Question about SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue
I don't know which power adapter to use and I can't locate my user manual. What is the DC input? My problkem is I need to make sure I provide the right DC input - I have several adapters - what is the required volage for the 320G?
    Genius:
  • 1,016 Answers
Most externals are 12v input voltage so as long as you have a adapter with this input voltage your be fine, and the hard drive should operate.
Let me know if you need more information.
Thanks
Jason
Posted on Oct 15, 2010
Need to know input, polarity and voltage to ensure I have the right adapter.
Complete Guide to Using the Correct Charger or Power ...
www.groovypost.com/.../choose-right-power-adapter-charger-phone-lap...
Jun 24, 2013 - If the device has a DC input of +12V / 5.4A, get an adapter that has a DC output of +12V / 5.4A. If you have a universal adapter, make sure it has the proper current rating ... Ideally, you'll have the same voltage, current and polarity on your ......or hdmi on my laptop .can you say what's the reason for the same.
How to select an AC to DC power adapter - ApogeeKits
www.apogeekits.com/power_adapter_selection.htm
An explanation of regulated versus un-regulated AC to DC voltage power adapters. ...voltage output power adapters and how to use this information to select the right one... Some (more expensive) DC voltage output power adapters have voltage ... Care should be take to ensure that the maximum input voltage of the load ...
AC/DC Power adapter ' Laptop Parts 101
www.laptopparts101.com > Laptop parts
Dec 26, 2008 - It's very important to use the right adapter for your laptop. ... Polarityon the new adapter's plug must be the same as on the original ... AC/DC power adapter voltage and amperage ..... I have purchased an non-hp dc-dc convertor (150W), 12Vinput, 19V output. .... So the cable component has to be replace.
Determining Proper A/C Polarity - Galen Carol Audio
www.gcaudio.com > Resources > How-To's
Jan 10, 2016 | Computers & Internet
What is the power output of ac dc adapter in jensen jta 460? Can this adaptor be changed with 220volt ac dc adapter with required dc output?
For Any Adapter:
As long as the Voltage and Power output of the power supply (wall outlet or other) matches the input requirements for the adapter whether 110V or 220V.at enough amp output; and
IFF the dc output of the adapter is exactly the same voltage and has for amps at a minimum matches the maximum amperage requirement for the input of the device, any of them will work, as long as it has the right connector with the correct polarity needed for the device!
Or, in other words...
Supply Output V = Adapter Input V
and
Adapter Output V = Device V
Adapter Output A(min) >= Device A(max)
Aug 27, 2015 | Computers & Internet
What's the required power source for model#95914
what is the deviice is it a Harbor Freight security camera being model number 95914 ?
if it is this device on Page 6 of the user manual it states to use the correct ac/dc adapter being 120 V~ / 60 Hz Input
9 VDC /200 mA Output
http://camera.manualsonline.com/manuals/mfg/harbor_freight_tools/95914.html?p=6
be careful on 120v or 240v with the power point depending on country.
If it is a different device can you please provide more information so we can match it to whatever we dig up for you ?
Hopefully you will find on the device a lable stating its DC voltage and DC current rating.
Nov 20, 2014 | Kitchen Appliances - Others
Yahama PSRE413 Keyboard DC Adapter Issues
Yahama PSRE413 Keyboard DC Adapter Issues (1): First try battery power to ensure Synth works.
If it does, problem is most likely near DC socket, or socket contacts dirty / worn.
(2): Get a contact-cleaner spray (Servisol, McKenic, Kontakt, etc) and squirt into socket, then plug / unplug / twist DC plug to 'scrub' the contacts.
(3): Get a qualified tech to manually apply DC to the PCB solder-points which will verify if socket is faulty.
Aug 10, 2017 | Yamaha PSRE413 Keyboard
I need a user's manual for Voltcraft Fast Charge Delta Peak model MW3610HC. I believe it is a battery pack charger. It is a Europian product that requires a U.S. AC adapter. I want to know what size...
SPECYFIKACJA :
  • V detection
  • Cigarette lighter plug
  • Double output
  • Discharge function
  • Dla Ni-Cd/ Ni-MH battery
  • Input voltage: 230V AC, 50Hz, 13.8V do 24V DC
  • Output :
  • Dla 230V AC or 24V DC input: 5.6V DC (4 celle) do 11.2V DC (8 cell)
    • Dla 24V AC input: 5.6V DC (4 celle) do 8.4V DC (6 cell)
  • Output regulowany : 1,000/2,000/3,000mA
Sep 04, 2011 | Vacuums
Lumix DMC-FZ50 will not power up. Tried 3 batteries and 2 chargers, no luck. tried turning on and off, changing modes...no luck. Suggestions?
If this camera is like my FZ20, there is a socket to provide power to the camera from a mains adapter. The input socket is under the cover where the USB lead goes, and the manual shows a lead attached between this and a battery charger. My battery charger does not have this lead or DC output, though. The one that does is an optional extra, part DMW-CAC1. The manual recommends using the adapter to power the camera when it is connected to a computer, to make sure that a flat battery doesn't cause the memory to become corrupted.
My suggestion is that you attempt to power the camera through this DC power input, either with the approved adapter (maybe one of the chargers you are using has the output?) or with a generic one. I have successfully used a generic 9 volt adapter on my camera (positive center connector).
If it will power up with an adapter, I expect there is an issue with the connections in the battery housing. Otherwise, it might be a more fundamental fault.
Nov 16, 2010 | Panasonic Lumix DMC-FZ50K Digital Camera
My Kodak Easyshare V1233 will only power up when plugged into the wall charger. Even after staying on the charger it will not power on unless plugged in.
Kodak has 3 types of charger that can be connected to a wall socket
USB AC Adapter - is especially useful when traveling, away from your computer, or just plain on-the-go. Connect your camera's USB cable to the adapter and plug it into a wall outlet to conveniently charge your camera.
5V AC Adapter - Provides in-camera charging for all KODAK EASYSHARE M and V Series Digital Cameras
Input: AC 100-240 V 50/60 Hz Output : DC 5.0 V
3V AC Adapter - Provides direct power to your camera but it will not charge the camera battery
Input: AC 100-240 V 50/60 Hz Output : DC 3.0 V
* You need to check the type of adapter your using. If your using the 5V AC adapter or USB adapter and the camera won't charge the battery contact kodak support line 1 800 235 6325 (23KODAK) for possible repair.
Nov 16, 2009 | Kodak Easyshare V1233 12.1MP Digital...
JBL Media 100 Speaker power?
Buy a power adapter from radio shack or similar place. You need a 1000mA 12 volt dapter. Just make sure it is rated @ or above 1000mA to avoid the adapter heating up and possibly burning. The whole setup is rated @ 850mA wich 1A(1000mA) should handle with enough head room. But it might run you about $15-20. I would just buy a cheap radio with rca inputs/aux input and use that. I got one from Walmart for around $40 and it plays CD's & AM/FM.
Jun 09, 2009 | JBL Media 100 Computer Speakers
Will not jumpstart
To recharge this unit at home use the AC charging adapter. Plug one end of the adapter into the AC/DC charger input port. Which is marked as number 7 on the image below. Then plug the other end of the adapter into a standard wall outlet. The charging port is located on the front of your power center and looks like the image below. If you did not get an AC charging adapter with your power center check the manual to see exactly what type you need. You will need to know the Voltage and AMPs of the adapter. Go to Radio Shack or an electronics store and purchase an adapter. It is very important that you make sure you get the right one. Your manual should tell you how many hours it takes to completely charge your power center.
Mar 13, 2009 | Power Center Jumpstart 11-411
Need cable and power supply
Power Adapter Input AC 100-240V, 50-60Hz, Output DC 12V/4.0A
This may help. Just make sure you have the right dc output mentioned on the back of your monitor (12v4a or 12v5a) if any lower your monitor will shut off after displaying for few seconds then electrical smell will come out from your ac/dc adapter. When it overheats it shuts off.
http://www.alibaba.com/product-gs/51210391/TFT_AC_Adapter_for_12v_4a.html
Manual
http://www.princetongraphics.com/site/download/manuals/vl1716.pdf
Jun 14, 2008 | Princeton Digital VL1716 17" LCD Monitor
SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue Logo
441 people viewed this question
Top SimpleTech Computers & Internet Experts
Lyle Siemens
Lyle Siemens
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
