Question about Mitsubishi WS-55859 55" Rear Projection Television
The picture on my set looks like the blue bulb casts a shadow that extending down from the top of the screen in horizontal arc through the middle of the screen. I took the magnifying lens off and looked down the "tube" and can see the arc clearly on the picture that's down the "tube". I don't think that it's a tube problem.
  • Mitsubishi Master
  • 3,459 Answers
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
To get fixed either call in a local TV repair company or goto sites such as www.TvRepairKits.com to get a repair kit with instructions.
Posted on Oct 15, 2010
Nikon d-90, shadows in pictures
if you're using pop up flash, you'll get more shadows doing a portrait shot than a landscape shot just due to the position of the flash bulb and the angle the shadows are cast.
Jul 06, 2014 | Canon Rebel XT / EOS 350D Digital Camera
Black spot in the middle of the screen looks like it has a burned spot
Yes if it uses 3 picture tubes one is burnt dead center--cover the lens one at a time to see which is causing this--permanent damage caused by a arc.
If a newer set you have a display unit with a dead pixel.
Mar 31, 2012 | RCA Televison & Video
I have small blue dots and a yellow shadow in the middle of my screen
The model indicated uses what is called a Optical Light Engine, it is a very expensive part and likely is your problem---not much else will cause this trouble.
Let me know if you have questions.
Dec 02, 2011 | Sony Grand WEGA KF42WE610 42" Rear...
When i turn it on it has an horizontal blue line in middle of screen then comes on, when shut down it has the colors in the middle in tight formation then suts off. is it the picture tube
the set having blue scteen when the nosignal condition so blue horizontal line due to failure in vertical deflection section and system control detect the vertical delection failure . so system control farce to set to shut down pls repair the vertical section and system should be ok
Aug 26, 2010 | Samsung SlimFit TX-S3082WH 30" TV
Picture blury and stretched
You have bad convergence ICs, requires disassembly and soldering to replace, quan (2) stk392-120 can use 150s or stk394-160 also.
they are located on the SSM CBA facing back left side, many delicate cables , torx 10 screws also look for any discolored 6.8ohm resistors near the ICs, usually (2) burnt resistors. most shops charge around $300 for the job done in house. Also will need to check that the yoke aren't loose and tilted (philips had black tape on some). and you may need a fluid change by now on the Blue and green CRTs (a professional job for sure). good luck !
Eric
Jul 31, 2009 | Philips 60PP9202 60" Rear Projection...
Red, Green, Blue curve upwards and cast shadows
that sounds like a typical Convergence IC problem..
http://i.ehow.com/images/GlobalPhoto/Articles/4575598/ConvergenceICs_Full.jpg
this is a picture of what typical convergence ics look like
Mar 12, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Blue "shadows" on my picture?
if you take the front bottom panel off, you will see 6 little nobs, look like this ::: the midle 2 should be blue, middle top is the focus, middle botton is intencity, turn the middle bottom nob down about a quarter to half turn, should solve prob
Jan 08, 2009 | Samsung HCM4215W 42" Rear Projection...
Picture has a blue shadow
Seems convergence out IC is fried in TV so it gives blue shadow.
Check out Convergence Out IC which you need to replace in TV, if you have enough experience of repair of big TV, necessary tools and know basic electronics.
Dec 18, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Hitachi53SDX89B color problem
Blue convergence IC bad...have both IC's changed..insist on
STK394-160E upgrade part # CZ 01341 Hitachi brand.....Original part is STK392-110......Also, check B+ feed resistors next to
convergence amp IC's for burn / damage...after rebuild, press magic focus.......................T.
Dec 21, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Blue tint and lines on screen.
Those lines sound like "retrace lines" and several things can cause them. The most common are shorts inside the picture tube and shorted semiconductors in the video driver circuits. They can also be seen if the blue screen voltage is too high or if someone has tampered with the screen voltage control.
Jan 20, 2007 | Philips 28PW9536 28" TV
Mitsubishi WS-55859 55" Rear Projection Television Logo
47 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
