Question about Casio Exilim EX-Z750 Digital Camera
I have a Casio Watch module #1189. It is a digital alarm chronograph. The battery went dead while sitting in a drawer for many months -maybe a couple years! So I replaced it with the same battery #CR2016. Now it still has no display. I double-checked the polarity and it is correct. I took the battery out and then replaced it several times. I checked the battery with a voltmeter -it reads 3V. The watch is clean inside, with no sign of corrosion like from a leaking battery, etc. The old battery showed no sign of leaking or corrosion. Is there a reset switch like to push a paper clip into to reset the watch? Your thoughts, please. Thanks in advance. Bob in Michigan.
SOURCE: Casio spf 40 Module 2273
Your Watch is in Auto or demo mode. Hold down the "Mode" button for 3 - 5 seconds and it will return to time keeping mode.
Cheers,
Murray
Posted on Dec 29, 2007
SOURCE: casio camera help! will not switch on or charge!
Check this topic:
http://www.fixya.com/support/t207895-battery_charger
Posted on Mar 10, 2008
upajos
  • 24 Answers
SOURCE: please help me to replace battery on my casio F-91W
This reset trick works with other Casio Alarm Chrono digital watches, such as my old Model W-720, similar to your F91-W. After the new lithium coil cell is installed and secured with the spring clip, the watch may show random segments in the LCD display or may simply be blank. Insert a sewing needle, paper clip, or blade of a small jeweler's screwdriver into the hole on the back of the movement stamped "AC" (All Clear) to momentarily connect the gold plated contact at the bottom of the hole to the stainless steel battery clip. The battery clip in most such Casio watches is connected to the "+" terminal of the coin cell. This will reset the CMOS chip and it should start up with the watch displaying 12:00 and the date at 1-1. Then, use the control buttons to set the time and date in the normal fashion.
Posted on Oct 29, 2008
SOURCE: Casio Exilim EX-S600 time and date entry at every startup
I'm not sure how many of you are from Canada and I'm not sure how the Casio warranty repair centers are in other parts of the world, but I sent my 3+ year old EX-S600 (purchased Jan 2nd '06) in to Casio Canada's repair center near Toronto, Ontario, and I received it back within 7 days fully repaired. It appears they through a factory v1.00 firmware on there and perhaps did a memory wipe or something (thats just what I noticed, they couldn't give me any more details). I upgraded back to v1.02 to get SDHC support for 8GB/16GB SD cards and so far so good, no problems anymore, settings are saved whenever I power off/on the camera. There was no charge for the repairs, and chances are this is because it required to replacement parts (the person on the phone that I spoke to before sending the camera in said that if there were no parts required that it would likely be free). So its worth a call to your local Casio repair center to see if you can get yours repaired even if its out of warranty as it should be an easy fix for them and cost both them and you the price of S/H, nothing more (in my case just $7 Canadian).
I hope this helps!
Posted on Jan 21, 2009
SOURCE: casio np 20 not charging camera ex z8
I sent an e-mail to Casio and they are deciding whether or not I qualify for a replacement battery thanks for your e-mail
Posted on Mar 27, 2009
Can't reset from military time to regulary time and have lost instructions.
Hi,you Here it is ,for the soft version of the user manual pls visit the URL below..
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
CASIO Watch User Manual Archives
http://world.casio.com/wat/download/en/manual/
Use this page to download a copy of CASIO watch manuals in PDF format.
To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
Jun 28, 2011 | Casio DW290 1V Classic Alarm Chronograph...
I have a casio alarm chrono watch that beeps on the hour and I want it to stop. I have searched for a user's manual and could not find one. Can you help?
Hi,bingo..here it is..For a soft version of the user manual pls visit the URL below..
Thanks
Apr 26, 2011 | Casio DW290 1V Classic Alarm Chronograph...
Screen went dead, watch is 3 months old
This is a case the watch should returned to the place of purchase, the battery is bad, or the timing module has failed, there is nothing that can be done but return it and let them deal with it.
Mar 19, 2011 | Casio G-Shock G2600 watch
How do set every hour beep sound for alarm chrono 165ft
you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Sep 21, 2010 | Casio Analog Digital Chronograph Alarm...
On the casio a158w how do I turn off the hourly chime? Thank-you
Hi Ms. Sophie Desro,
If the alarm has sounded, press "A" (top left-hand button) to stop the sound.
To switch the Daily and Hourly Time Signal on and off:
Press "C" (lower right-hand button) while in alarm mode in sequence:
a. }}}} + BELL = Both alarms on.
b. Display Blank = Both OFF.
c. }}}} = Daily alarm on only.
d. BELL = Hourly Time Signal on only.
Test the alarm by holding down "C" to sound the alarm.
Please note b. and c. to turn off the alarms.
For more information, Casio has an Operational Chart for your watch, Module QW-1275. You may download a PDF file here:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw1275.pdf
Try this and let me know if this works. Thanks.
Regards, Bill
Sep 16, 2010 | Casio DW290 1V Classic Alarm Chronograph...
How do you set the time and date on a casio digital alarm chronograph 1155 WN-10 watch?
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please.
Mar 05, 2010 | Casio Watches
I have a casio a158w alarm chrono, the screen went blank, opening up the back, is the battery the big round thing in the middle that seems to be stuck in place??? it takes up most of the inner works of the...
Yes, the big, round thing in the middle is the battery. To get it out you need to unclip or unscrew the contact covering it. When the contact is off you will see the battery number written on battery - buy exactly the same one and replace. After replacement you will need to set the watch manually.
Jul 09, 2009 | Casio DW290 1V Classic Alarm Chronograph...
Change Time in Giordano digital Chronograph watch #1143
KEEP YOUR FINGER ON THE BOTTOM LEFT HAND BUTTON. WHEN IT STARTS BLINKING PRESS IT AGAIN.USE THE OTHER BUTTONS TO CHANGE TIME.
Feb 03, 2009 | Casio DW290 1V Classic Alarm Chronograph...
Missing screw and band for Casio Alarm Chronograph mod 388
I am not sure that i have a solution but i am 100% intrested int hat watch mine has the same problem and it was my grandfathers, i sure would like to get a hold of you!!!! mandy laesser at g mail, thanks!
Nov 19, 2008 | Casio DW290 1V Classic Alarm Chronograph...
10 year old alarm chronograph
good morning ! your anadigi chronograph 388 is veery easy to operate,just change the battery then short the reset button the fix the case back and set the time use the crown and the button to set the time calendar and the alarm !thank you ! god bless !....
Sep 01, 2008 | Casio DW290 1V Classic Alarm Chronograph...
Casio Exilim EX-Z750 Digital Camera Logo
169 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
