Question about Cell Phones
Nokia 9300i Security Code problem
I am Using 9300i Phone and suddenly it got locked, i tried to open it by pressing 12345,still it is not opened can any body help me please
  • sarfaraj_now May 17, 2009
    my nokia 9300i, encidentaly i forget my security code.
    which code i use that code is not access. my friend input nother code and unfortunately he forget it. so please help me to get rid of this problem as soon as posible.
  • 749 Answers
The security for these phones are strong... you needed to go to a cellphone repair shop and they will hack through it or assign a new lock code for you... good luck...
Hope this helps.... ;)
Posted on Sep 01, 2008
Nokia 6280 needs restriction code
Try the soft reset and see if that solves whatever issues it is you have. Using the dialing keypad type in *#7370# and then inter your lock code (default is 12345).
May 05, 2014 | Nokia (BP6M) 3250 6280 6282 6288 6233 6151...
Phone lock open code
try this *#7328748263373738# it will return it to the original code(12345)
Jul 09, 2013 | Nokia 1280 Cell Phone
Have you tried the default unlock code?Still, if you are unable to open the security lock you can master reset the phone for free using the free generated code for your Nokia 1110 from Unlock-free.com and reset the security lock.
May 11, 2013 | Nokia 1110 Cellular Phone
Have not use my nokia 1600 for quite a while but recently needed to use it but it suddenly asked for Security Code. Tried 12345 but got code error. My phone's IMEI:356413014173749. Please help
If the Mobile Nokia 1600 shows Security code error,please call the service provider and use the Default code they will give it for You!!!
You can try using 0000 also that is also Default code,if not open from security Code lock means get the master reset code from
Mobile-Unlocker and reset it...
May 31, 2011 | Nokia 1600 Cellular Phone
FORGOT MY NOKIA 3120C-1C SECURITY CODE
If you forget the security code, please try nokia master reset code : 12345. If it fails , just get the code by key in your IMEI number at :
www.nfader.su
or
www.nokialockcode.com/calculate.php
Regards, Jay
Feb 24, 2011 | Nokia 3120 Classic Cell Phone
I want your phone locker?
You can set up a security code to lock your Nokia 6288 keypad in case a thief tries to call from your stolen phone
Published on Mar 14, 2007
You can set up a security code to lock your Nokia 6280's keypad in case your phone opens in your pocket and calls one of your contacts, annoying them and potentially running up a huge bill.
The code will also stop a thief from using your stolen Nokia 6280 to run up a huge phone bill before you can alert your network provider.
To set the security code, click Menu > Settings > Phone > Security keyguard. You'll be prompted for the Security code. By default this is 12345. Enter this and press OK. Select On and click Select to see the message 'Security keyguard activated'.
Now when you slide your phone shut and press Lock, you'll see the message 'Keypad locked with security code'.
When you slide it open, you'll be prompted to enter the security code. Type your code and click OK to activate your keypad.
Of course, if any potential phone thieves are reading this, they'll now know the default security code is 12345.
To change the security code, go to Menu > Settings > Security > Access codes > Change security code. When prompted, enter your current security code and click OK. The enter your new security code (a PIN between 5 and 10 digits in length), click OK and enter the new code again to verify it. Click OK and you'll see the message 'Security code changed'.
Hope this helps.
Jan 12, 2011 | Nokia Lands Phones
6303 security code
go to google website type n search nokia unlok codes.. then type nokia unlock codes when ask password in ur mobile... when u entered unlock codes it will show only code error then u type 12345 it will accepted...
Aug 31, 2009 | Nokia 6303 Cell Phone
Wep key data of nokia 9300i
Hi..
Let me help you out..
You have to enter WEP key which you used for computer synchronization.
Let me know the Router Model you are using..
follow this steps:
Option:1 - If setup with Bluetooth or Router with Mobile.
Just enter 12345
if it promts again in the computer there also enter 12345. use same key in all places when it prompts.
Option:2
If the setup as Router computer and Cellphone.
1.Open Router Configuration page by accessing default IP address mentioned on the router.
2.Go to Security or WEP tab. disable WEP.
or set WEP key
3.now enter the same Key for your nokia 9300i.
Feb 17, 2009 | Nokia 9300i Cellular Phone
Nokia e71 lock code
press the keey on the left side of shift key. it will change the entry into num mode. press 112 and press dial button (green phone button). It will show connecting press end call button. Now the set should be in normal mode.
Nov 18, 2008 | Nokia E71 Smartphone
Forgotten code
i forgot my keypad security code. my mobile set is nokia 6233. please help me. is it possible to unlock or reset without formating or deleting my phone memory.?... please please help me.....
Aug 16, 2008 | Nokia 6233 Cellular Phone
Cell Phones Logo
126 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
