Question about Nintendo Super NES Console
When I turn on the system the game starts, but the screen is fuzzy and there is no sound. Any ideas?
  • Nintendo Master
  • 427 Answers
Make sure you are using only licensed accessories with your system.
We find that video problems occur most when an unlicensed RF switch is used. Make sure the name "Nintendo" is molded onto the RF switch, as opposed to "for use with Nintendo." Unlicensed products are not fully compatible with our systems and may not work correctly.
Check all of the system connections to verify that they are firm and correct.
For AV connections
Remove the AV cables and reinsert them with a slight twisting motion
For RF connections
Make sure the channel switch on the TV and system are set to the same channel (either CH3 or CH4)
Slide the Power Switch on the Control Deck to the OFF position. Remove the Game Pak and re-load it, pressing firmly to make sure it is locked in place.
Important Note: Removing the Game Pak with the power ON will cause the Game Pak image to freeze on the screen. Press Reset to correct the problem. Always turn your system OFF before inserting or removing Game Paks.
Slide the Power Switch on the Control Deck to the ON position.
If the above troubleshooting doesn't fix the problem, see below. Well try using av cables instead of an RCA switch then.
When I turn on the system the game starts, but the - 7_28_2013_12_38_17_am.jpg
Posted on Jul 28, 2013
My laptop makes loud beeping noise and screen comes up all fuzzy & crazy
sounds like hard drive is bad, replace with new or buy new computer
Jan 09, 2013 | Acer Aspire Computers & Internet
I am having ongoing problems with Samsung R519 laptop screen as it goes all fuzzy then goes normal then goes fuzzy again I have replaced the screen and screen cable and it still goes fuzzy then goes normal...
Have you updated the video driver in the laptop, there have been cases where the screen gives a variety of symptoms because the driver was outdated, if that fails! as crazy as this sounds do a fresh install of your operational system. I serviced a laptop with a flickering screen, I reloaded windows and got rid of the problem.
Apr 16, 2012 | Samsung R519-53S Notebook
Hi my problem is at first my xbox 360 went on fine then after 10 mins the screen started going fuzzy so i turned it off then back on was working fine for about half an hour then the screen started going...
If you hear sound but no picture then your graphic chip has got separated from your motherboard, this is not a simple fix. receommend you to look for a local repair shop that can handle game console repairs or send it to xbox.com
Thanks
www.1RepairStop.com
Sep 11, 2011 | Microsoft Xbox® 360 Core System Console
When we turn on our NES system, after about 20 sec...
If you are using an RF Switch, and notice the picture quality degrading (static or "snowy" picture), we recommend trying a different RF switch. For information on ordering a replacement, click here. If that doesn't solve the problem, your system will likely need to be replaced. Due to the age of the system and games, we can no longer offer factory repair. Please click here to find out what options might be available.
May 20, 2010 | Nintendo NES Console
Xbox 360 Blurry/Fuzzy Screen
The machine is overheating and the graphics chip on the main board is acting up cause of it. Make sure there is no dust or dirt blocking the air vents that would cause the system to heat up more then normal.
If that doesn't do it then maybe think about getting a cooler for the system, here is a website that talks about a few of them. Click here.
If that doesn't help then your mainboard is going bad and would need to be replaced.
May 29, 2009 | Microsoft Xbox 360 Console
When turning on the xbox the screen turns pink
OK did you ever try to hack your system did you open the inside of it did you drop or smash it or leave it in extreme temps if not it might be the result of poor cable connection,first turn off your Xbox 360 and check out the cables that are connected to the system. Remove them and re-connect them firmly. Now switch on your Xbox 360 again. There is a good possibility that you will find the fuzzy purple screen gone. If you still find a fuzzy purple screen then this might be a bit more complicated problem that your system is experiencing. Usually system overheating is one of the major reasons that cause various Xbox 360 errors
May 05, 2009 | Microsoft Xbox 360 Console
Fuzzy Screen Display
this sounds to me that water has leaked into the screen
Apr 11, 2009 | Nintendo DS Lite
Screen failure
sounds like ur xbox is about to go red light soon. It is fixable and i can list the steps for fixing it if u'd like. Kinda complicated, but ive fixed 30+ systems using the process
Jan 13, 2009 | Microsoft Xbox 360 Console
Game wont get past start-up screen
It could be your gameboy has something in it. One time I got a dog hair in my gameboy and it wouldn't load anything. If that's not it, try removing the game and putting it back in while checking each time if the nintendo logo is fuzzy. Some of my older gameboy games require me to keep removing the game and pushing it back in over and over until it establishes a strong connection.
Jan 04, 2008 | Nintendo Game Boy Color Console
Nintendo Super NES Console Logo
121 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
