Question about Kodak EasyShare C142 Digital Camera
Kodak easyshare c13 does not turn on when I push the on/off button. I have new batteries in correctly. It turned on once. But it is not turning on now. I refuse to pay $6 for immediate assistance.
robmcd27
  • 423 Answers
SOURCE: The Lens Stuck in extended position on my kodak easyshare v-550
Hi there, welcome to FixYa.
L-83 is a type of lens error. There are a few different types of errors with causes ranging from a broken gears (they're plastic), to sand or dirt getting in the gears preventing them from turning. So, here are a couple things you can do to fix this yourself before turning it in to shop for repair.
1) Get an air compressor and put the nozzle up to the space between the lens and the body of the camera and blow it out real good. Then turn the camera over (lens down) and tap the lens on a hard surface. You may have to do this a couple of times.
2) Press the power button on the camera, and while it's flashing it's lights, bang the side of the camera on the palm of your hand a couple of times. That may free the gear up.
If it's not something blocking the gears from turning, then it could be that the guide pins on the lens may be out of their tracks. If this happens, then the lens will not move at all.
Press the power button and grab the lens, give it a tug and a twist. Don't be afraid of it, you want to manuever those pins back into their tracks. You should hear a click when they fall back into place. If you hear the click, then stop pulling on it. Power it off and back on to see if the lens retracts.
If these three suggestions won't work for you, then you should turn it in for repair. Perhaps the teeth on the gears are getting stripped off, and it's pieces of the gear themselves that's getting trapped in the other gears.
Hope this helps you. Thanks for coming to FixYa.
Rob
Posted on Mar 14, 2009
SOURCE: Kodak Easyshare camera turns on and off
Hi, here is whats going on, if your M763 is powering on for 2 secs and the lense opens up then go's right back in, there is a 90% chance you got sand in the unit from say the beach ?
here is a test , when you press the power buttion watch the lense you will notice that the bigger part rotates as it comes out, what you want to do is give it a little help Lightly rotate it abit more just at the point where it normaly stops and go's back in, the cam will prob stay on and work like normal.
now the hard part 2 things to try, a can of AIR from walmarts try to blow out and sand thats around the rings, i did this and have fixed about 20 of these's now, on the others you will need to take it apart and clean the gears and mech of the lense housing then put it all back together.
hope this helps
IST tech
Chris
Posted on May 26, 2009
pumpkinman
  • 1147 Answers
SOURCE: My M863 Kodak Easyshare camera turns right off.
sounds like a power issue.maybe your batterysare no longer taking full charges
Posted on Jun 29, 2009
SOURCE: Camera turns on but immediately turns off.
battery is dying---not worn out but you'll need to buy a NEW battery. They it'll work again.
Posted on Jul 26, 2009
  • 8 Answers
SOURCE: My Kodak Easyshare M1063 won't turn on
Try cleaning the contacts from the battery and the battery compartment of the camera. I had the same problem and this fixed it, it seems to be a common problem.
Posted on Aug 15, 2009
Cara memperbaiki kamera kodak easyshare m883 yang mati sendiri
check battery of the camera if is okay unless you have a damaged battery, or the push button swich if stuck or damaged.
Jul 01, 2016 | Kodak Easyshare M883 8.0 Mp Digital Camera...
Tip
Kodak EasyShare Z740 Turns Off Fix Does your Kodak EasyShare Z740 Turns On...
Does your Kodak EasyShare Z740 Turns On Then Turns Off right away?
Does your Kodak EasyShare Z740 Turns Itself Off with new AA batteries in it?
Many of these Kodak EasyShare Z740 cameras that shuts off right away and will not stay on, will actually stay on if you select FAVORITES to view pictures, but just flash back and turn off if set to auto or camera mode. Try this.
If the lens cannot extend, the camera will turn itself off. You can try giving the camera a thump with the heel of your hand, but I would recommend servicing the camera rather than smashing a delicate digital instrument. After trying the steps below, a last chance alternative that works for some people is to grab and actually PULL the lens out as it tries to extend itself. Again, its delicate; if you can afford it, maybe pay for servicing before hitting and pulling on your camera.
However, before servicing your Kodak Z740 try this fix:
  1. Hold down the Time/Ascending Folder button (the button under OK on the circular panel)
  2. While holding that down, press and hold the ON/OFF button.
  3. The camera may turn itself on and stay on this time, acting normally again.
If this doesn't work for your try this:
  1. Hold down the '>' button (the one that brings you to picture review)
If that doesn' t work, try again with the 'Trashcan' button, and ON/OFF button.
I hope that helps.
____________________________________
Kodak EasyShare Z740 Manual Download
on May 01, 2010 | Kodak EasyShare Z740 Digital Camera
My z740 camera will not stay on
I may be able to help with your Kodak EasyShare Z740 that turns itself off.
It may be a 'lens extending' problem, or it might be fixed with a combination of button presses to reset it while turning it on.
Try these steps to fix your camera.
I hope that helps.
_____________________________________________
Mar 19, 2010 | Kodak EasyShare Z740 Digital Camera
Won't recognize the memory card. I have tried several and get the same message.
Hello. Double check to be sure that the memory card is correct for your camera. Also check to be sure that you are installing it correctly. Once you are sure, turn on the camera and go into the menu to find the reset button. push it. Finally go into the menu again and find the format button and push that.
Regards, Joe
PS - kindly rate my answer. thank you.
Feb 04, 2010 | Kodak EasyShare P712 Digital Camera
My camera will not turn on at all and have put in new batteries
I hope that helps.
Dec 28, 2009 | Kodak EasyShare Z740 Digital Camera
My Kodak Easyshare M7623 Digital camera will not come on. It is completely charged and the lens is out. When i push the ON/OFF button the screen comes on and quickly goes of. The lens remains out the...
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
If issue persists, call 1.800.235.6325 for repair.
Thanks.
Neerak21
Sep 20, 2009 | Kodak EASYSHARE M763 Digital Camera
My camera all of a sudden attempts to come on and then cuts off.
I hope that helps.
Mar 30, 2009 | Kodak EasyShare Z740 Digital Camera
Kodak easyshare Z740
I hope that helps.
Nov 05, 2008 | Kodak EasyShare Z740 Digital Camera
Won't turn on after changing batteries
I hope that helps.
Feb 29, 2008 | Kodak EasyShare Z740 Digital Camera
Kodak EasyShare C142 Digital Camera Logo
138 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
