Question about Kenmore 84072 Electric Dryer
The tube spins, but there is no heat. - Kenmore 84072 Electric Dryer
  • Kenmore Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Oct 15, 2010
Fridgidaire fleb8200dso dryer still spinning no heat
if this is an electric dryer you need to replace the heating element-also while you have the machine apart vaccume out all the lint you can get to -cheers Denny
Oct 28, 2013 | Washing Machines
Kenmore dryer
You need to do a few basic checks to see if it is the element or maybe a safety. I recently did a video of a Roper electric dryer that would run but not heat:
Aug 10, 2012 | Dryers
Does not heat up but will spin
Take a look at this video to walk you thru the troubleshooting process.
Jan 01, 2012 | Frigidaire GLGQ2152ES Gas Dryer
HE5 dryer has no heat - everything else appears to work, tube spins , controls can be set, start. But no heat. Purchased new in early 2008, may be used 2 times / week.
Several reasons this could be. There is a separate fuse for the heating element inside the unit...find it and check it. Second...The element works on a 220v system whereas the spinning and lights work on regular 110. Check the 30 amp breaker in the house. Third, the element is bad and needs to be replaced. There are only 3 or 4 major parts to a dryer. There are easy to repair if you take the time to get the repair manual and study it.
Jan 22, 2011 | Kenmore HE5 Electric Dryer
Gas dryer is spinning but won't get hot what can I do before calling for repair?
Disconnect the vent tubing and check for any clogged up areas. That will prevent the heat to work vis the moister control sensor. Clogged vents are the number one reason why dryers do not heat up while spinning
Apr 29, 2010 | Dryers
Kenmore Elite dryer won't heat
if no heat at all unplug the dryer take off the vent take out the screws holding the back on there is a long oval shaped tube with two wires going into it there is a holding bracket holding it in place take out the screw unhook the wires take out a screw holds the heating coil in take out that screw inspect the heating coil for breaks it sounds like it is burned out if so replace if not it is probably the oval shaped thermostat on the tube i do hope that this was helpful then reverse the procedure, thank you.
Dec 30, 2009 | Dryers
No heat, the drum spins
Sounds like your problem is with the heating coil.
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with a continuity meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
Good Luck,
Hope this helps
Oct 07, 2009 | Maytag Dryers
Maytag dryer stopped heating /drying
ON THE SIDE OF THE BURNER TUBE THERE IS A RESET THERMOSTAT- IN THE CENTRE U PUSH THE BUTTON.
Jul 08, 2009 | Dryers
Dryer turns on and spins, but no heat.
Take the back off the dryer. Will will see a metal tube running from the bottom of the dryer to the top. This will have a fuze at the top and a thermostat at the bottom, and the heating element is inside the tube. Check the ohms on the fuze and the heating element. Replace the one that has no continuity.
Jun 29, 2009 | Kenmore Dryers
WHIRLPOOL DRYER MODEL LEQ8858JQO
Thermostat, High limit and low limit thermostat or even a safety Temp limiter. All three are similar in cost and located on the back inside of the dryer and 1 by the airflow tube under the lint trap.
Apr 08, 2008 | Whirlpool LEQ8858J Dryer
Kenmore 84072 Electric Dryer Logo
48 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
