Question about Homedics Rc Quad Quad Extreme Rechargeable Hand Held Massager with Charging Base and Adaptor, Black and Chrome
Homedics RC-QUAD...can you change the rechargable battery in this unit? If so, how?
How does the 7.2 volt rechargeable battery work in the Big Haulers RC sets?
Open the door on the back of the boiler(inside the cab), the battery pack should slide in, then close & latch the door.
Jun 08, 2014 | Bachmann Big Hauler Radio Controlled Train
Leds stay on and do not blink,
Hi. I have the same issue.
RC has brand new batteries, switches on and see to work properly.
Quad is charged. But LED will not blink.
RC and Quad do not see to connect.
RC lights keeps blinking.
What happened ? As far as I know nothing unsual. I bumbed the quad slightly on the roof of the living room where I was fligh it. Nothing unsual. I landed it a bit roughly. Then it stopped responding. I assumed charge was empty but when I charged , nothing happened.
Dec 25, 2013 | Protocol Manta 4-Channel Radio-Controlled...
Copter is charged. it wont respond to the rc though
Turn on the remote control first then the heli the instructions are wrong
(I have the heli)
Where doI find the slot to recharge my helicopter
with most rc helicopters you have to disconnect the receiver unit from its battery and connect the charging lead to the battery lead the charger should have 2 leads 1 for the transmitter & 1 for the receiver
hope this helps
Aug 08, 2011 | xheli Exceed RC 24Ghz WarHawk 300 4Channel...
Hand held rechargable masager recharges but doesn't not vibrate when the button is pressed, the red light does not turn on either. The red light only goes on when it's recharging
Possible that the supply to the motor is cut or the motor is faulty or the switch has failed.
you have to remove and check the three possible faults, perhaps inthe process of vibration this can make wires break off contacts.
Sep 21, 2010 | Homedics Rc Quad Quad Extreme Rechargeable...
Remote doesnot work
If you have not already, register your product with the company. And contact them regarding the malfunction. they should replace the part or the product if you send it in.
Jun 09, 2009 | Homedics Qrm 400h Therapist Select Quad...
Cannot unscrew screw!
try super gluing (or with some commercial purchased weld products (like a glue or epoxy) a bolt to it and extract the screw with a wrench on the head of the bolt. Might try vice grips on the head too.
Dec 28, 2008 | Homedics Quad Roller Massaging Cushion...
Homedics Rc Quad Quad Extreme Rechargeable Hand Held Massager with Charging Base and Adaptor, Black and Chrome Logo
69 people viewed this question
Top Homedics Health & Beauty Experts
Jim London
Jim London
Ankit Chandel
Ankit Chandel
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
