not lit even when pressing the power button). But,TV is still dead.
  • jvn4 Oct 17, 2010
    Can i use a different ballast from another set? I have a Sony with a optic block problem, since all of the connections are the same?
  • 11,800 Answers
The blue led dies because the power source dies: it detects a big short on one of its outputs and shuts down to protect itself automatically. Since apparently it's a very big short and you just had to replace the bulb then the faulty part is the ballast board (the one that powers the bulb): when the bulb failed it has generated a power surge that fried it.
Replace the ballast and verify the power source board: if you're really unlucky when the ballast got fried it has in turn damaged the power board.
Posted on Oct 17, 2010
  • Azrael SRL Oct 17, 2010
    I seriously doubt it - the voltages are different on the power side. But you have nothing to lose trying it - both tv's are dead anyway. Just make sure the polarity is the same on both connectors.
Rca dlp model /page-2
White dots on a DLP are ALWAYS a DMD chip problem, you can find these online like at Discount-Merchant, they are easy to replace you can find videos on youtube, they are sometimes called DLP chip.
Easy to do for a fairly experienced or handy person!
Feb 21, 2014 | RCA 50in Tv M50 Wh 92s Dlp Hdtv Works But...
Have a RCA M50wh74s replaced the bulb....blue light blinks 5 times again and again eventually a steady blinking all blue light bulb in correctly, door closed correctly, any suggestions and I have sound.
Bad Caps on the AC IN board? I would visually inspect the caps on the AC IN board for any sign of swelling or doming on top. They should be perfectly flat.
Aug 20, 2011 | RCA HD52W56 52" Rear Projection HDTV
I need to find the bulb for this tv m50wh745
www.tvrepairworld.com click on RCA DLP Lamps Its for the M50WH74S models and its the lamp and the housing not just the lamp
Aug 04, 2011 | RCA HD50LPW175 50" HDTV
I have a mitsubishi the model number is wd-82837 it keep shut down after blue screen show
Ur tv"LAMP"LED light indication flashes or stay on?Ur tv projection lamp been inside this tv like a 1 1/2 or 2 years and tv been on an in used like 4 or 5 hours every day.Yes to all of this,than the tv projection lamp is the causes and it life are ending.The tv projection lamp require replacing.
Dec 09, 2010 | Mitsubishi WD-82837 82 in. HDTV DLP TV
My Samsung DLP model HL-P6163W keeps turning on and off and now lights are flashing. We replaced the color wheel last year and about two years ago the lamp.
could still be the lamp but it could also be the Ballast for the lamp has failed. I've replaced a lot of Ballasts on DLP machines.
Nov 17, 2009 | Samsung 61" Slim-Depth DLP HDTV
Mitsubishi DLP overheating
Mitsubishi has problems with the thermal sensor going bad. They extended the warranty for several sets. The sensor is right by the lamp. Call mitsubishi and insist they do something for you. If you keep playing your set, the bulb could also be at risk. I would think your set is covered being a 62" set. Good-luck and be sure to act ASAP.
Dec 07, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Toshiba DLP 50HM66
This is a feature of the Hot Restart feature
Jun 18, 2008 | Toshiba 50HM66 52" Television
Rca m50wh74s HELP
Sounds like a bad high voltage transformer (FBT). Call a service center.
Jan 11, 2008 | RCA HD52W56 52" Rear Projection HDTV
Rca 50 dlp hd50lpw175
Yes but did you find a fuse open and changed it?
Jan 08, 2008 | Televison & Video
RCA 50" widescreen model M50WH74S Quit working
the deflection board put set into shut down,should be under warranty for service.
Aug 03, 2007 | RCA HD52W56 52" Rear Projection HDTV
Televison & Video Logo
305 people viewed this question
Top Televison & Video Experts
Electro Med Services...
