Question about Amana AER5725QA Electric Kitchen Range
Have never cleaned an oven using the self-cleaning feature. Need the procedure. Want to be safe!
    Genius:
  • 1,075 Answers
To be safe,just use a soapy detergent and a good little brush always use warm/hot water, as greese needs a little heat,not to hot as to burn you,you will find this will remove all greese,then dry with a clean cloth,turn oven to about 100deg c for 20 mins,and thats it.adrian,,,
Posted on Oct 15, 2010
RBS305 replaced thermal cutoff twice and again it won't come on bake or broil
Good Evening!
The self clean feature is causing your thermal fuses to fail or open. This is a safety mechanism that when open (bad) won't allow electricity to pass through any longer. The temperature in your oven exceeds what the components in your appliance can handle. If you want your oven to last it's longest, I would discontinue using that feature. If ever the control board or keypad on your oven by way of the self clean feature, we can help you with that. Fixyourboard.com can help. Send all inquiries to info@fixyourboard.com . Thank you!
Jun 05, 2017 | Whirlpool RBS305PD Electric Single Oven
Hi, is this oven self cleaning or can I use chemical cleaners to get the oven clean, especially around the fan? B x
Hi, W/D here.
Ovens just love for you to use the self cleaning feature on them. This gives them all kinds of excuses to lock up, fail components and have other components become "unpredictable". Self cleaning takes the oven to extremely high temperatures to incinerate the baking residue. This also uses a high amount of energy. My best advice is to clean the oven with the spray cleaner whenever possible, and to avoid the self cleaning feature altogether. Use normal precautions with the spray, following the directions on the can. This will do the job just as well, and takes much less time. Just make sure that the product that you use says "safe for self cleaning ovens", and you'll be fine.
Best regards, --W/D--
Feb 17, 2011 | Ovens
We had some butter drip on the bottom of the oven and a small fire started. Smothered it with flour to put it out now there is some flour and possibly butter that went through the slits in the bottom of...
I would just pull the oven all apart and clean it by hand...
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Sep 07, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a Kenmore Gas Oven, model # 911.30465864 and have lost the manual. I want to clean the oven, (it has self cleaning feature), but I am not sure if I can use oven cleaners in Gas Oven or not. Can...
Just use some easy off and do not use the self clean feature. Clean it the old fashioned way. Self clean ruins expensive electronics.
Feb 20, 2010 | Ovens
I lost the operator's manual for my Maytag electric range, model No. MERH752BAW. I need to know the procedures to use the self-cleaning oven feature.
I would not advise using the self clean feature. The extreme temps harm the electronic controls. Losing the manual might be a blessing.
Jan 19, 2010 | Kitchen Ranges
Advise use of self clean feature on kenmore self clean oven 30''
If there is an up and down arrow on the control panel, you need to press the clean button first and then choose clean time with the up and down arrow. Be sure to remove the racks, if left in the oven they will be blackened by the extreme heat. Clean them separately with oven cleaner. Place them on newspaper and spray them.
Dec 07, 2009 | Ovens
Need to activater self-clean
Every self-cleaning oven is different. It's best to consult the owner's manual for the correct procedure for your oven. But often the steps are:
  1. Set the Start time for the time you want the cleaning to begin.
  2. Set the Stop time to a time 2-3 hours after the start time.
  3. Close and latch the oven door.
  4. Set the selector switch and/or thermostat to "Clean."
Jan 09, 2009 | Farberware FAC900R Toaster Oven with...
Self cleaning MAytag Gemini GAS oven
A wonderful feature is that the ovens self-clean with the press of a few buttons. Only one oven can be programmed to self-clean at a time. Remove the oven racks. Turn off the oven light and close the door. Press the "Clean" button and then press "Auto Set" to automatically clean the oven for 3 hours. Press the "Auto Set" pad again to set the oven for a 4-hour clean cycle, or press the button one more time for a 2-hour cleaning. The oven locks when in cleaning mode. When the oven is finished cleaning, the word "Cleaned" will be displayed on the control panel, and the oven will remain locked until the oven has cooled, which takes about an hour. To cancel the self-clean cycle, just press the "Cancel" button. Simple!
Dec 28, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Amana AER5725QA Electric Kitchen Range Logo
48 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mike Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
