Question about Roper RS22AQXKQ Side by Side Refrigerator
Icemaker stopped working. There is water to the refrigerator (is water to drink) but does not fill icemaker. Thanks, Gene
I changed the water inlet valve on the fridge. It still doesnt send water to the ice maker, but continues to send water to the door, so what do i do now?
Posted on Oct 19, 2010
My side by side refrigerator is making a buzzing noise from the ice maker area every few minutes
That sound you here is the icemaker calling for water to fill the icemaker but not water into refrig to fill icemaker. If you have no water connected to icemaker,lift up and lock arm into place to turn off icemaker,if you do have water line connected but no ice is being made need to see why water from house plumbing is not coming into the refrig.
Gene
Aug 11, 2011 | Frigidaire Refrigerators
Replaced water filter on my Frigedaire refrigerator and it is leaking where the filter is it is making ice when the bar is raised for no more ice it does not lead but when the bar is down to make ice is...
The problem there is going to be one of 2 related causes.
The tube in the back of the icemaker where the water enters it is partially frozen and when the water comes into the icemaker some of it is spraying into the bin instead of filling into the icemaker.Remove the icemaker and check and thaw that tube.
That tube is out of place so once again instead of water filling into icemaker correctly some of it is running into ice bucket instead of icemaker.
Gene
Aug 11, 2011 | Frigidaire FRS3R5EMB Side by Side...
Icemaker quit making ice .. water supply to drinking water still working ..switch is on the on position
check the fill tube that brings water into icemaker..these sometimes freeze over..if it is, defrost and order new fill valve....or, you have a fill valve thats bad..
Jan 11, 2011 | KitchenAid Refrigerators
Icemaker inlet tube frozen. No water to icemaker. drinking water dispensor works fine.
If the tube is located behind the icemaker and to the left in the freezer simply either take a blow dryer to it or if you can remove the fill tube manually i would. This happens because your valve is leaking back alittle and if it reoccurs you'll need to replace the valve. Just thaw the fill tube and you'll start working again.
Feb 09, 2010 | KitchenAid Refrigerators
Ice maker stopped working
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig .
Sep 05, 2009 | KitchenAid KSRP25FNSS Side by Side...
Water to dispenserbut no water to ice maker
There is a separate valve that controls the water flow into the icemaker and its exact location may be different from one fridge to another. The valve is electrically controlled by a switch that senses the start of a fill cycle and that switch can also fail. Our icemakers generate close to 98% of all refrigerator failures according to the leading consumer magazine.
Apr 11, 2009 | Kenmore 53642 / 53644 Side by Side...
Not making ice
There is usually a wire like piece that needs to be in proper position for water valve to flow, have you checked owners manual?
Oct 18, 2008 | Whirlpool GD2SHGX Refrigerator
Icemaker won't fill with water
If you would like a repair manual for your refrigerator, you can get one here. These are helpful to have in case you have other issues with the fridge.
Thanks
Sep 29, 2008 | Samsung RS2630WW Side by Side Refrigerator
Ice maker
verify the water supply to the valve first, second verify valve to icemaker works(unit has dual valve at rear bottom of fridge, switch plugs, then press water dispenser and see if icemaker fill with water ) if fills icemaker is bad , if not valve is bad. replace one or the other.
Mar 28, 2008 | Refrigerators
Roper RS22AQXKQ Side by Side Refrigerator Logo
85 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
