Question about Raritan Boating
Re assemble a vortec v6 marine engine. looking for repair manual
Check on iboats.com I even found an antique boat motor repair manual. Good web-site.
Posted on Oct 15, 2010
Testimonial: "Thank you! :)"
Location or diagram Oil sending unit 98 isuzu hombre
what engine, THE CAR IS A GM s10 IN DRAG.
4.3L v6 Vortec 4300, GM
2.2l i-4, OHV ENGINE. NOT ISUZU!!!
In 1996, Isuzu replaced its Pick Up with a version of the Louisiana-built Chevrolet S-10, the Isuzu Hombre, based on the Brazilian market S-10
so google the vortec 4300
here Ill type for you....
on most v6, its near the oil gallery , on a bank.
so that means if youd look on both banks , the one with the 1 wire sensor is it.
but not this v6
its here.
log in to mitchell's and read, its all there.
Nov 22, 2016 | 1998 Isuzu Hombre
A sucking noise by the carbuerators on a 2000 100hp yamaha outboard
Are any vacuum lines missing or broken cracked etc? Are all unused vacuum ports capped?
Jun 24, 2016 | Seloc Yamaha Mercury Mariner Outboards...
How to replace the water pump impeller
If you have no idea , best take it to a repair shop and have it done .I worked on motors for 20 years and many times people brought them to me after they messed it up .
May 11, 2016 | Seloc Yamaha Mercury Mariner Outboards...
How to unlock a chevy 4 .3 motor
GM ( Chevrolet or GMC ) 4.3 L V6 Engine Tear Down ...
? 3:39
https://www.youtube.com/watch?v=-gkxF7wKIdk
Feb 1, 2013 - Uploaded by AutoEclinic
This video goes through the teardown process of a GM 4.3L V6. It has been removed from the vehicle and we ...
4.3L Vortec V6 Throttle Body Blade Mod - YouTube
? 13:54
https://www.youtube.com/watch?v=okEDVwlEHvM
Mar 21, 2012 - Uploaded by EricTehRedneck
4.3L/5.7L Vortec V6/V8 ' Throttle Body Blade Mod ' 262/350ci ... bottom of the blade to increase airflow into the ...
How To Clean Your Vortec 4.3L V6 Throttle Body - YouTube
? 11:21
https://www.youtube.com/watch?v=q8I67-GwXhM
Dec 09, 2015 | Cars & Trucks
How do I remove and re install the CPI unit and gaskets on a 1998 Chevy Blazer with Vortec V6
You have to reove the upper plenum. that is the part on top of the intake that looks like a dome on top of the lower intake.There is 8 10mm bolts around the outside of the dome part. the disconnect the fuel lines at back of lower intake and remove the cpi unit.
Sep 12, 2014 | 1998 Chevrolet Blazer
The manual tilt is locked in the up position, have been unable to lower the motor from a trailering position.
lift the engine to release weight !if siezed heat up and grease the joint till free !
Sep 04, 2013 | Seloc Marine Repair Manual...
Gday,i have picked up a 14ft boat with a Mariner outboard 60HP 2cyl but theres no compiance tag or numbers to show exactly how old it is,the wireing is there but nothing is connected to starter switch...
Mariner Trigger Assemblies
60 3 1984-1990 6428681-D000749 68162A 3, 68162A 3, 68162A 6, 96455A 1, 96455A 8 134-6453 18-5797 60 3 1991-1997 D000750-OG589999 99021A 3, 99021A 5, 99021A 8, 99021A13, 99021A15, 99021A16 134-9021-3 out of stock - 65 3 1976-1979 4382057-4571651 68162A 3, 68162A 3, 68162A 6, 96455A 1, 96455A 8 134-6453 18-5797iboats.com
You can look at your parts and determine your serial number and year.
Direct link to the page
http://www.iboats.com/Mariner-Outboard-Electrical-Parts/dm/cart_id.556536444--session_id.729929016--view_id.268684
Mar 22, 2010 | Intex Mariner 400 4 Persons Boat Raft Set
93' chevy 4.3 V6 vortec. engine problem
fuel lines inside the intake plhenum may be cracked and leaking inside the plhenum. same thing happened to my 1992.sonoma. they are made of a plastic material and tend to crack right in the bend of these lines.
Mar 18, 2010 | Chevrolet S 10 Cars & Trucks
1992 vortec v6 motor getting spark and strong fuel pressure to motor but wont start, crank sensor is good ,motor tries to start when fuel poured into throttle body
the probem is probably in the injector assembly whichis under the intake plenum.after removing it you will se the plastic tubes and ijector popit valves unlike actual individual injectors.this whole contraption must be replaced as an assembly.you can get repair manuals from this site or go to you library.it may actually be flooding as these had problems with leaking fuel pressure regulators which i think are also only part of the whole assembly.
Feb 14, 2010 | 1992 Chevrolet S-10 Blazer
Fluid specifications and quantities for 99 silverado
You did not give your engine size or other information, but here is a list from the handbook...
Cooling System Capacity (Approximate)
VORTEC
4300 V6
Automatic 12.6 quarts (11.9 L)
VORTEC
4300 V6
Manual 12.9 quarts (12.2 L)
VORTEC
4800 V8
Automatic 13.4 quarts (12.7 L)
VORTEC
4800 V8
Manual 13.7 quarts (13 L)
VORTEC
5300 V8
VORTEC
5300 V8**
Automatic 14.9 quarts (14.1 L)
VORTEC
6000 V8
Automatic 14.8 quarts (14 L)
VORTEC
6000 V8*
Automatic 14.4 quarts (13.6 L)
VORTEC
6000 V8
Manual 15.2 quarts (14.4 L)
VORTEC
6000 V8*
Manual 14.8 quarts (14 L)
VORTEC
5300 V8**
VORTEC
6000 V8
VORTEC
6000 V8*
VORTEC
6000 V8
VORTEC
6000 V8*
Crankcase Capacity (Approximate)
VORTEC
4300 V6
W 4.5 quarts (4.3 L)
VORTEC
4800 V8
V 6.0 quarts (5.7 L)
VORTEC
5300 V8
T 6.0 quarts (5.7 L)
VORTEC
6000 V8
U 6.0 quarts (5.7 L)
Fuel Tank Capacity (Approximate)
Short Bed 26 gallons (98 L)
Long Bed 34 gallons (128 L)
Chassis Cab 34 gallons (128 L)
Apr 03, 2009 | 1999 Chevrolet Silverado 1500
Boating Logo
248 people viewed this question
Top Raritan Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Raritan Boating Expert? Answer questions, earn points and help others
