I cannot put the power on my printer - Office Equipment & Supplies
  • 6,487 Answers
If you;re saying that the printer wont power ON , this is a sign of a hardware failure on the printer or with the power adapter that you have.
So the first thing that you can do here is try connecting the printer on a different power outlet and also try a different power cable and if still printer wont power on the power supply on the printer is bad and needs repair and replacement.
Posted on Oct 15, 2010
Replaced cartridge won't print
Step followed:-
1. Remove cartridges.
2. Press and hold the Power Button and remove the Power Cord from the back of the Printer(in printer ON state).
3.Shake the cartridges and clean the cartridges.
4.Clean the printhead softly from cotton clothe.
5.Put the cartridges again.
6. Press the power button and connect the power cord.
7. Clean and allign catridges from printer control pannel.
This might can help you and try to put some thick paper instead of normal paper.
Apr 05, 2014 | HP PhotoSmart Office Equipment & Supplies
Tip
For HP officejet printers with "ink system Failure" error : Do this
Unplug the USB cable from the back of the printer if it is connected. Now take out the power cord.
Now Reset the printer:-
To reset it.
Connect the printer power cord to the Wall Outlet or Wall Jack.
Make sure it is not connected to the Serge Protector or power strip.
Partial reset :-
Now on the printer itself. --> Press and hold the
# and 3 button at the same time. Now take out the Power cable from the back of the printer and wait for 20 sec. Now put the power cable back in the printer. Now release the two buttons. ( Note :- remember you need to hold down the # and 3 button the hold time )
(On the printer screen it should say Part nvm reset.)
Now try to turn on the printer and check if it shows the Ink system failure - 0xc19a0027 option. If it works Perfect. If not then do this :-
Semi-Full Reset:-
Open the front door and take out all the cartridges from the printer. Now close the door.
# and 6 button at the same time. Now take out the Power cable from the back of the printer and wait for 20 sec. Now put the power cable back in the printer. Now release the two buttons. ( Note :- remember you need to hold down the # and 6 button the hold time )
( On the printer screen it should say Semi-Full rest )
The printer might shut down automatically or may be it won't. At this point Put the cartridges back into the printer and then turn on the printer if it was shut down.
or If the printer is on turn it off and then switch it back on.
The problem should be resolved up till now.
If still exist DO the last step which will reset the whole chip of your printer.
********************Do not do this step unless required************************
( Note :- make sure before you do this step the cartridges should be out of the printer. As it can corrupt your cartridges as well )
************************ Full reset of your printer ********************************
# and 9 button at the same time. Now take out the Power cable from the back of the printer and wait for 20 sec. Now put the power cable back in the printer. Now release the two buttons. ( Note :- remember you need to hold down the # and 9 button the hold time )
( On the printer screen it should say Full rest )
If still the problem Exist Call HP as the product has gone bad. The printer will be replaced if it is still in warranty. Remember the printer HP replaces is always a refurbished printer.
HP :- 1-800-474-6836 ( Tech Support )
on May 26, 2010 | Office Equipment & Supplies
Power supply lexmark
dude its the problem of logic card plz dont play with power adapter.
go to service station or do repair yourself if u know
Jun 07, 2012 | Lexmark X2670 All-In-One Printer
Printer shows no cartage found
Partial reset :-
Now try to turn on the printer and check. If it works Perfect. If not then do this :-
Semi-Full Reset:-
May 11, 2010 | HP PhotoSmart C4385 All-in-One Printer
The Officejet J5780 has a error message of out of paper@
First of all make sure there is no paper pieces stuck inside the printer. Now ..!
Unplug the power cable ofthe printer.
Unplug the USB cable from the Back of the printer and make sure it is stand alone printer.
Now,
Take out the duplex-er ( A box at the back of the printer which has two buttons at the ends of it which you can press to detach it from the printer :- It is used for duplex printing ) from the back of the printer.
Once you take it out you can see the ROLLERS and the ROD which takes the printer page and rolls back to give you the out put.
Take a lint free cloth and clean the rod and rollers. Try to move the rollers in clock wise or anti clock wise direction. If it moves fine Other wise hardware issue.
Now attach the Duplex-er back to the printer.
To reset it.
Partial reset :-
Now try to turn on the printer and check if it shows the out of paper option. If it works Perfect. If not then do this :-
Semi-Full Reset:-
The printer might shut down automatically or may be it won't. At this point Put the cartridges back into the printer and then turn on the printer if it was shut down.or If the printer is on turn it off and then switch it back on.
May 07, 2010 | HP Officejet J5780 All-In-One InkJet...
It just started blinking and says the printer is offline
If it says printer is offline, it usually means your printer is not connected to the PC. Blinking printer light means there is a problem with the printer (usually paper jam) or with the ink. Check the ink cartridge. Take the cartridge out and put it back in. Make sure you also check the USB cable that goes from your printer to the PC, take it out and put it back in. Also, try to turn off the printer, take it out of the power outlet for 30 seconds and put it back in. If you have a power strip, don't use it, try plugging it directly to the power outlet on the wall and turn it back on.
Nov 09, 2009 | HP Deskjet D1430 InkJet Printer
Trying to dowload lexmark printer series 4350 on my compaq laptop
hi
before you put in disc,,connect USB cable to the computer,,make sure the printer is connected to power supply and it is powered on...if your printer still does nt show up...contact tech support
Jan 25, 2009 | Lexmark P4350 All-In-One InkJet Printer
My laserjet 1300 burnt
b'coz of your printer power supply goes to down
replace powersupply unit
Feb 27, 2008 | HP LaserJet 1300 Printer
12 people viewed this question
jasbo
jasbo
