Question about GE Televison & Video
Have Ge model 52GW945 tv, it went blank no picture, nothing, I checked fuse its ok what next
    Top Expert:
  • GE Master
  • 75,471 Answers
Check the swithed mode power supply section. Some sets uses Ics for control the power regulation, while others uses transistors as oscillators and choppers. If the power to the oscillator section of the SMPS is absent, the supply system won't wake up. So many reasons are there. You just check the resistor, usually connected from main DC rectified supply, to energise the oscillator section of the SMPS. In most sets it may be two resistors in serial, usually 270k 1W*2. If any one of this get opened, the power supply will not start up. Check it first and preceed. If the set uses Ic as regulator controller, check the positive supply voltage at the respective pin of the Ic.
Posted on Oct 15, 2010
I plugged in a computer and changed the input to VGA and the TV went blank
It sounds like your tv is in sleep mode.
What are the settings for the computer? Make sure it is set for the vga output. If it is a laptop, this is usually done with a function (FN) key. On your settings screen you can set the resolution and which monitor you are using.
Sep 29, 2012 | Polaroid 2611-TLXB TV
GE TV MODEL #52GW945---WONT TURN ON
Have someone check to see if the Horizontal output transistor is shorted==that and the high voltage transformer were common failure parts in this model
May 23, 2012 | GE 46GW945 46" Rear Projection Television
I have a GE model 52GW945 . It went blank, no sound, no video just dead
First thing to check is the cable that is connecting the television to the main power source, then you check the power panel. If it is not faulty, then the problem is that there is a burnt capacitor inside the unit, mainly on the main board of the television.
Run a check on the main board for burnt capacitors and replace them, after doing that, your television should be in good condition once again.
Take care and good luck
Oct 15, 2010 | GE Televison & Video
I have a GE TV model: 27GT271 and no sound
Possible cause of the problrm is bad/poor solder on the grounds for the tuner circuit shield an the bottom (solder side) of the circuit board. Grounds need a wire jumper from point to point. This was a common problem for those sets and ocassionally it would take out the eeprom chip with it. (Various other problems were shrinking picture/fuzzy picture and intermitt. power)
May 14, 2009 | GE 27GT271 TV
Not working
next thing you would want to do is check the stereos fuse then check your wiring yellow red and black.
May 06, 2009 | Car Audio & Video
TV wont come on
Try changing the fuse located inside your tv cabinet.
good luck---------------tomtaso
Dec 01, 2007 | Televison & Video
Power button Flashes
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
Jul 18, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Tv went off.
i have the exact same problem except with a different tv model.and i cant get help.
Jun 01, 2007 | GE 19GT357 19" TV
Televison & Video Logo
140 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
