Nspire 1 Bay (NSP-511U) USB 2.0 External Drive Case Logo
Posted on Oct 15, 2010
Driver for Nspire nsp-511u external drive case?
Error 1308. Source file not found: E:\PC\TI-NSP~2\Program Files\TI Education\TI-Nspire\locale.properties. Verify that the file exists and that you can access it.
Maybe the file is missing, or there is a defect on the disk. I suggest you go the education.ti.com website and download the trial software from there. Install it on your computer and validate it with the license that came with your calculator.
I had external hard drive got a new casing just want to know how to put in new casing
Hi
Which type or external drive you have (PATA) or (SATA), connect your driver to your External drive case, The external drive case have both of connector to connect the drive, chose your drive and connect the drive and connect the power, that ok
Now close your drive case and USB one side put in external drive case and second side put your Com/Lapi and switch on your external drive, your com/lapi detecting your external drive and your see the my computer external drive now what ever data you want to store, copy
and enjoy
Even when laptop is plugged into an electrical outlet, it will suddenly think it is not and drain the battery power..the indicator lights will flash and battery power will drain.
There may be a fault in the laptop's power supply adapter.
Try testing its rated output voltage versus the actual with a multimeter.
If the adapter comes in 2 sections, 1 cord from the wall to the adapter, and then the adapter to the laptop, be sure to test both sections.
Replace the adapter if required.
Also check that the connection socket where the power adapter plugs into the laptop is not loose and preventing proper electrical contact.
Good luck.
I noticed that my NSP-450P4DL13 power supply is not running the larger fan designed to take air internally. Is this thermally activated, or is it supposed to run at all times? the smaller fan which expels...
*********** board also can control the function of the fans. Enter the bios and check if the system has this function. It is based on the temp of the system. Good Luck
My NSpire power supply just randomly fried, and is still under warrenty. however i cannot find their website or any number to call for it. help!
give these guys a call or drop them a line and they should be able to help you out with this problem. www.nspire.com
Let me know if you need more information.
Thanks
Jason
When booting my computer i only get to the windows loading and then i get the blue screen which i do not get enouhg time to read, it restarts very quick. i tried swaping hard drives and still can't get...
One bad lead will cause your computer to continue in a cycle
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
hope this helps
NSPIRE/ASUS LAPTOP
I'm not sure what model of laptop do you use.But I'm pretty sure that all laptop have quite similar method to replacing the hard drive. It is below the laptop and usually at the screwed panel that you'll need to open have indicate a HHD symbol. You can check out the video of how to replacing a laptop hard drive through this link : http://www.youtube.com/watch?v=cvmNHPogvWA
NSP 352U
Fry's electronics has replacement LED's. If you cannot find it please let me know and I will see if I can get one to you.
Top Nspire Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Nspire Computer and Internet Expert? Answer questions, earn points and help others
