Question about Zenith C27V22 27" TV
Screen intermittently goes black for about 15 minutes. sound continues with all other functions ok.
    Top Expert:
  • Zenith Master
  • 75,320 Answers
Your TV has some loose contact in the circuit board. Usually it occurs on the soldering of picture tube base board. After long use the soldered contact will get loose sometimes. This fault cannot be detected by normal multimeter test. The only remedy is to resolder all the suspected soldering points. You just call a tecnician for support. You can assure it whether this is the problem or not; by make a small hit my hand on the side or top of the TV set while the screen goes off. Never hit it with any hard material. Only use your palm.
Posted on Oct 15, 2010
Lc-60le835u screen going black,turned off for minute,turn back on okay for 15 minutes then screen goes black again, now screen is always black the sound is ok,need 2 know what it is I need to replace?
I would only guess on this without testing it and having a repair guide, but the PCB that controls the screen display is called the "T-Con" PCB
Nov 04, 2016 | Sharp Lc-60le835u Led Tv
On idle machine -- power and field lights are lit, relay is NOT (relay board)
With everything that you have tested and the relay board testing okay, this sounds like the console is the problem.
Jan 02, 2014 | Stairmaster Stepmill 7000 Pt
I have a Vizio SV470XVT1a. When I turn the tv on I may get a normal picture for a minute or two then the screen goes black or I will have a greenish or pinkish screen. I continue to have sound. Afte
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jun 10, 2017 | Vizio SV470XVT 47 in. LCD TV
Screen goes black on toshiba tv how to fix
I would check to see if any capacitors have gone bad or are going bad.
Oct 07, 2012 | Toshiba 32A60 32" TV
My tv has sound but the screen is black. At times
Ur LCD inverter board is dead.Must replaced the board.Usally a long board.
Jan 05, 2010 | Olevia LT27HVX 27 in. LCD Television
Screen goes black after about 10 minutes...POLAROID TLX-04240B
Simple Fix Repaire the backlight
repair man sure www.teexp.com
dont shoot the messanger!
Jun 13, 2009 | Insignia 42" LCD Flat-Panel HDTV
Pls more info; what do you mean tv on, picture froze? you are watching on tv chanel, do you use cable? I can help you but need more details.
Aug 29, 2007 | JVC AV-32D305 32" TV
TV screen went black, sound OK
check cold solder vertical circuit
Nov 21, 2006 | JVC AV-27530 27" TV
No Picture after it's been on a while. Audio OK.
ok you have a vert sweep problem and yes its probably connected to in a way to the "tap and fix" problem! Seems to be n intermittant connection on the vertical out put Ic or maybe even on the rgb convergence ic?? The total loss of sweep though tells me that theres two differant problems! Maybe and intemittant connection on the vert output Ic as well as bad connections on the convergence ic??.
Apr 16, 2006 | Mitsubishi VS-5043 50" Rear Projection...
Zenith C27V22 27" TV Logo
63 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
