Question about RCA L32W11 32 in. HD-Ready LCD Television
My RCA tv is only 1 year old and the screen only is light black after turning it on. It has volume but no picture and it will play DVD but still not picture.
  • 597 Answers
The problem is either the lamp is faulty or you have a bad t-com board.
Have the lamp checked and if it not faulty, then replace the t-com board of the television.
Take care
Posted on Oct 15, 2010
RCA 60921 rear projection tv. Everything worked perfectly until today. It sometimes made a hissing noise on and off but nothing very loud. Today I turned on the TV and the audio works but there is no...
Bad FBT Flyback Transfomer.You need to also check the Hori output Transistor,chances are if FBT is bad then Hori output will be shorted.
Mats Electronics should have FBT 1-800-628-1118
ACME 1-800-575-9833
Jun 28, 2011 | RCA P60921 60" Rear Projection Television
"32" rca tv about 3 years old was on & it went black- power light is on"
sounds like the sceen is dead, if you are receiving nothing on screen, then it sounds like either a component and/or screen is gone... however, check the tv input to make sure it wasnt acidentally switched to an input channel with nothing selected... if that does not work, call local tv repair or mfg customer service tech. if under warranty, have repaired or replaced. without physically seeing tv, it is hard to diagnose issue outside of information given. could be simple board replacement or could be screen.. but check input first, if a dvd player plays, then it could be just component or input on wrong selection
Oct 17, 2010 | RCA 32V550T 32" TV
Rca hdtv 52inch will play fine then picture goes black but still has sound.. after a few mins.picture will come back on , and will play fine could last all day or may go out again in a few mins.
My tv is relatively new, but the bad thing is that I had an old; big screen tube type rca model; home theatre, that was heavier than a car, and it went out, due to the cracking and popping sound, off sometimes, and back on.
What is strange is the new tv now, the hdtv, light weight, about five years old, is doing the same thing. Actually, now, the power will not even come on. The lcd green light in the front goes on and off.
Take no offense, but I thought I would not have these problems anymore. What do you suggest?
Feb 16, 2010 | RCA HD52W59 HDTV Projection Television
Lost entire picture, sound and everything else OK
check the invertor boards resistors they power the back lights
also check for any capactors that have blown (raised tops) they look little bateries
Dec 12, 2009 | Element Electronics FLX3220F 32 in. LCD TV
Prima HDTV has a black screen on TV, but works fine while Playing DVD
try turning the channel up or down with the tv remote to input 1 or 2 depending on which one is being used for the dvd player. tv should use input 1. dvd should be on input 2.
when turning the channel set it to show the dvd screen, then go up 1. if it doesn't show, return and go down 1.
Oct 22, 2008 | Prima C2012 TV
RCA f20580wn 20" TV about 20 years old
Hopefully you have the problem solved.
If not, the RCA plugs, listed as input 1 and 2 are shown on channel 91 and 92.
I recommend connecting the DVD to either input. Turn on the DVD. Then run the auto programming function of the TV. It will find and program the channel for the DVD. Then use the channel up or down on the remote you are currently using and you should find a working DVD.
Hope this helps.
Rcs97
Apr 07, 2008 | Televison & Video
Won't play ANY movies
separate the plug on the other appliance,check if the trouble is dvd or tv by connect other input device like game console or dvd.
Feb 11, 2008 | RCA DRC8052N DVD Recorder
Snowy screen playing dvd's
1.Check audio/video RCA jack cables
2.check S-video(if you use S-video cables)
3.check with another dvd player to get normal picture on your tv system. if picture is normal in this process. then problem with your old dvd player.
4.if same problem occurs in other dvd player. then problem with your television. external audio/video processing circuits
5.if the tv is ok. then the problem with your old Dvd player audio.video converting circuits
6. if can be rectified by authorised service engineers
7.Contact service engineer. as there is no recitification process from user part
Dec 15, 2007 | Hitachi 43FDX01B TV
RCA L32W11 32 in. HD-Ready LCD Television Logo
67 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
