Question about Mitsubishi WT-46809 46" Rear Projection Television
I have a model # WT-46809 and in comes on and within 5 seconds shuts off error code repeats 2 pause 2 pause2 over and over what do u think it is
  • Mitsubishi Master
  • 3,459 Answers
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
To get fixed either call in a local TV repair company or goto sites such as www.TvRepairKits.com to get a repair kit with instructions.
Posted on Oct 15, 2010
When I turn the tv on,,it just turn off,,
do the self check this model has. When green power light goes out on the front of the set press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and then let go of both.
Power light (green) should blink a two digit code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Sep 14, 2011 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubisi wt-46809 will not turn on. i plug it in and it blinks 3 times then nothing. no error code when i hold menu and input
keep in mind if you unplug set it clears the error buffer.
Try to turn set on and if power light comes on and goes off then do the self check; menu and input for at least 5 seconds and release both buttons.
UNPLUG TV ANDTHEN PLUG BACK IN---TURNON---GREEN POWER LIGHT COMES ON FOR A MOMENT ANDGOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
Before you rate this information let me know what you find.
SD TECH
Jul 20, 2011 | Mitsubishi WT-46809 46" Rear Projection...
Turned off and power light blinks
Please let me know if the blinks separated with a pause, if so first blinks is denoting the first digit then pause blinks again denoting the second digit. Example, if the error code is "22" the unit will blinks two times pause blinks 2 times and will repeat the error code. It will help to determine where the fault came from.
Jdvillanueva
Jun 24, 2011 | Mitsubishi WT-46809 46" Rear Projection...
Was working fine now will not turn on
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
SD TECH
Jun 14, 2011 | Mitsubishi WT-46809 46" Rear Projection...
My TV does not turn on the green light steadily blinks. Can you please let me know what I can do without calling service
When the power light comes on and then goes out, on the front of the set press both the MENU and INPUT buttons at the same time and hold them both in for at least 5 seconds and then release both buttons.
The power light will blink a 2 digit error code and repeat it at least 5 times.
The most common error will be 2 blinks, 2 blinks- a pause and then it will repeat it for a total of at least 5 times.
To get it to repeat this--you have to unplug the set, try to turn it on again and repeat the process.
The error codes are to try to narrow down where the problem is.
Dec 28, 2010 | Mitsubishi WT-46809 46" Rear Projection...
The TV was working great yesterday, but today, when you press the power button, th TV clicks on, then within 5 seconds clicks off, picture never appears but green light comes on until TV clicks off. ...
If this told you something you did not know rate this solution as very helpful as I do this here for free.
Post comment here if I can assist you further.
SD TECH
Sep 28, 2010 | Mitsubishi WT-46809 46" Rear Projection...
When the tv plugged up the power led blinks 3 times. When the power button is pressed the tv comes on for three seconds and turns back off. What could be the problem? Could this be a convergence problem?
Do the self check when power light goes out:
ON front of set (not remote) press and hold both the Menu and Input (Device) buttons at same time for 5 seconds or longer and release both buttons.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know code.
SD TECH
Sep 24, 2010 | Mitsubishi WT-46809 46" Rear Projection...
Tv WONT STAY ON
When the power light comes on and then goes off perform the self check feature the model you indicated has:
On the front of the press and hold both the MENU and INPUT (DEVICE) BUTTONS both for at least 5 seconds and release both buttons.
The green power light should blink a two digit error code--most common is 2 blinks, a pause and 2 blinks.
If this information has helped you rate this solution as I do this here for free.
SD TECH
Dec 23, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Tv turns on then right off
NEXT TIME IT SHUTS DOWN: when green light goes out on THE FRONT OF THE SET: press and hold BOTH the menu and input buttons at the same time for at least 5 seconds and then release both.
This is the self check this model has---power light should blink a two digit code---for example--two blinks, a pause and two blinks and the set will repeat the error code about 10 times.
1 blinks and then 2 blinks is NO ERROR DETECTED
2 blinks and then 2 blinks is short protect
ETC.....Let me know if you get an error code and I will tell you what the problem is---hope you find 2,2 that is the most common and the most easy to repair.
SD TECH
Oct 22, 2009 | Mitsubishi WT-46809 46" Rear Projection...
When I turn on my tv it will shut off
Model number is WT-46809?
If set comes on for a moment and then goes off(green power light)
ON THE FRONT OF THE SET PRESS BOTH menu AND input at the same time and hold both buttons in for at least 5 seconds---then release both buttons.
Watch the power light---it should blink a two digit code---ERROR CODE---
The most common is 2 blinks, a pause and 2 blinks-----set will repeat the error code about 10 times.
If you find this error code let me know the blinks and I will tell you what it means and may be able to tell you what is needed to correct it.
SD TECH
Oct 20, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46809 46" Rear Projection Television Logo
94 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
