Question about Vacuums
Juki LS341N sewing machine manual - Vacuums
3 Suggested Answers
  • 1739 Answers
SOURCE: where can I get a
Not sure if this is the complete manual but only site where I could find it available for free:
http://www.free-service-manuals.com/Sewing_Machines/Juki_DDL_227_Basic_Repairs_&_Adjustments_L98742/
Click on Download/Visit to receive the manual in zip format.
Posted on Mar 27, 2011
  • 586 Answers
SOURCE: I have a acquried a
Hello there,
Theres a number of causes of such problems. You will simply just have to run a check on some of the components below:
If it is the upper thread that is breaking, check Rethread your machine. An incorrectly threaded machine can cause thread to break.
Decrease the tension on your machine. The tension may be too tight for your thread.
Reposition the spool of thread on the spindle. You know that little nick in the edge of a spool that's used to hold the loose end of the thread? Your thread may be catching on this nick as you sew. Place your spool so that this nick rests against the bottom of the spindle.
Reinsert your needle. Make sure it goes all the way into the holder and that it's positioned correctly, usually with the flat side away from the bobbin, but consult your machine's manual to be sure.
Change your needle. Your needle may be bent or dull. The eye of your needle may have a nick in it that's cutting the thread as you sew. Or the eye of your needle may be too small for your thread, in which case, change to a larger needle. And make sure your needle is appropriate for the weight and type of your fabric.
Change your thread. Your thread may be weak. Or your thread may be fuzzy and irregular, causing it to catch in the eye of your needle as you sew. Cheap thread tends to be weak and fuzzy, so make sure to use a quality, brand name thread. And if you've been sewing with an older cotton thread, which can dry out and become brittle with age, try a newer thread.
Check your presser foot for damage to the needle hole.A burr in your presser foot's needle hole may be cutting your thread. Gently smooth any rough spot you find with an emery cloth.
Also, There may be a burr in one of your thread guides, in which case, you may need to have your machine professionally serviced to have the part replaced.
If your lower thread is breaking: Reinsert your bobbin. Your bobbin may not be seated properly in its case.
Rethread your bobbin. Your bobbin may be threaded incorrectly or the thread may be tangled.
Remove some of the thread from your bobbin. If your bobbin is very full (if it's hard to insert into the case, it's too full), this may be keeping your bobbin from turning smoothly.
Rewind your bobbin thread. If your bobbin thread is wound unevenly, this may be keeping your bobbin from turning smoothly.
Try a new bobbin. There could be a nick along the edge of your bobbin spool that's catching your thread as you sew.
Clean the lint from your bobbin case.Lint in your bobbin case could be keeping your bobbin from working properly.
Check the needle hole in your throat plate for rough spots. A burr in the needle hole of your throat plate (usually caused by the needle hitting the throat plate) could be cutting your thread. Gently smooth any rough spot you find with an emery cloth.
Hope this helped. Goodluck Elect_Comp
Posted on Aug 31, 2011
Need a manual for my singer sewing machine it is a singer genie 353 or 354
HI......................
Singer 353 and 354 sewing machine service manual.
Note* This is a service manual. If you need the instruction manual or the great little trouble shooting and adjusters manual, we also carry both in our store.
Service manual includes:
* Bobbin winder
* Rotating hook
* Motor and electrics
* Needle bar
* Presser bar
* Much more
THE MANUAL LINK IS GIVEN BELOW.............
http://sewingmanuals.blogspot.com/2011/04/singer-genie-353-354-sewing-machine.html
GOOD LUCK..................
Sep 22, 2011 | Vacuums
How to get Brother sewing machine apart to replace spool spindle.
To be honest the best thingon such instructions is the manual which is provided along with the machines,but many people don't have it , probably because they have lost the manual orthey have got the machine as a used one and forgot to take the manual alongwith it.
Please follow the belowinstructions :-
Close to the end of theHandwheel , there is usually a spindle, at the back of the machine.
This is where you need to restthe spool on and you would notice it sitting perfectly.
In case the length of the spindleis less , then pull it up gently with your fingers.
Also there are machines these dayswhich have easy to replace facilities , so the spindles just slide intothe machine for safety norms when you put the machine away.
Therefore , all you need to do it pullit up and it would be fine.
An example of a manual forbrother's sewing machine can be found in the below link which would give you anidea of how exactly it's done.
http://bit.ly/j2BdsP
Hope this helps ..:)
Jun 11, 2011 | Vacuums
Hi there. i am looking for the manual for the juki HZL F300. I lost mine and cant figure out how to get a zigzag stretch stitch to work
I could only find this, but there may be others.
Details: Juki HZL-F300 Sewing Machine Instruction Manual - Photocopied Version
http://www.sewingpartsonline.com/juki-hzl-f300-manual.aspx
May 27, 2011 | Vacuums
Where can i get an owners manual for a mf-860 juki machine
A good and easy to use site for finding this manual is, www.sewingmachinemanual.net. The site makes the manual available in PDF format for download as well as a PDF formatted CD to order. Hope this helps.
May 07, 2011 | Vacuums
Where can I get a free manual for a Tokyo Juki Industrial Sewing Machine # DDL-227?
Mar 27, 2011 | Vacuums
What bobbin do I use in a Juki DDL 8300
Hi there.
Nice machine... Here is a link to all the parts for your Juki DDL 8300
http://www.juki.co.jp/industrial_e/webparts_e/partslist2.html
Your bobbin's Juki part number is B9117-051-000
Mar 11, 2011 | Vacuums
Vacuums Logo
88 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
