Question about Samsung HL-T6187S Television
My tv is saying check fan no.1 and hen goes off
  • 3 Answers
On the Samsung HLT6187S models (there's no difference between S, SX, SAX, etc) Fan #1 and Fan #3 are in different locations but the same part. Fan one is the fan that you see when you take the back off the set. It's right there on the left sitting at a diagonal. It draws air from the lens to keep it cool.
Fan #2 is the large fan that pushes air to the right of the TV (as you're looking at it from the back).
Fan #3 is the LED PCB fan, all the way around the right side of the TV back.
All three fans are simple to replace and takes about 3 minutes to do. Conventional wisdom stipulates replacing all three while youve got it open.
Posted on Apr 25, 2012
2 Suggested Answers
  • 94 Answers
SOURCE: a message on the tv says check fan # 2
defective fan causing shutdown. Fans run around $70. A tech will know what to do.
Posted on May 28, 2010
First who came hen or egg
I would say hen came never seen an egg come
Sep 28, 2014 | Framed Art by Tilliams Hen and Eggs, 16 x...
A message flashes at the bottom of the screen
tv is overheating.  possible that fan not working or temperature protection circuit faulty.  check fan for excessive dirt first.  could be as simple as cleaning the fan
Jul 29, 2010 | Mitsubishi WD-57731 57" Projection HDTV
I have a Samsung HL-T5087SA DLP TV and it keeps saying "Check Fan #1" and after a few minutes the TV goes off. Do you know how to fix it?
Well I suppose the first thing to do is see that FAN#1 is actually doing the job! If not then replace it.
If it;s turning off then there is a rise in temperature that is causing t6he sail safe sensor to sw2itch off to protect against further damage or even fire
Please rate my help++++Thanks for using FIXYA
Jun 26, 2010 | Televison & Video
A message on the tv says check fan # 2, then the tv goes off after about 1 minute to 5 minutes.
May 27, 2010 | Samsung HL-S6187W 61 in. HDTV
I have a samsung LN52A550 LCD tv set and it won't show anything with a HD signal. If I hook up a 480I signal the tv will work,but if I hook up the tv antenna or any other hd source to it,the tv goes crazy...
Get a roof or digital antena.Will give u better signal.HD 1080i CBS,NBS check that if u have that in 1080i well able to get HD on the set.U might have a 720p tv set.
Dec 15, 2009 | Samsung LN52A550 LCD TV
Cooling fans in op until engine is shut down . At idle, in traffic, temp gets high, hen wmoving, temp goes back to normal. When I shut down the engine the fans start to run as they are supposed to when the...
Check out clarks-garage.com he has a complete troubleshooting guide for your cooling system along with a schematic. In short, check the low speed resistor on the firewall. Should be around one ohm.
Oct 10, 2009 | 1985 Porsche 944
Check fan # 1
There is a slight possibility that fan #1 is still good. I would still investigate it though. If the heat is not controlled, more damage could be done. I'm not sure which fan is #1. I think on the PCB of the TV would have some kinda of marking that would say FAN 1, FAN 2, etc.
Jan 28, 2009 | Samsung HCM4215W 42" Rear Projection...
STATUS LIGHT YELLOW, LAMP LIGHT GREEN: TV TURNS OFF.
have you checked the air filter located on the side of the unit? Also can you hear the fan start as soon as you plug the set in?
Apr 09, 2008 | Mitsubishi WD-52631 52" Projection HDTV
Rca television model 24v412t- or 25v511t
Thank you for your quick response.A new TV is to be shipped to me,via Jayco RV.Iam thankful for that,the wait will be a while.Better something than nothing.
Thanks Sincerely Maynard J Henning
Feb 24, 2008 | Audio Players & Recorders
55 in Sony KDF55WF655 Goes to standby and red light blinks 4 times
Check the thermal sensor fuse part# 1-910-023-93 or possibly one of the four fans. If the unit goes into Fan/Thermal Protect shutdown (4 blinks) it can be difficult to determine the cause since the unit turns off too quickly to troubleshoot. Solution: Ground the data line by inserting a jumper between pins 3 and 6 of CN44 on the H4 board. This overrides the protection circuits for troubleshooting. Do this right after turning the unit on and as soon as the lamp is seen lighting. Check pins 2, 5, 8, and 11 of CN6000 on the G2 board for less than 1VDC. Any voltage higher than that indicates a faulty fan. If all voltages are within specs, the H4 board must be replaced. If a fan is found defective, the optical block will need to be replaced if it is located inside the assembly. H4 Board Part Number: A1054674A Replace the following part based on which pin of CN6000 is out of specs: Pin 2: Fan 1 (part of optical block) Pin 5: Fan 2 178723211 Pin 8: Fan 3 178706511 Pin 11: Fan 4 178708111 Optical block Part Number: A1084662A
Aug 26, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Samsung HL-T6187S Television Logo
412 people viewed this question
Jerry Greenberg
Jerry Greenberg
