Question about Kenmore Dryers
There is no heat when drying clothes. Dryer tumbles, but no heat. Open bottom panel, no glow from ignitor. Replaced ignitor. Still no glow.
  • Kenmore Master
  • 43,501 Answers
It could be a high limit, thermostat, or thermal fuse...
if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Oct 15, 2010
My electric clothes dryer will tumble but won't heat up to dry clothes
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Feb 17, 2011 | Roper Dryers
Put the cloths in the dryer like usuall and waited for peep to let me know its dry. but when i heard the peep assumed the cloths will be dry, the cloths were just like i got out of the washer, wet. it is...
heatman101
Feb 02, 2011 | LG DLGX8388 Gas Dryer
Dryer runs....no heat
Make sure the lint filter and the exhaust vent pipe are not clogged.
If electric then the thermostat or the heating element has failed.
If gas: First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Dec 21, 2009 | Refrigerators
Dryer not drying clothes
If the load is extremely large or heavy it may require more time. If you have an auto sensor cycle try that. If you are using the auto cycle and the clothes are not drying then the sensor may be not operating correctly. Make sure the lint filter is clean and that the exhaust vent duct is not clogged. Check all the way to the outlet. If all is clear then the thermostat2.gif may need to be replaced if it is not calling for heat as often as it should. Also check to make sure there is air flow from the vent. If not then the fan/blower may be broken or disconnected from the motor shaft.
If there is no heat then the thermostat or heating element (for an electric dryer) is not working.
If a gas dryer with no heat: Check the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
If everything above is OK then the thermostat2.gif or the auto sensor is not working correctly.
Oct 21, 2009 | Whirlpool Dryers
Dryer turns on, tumbles the drum but does not ignite the gas unit to heat and dry clothes
Sep 21, 2009 | Dryers
Not drying clothes not producing heat
Aug 26, 2009 | Dryers
Gas dryer tumbles but is not heating up
Aug 25, 2009 | Dryers
My dryr tumbles but does not dry
Gas dryer? First thing to check is the ignitor underneath the drum. (You have to open the panel to see it)  It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off.  If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced.  If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
Electric dryer? Temperature sensor has failed or heating element has burned out.
May 30, 2009 | Whirlpool Dryers
DRYER WILL NOT GET CLOTHS DRY
A dryer needs only three things to dry clothes:
1. Tumble the clothes.
2. Blow the air.
3. Heat the air.
If your clothes aren't drying, you are missing one or more of these.
You've mentioned that the basket is tumbling. That's good. The blower is also running if the motor is turning. But that doesn't mean the air is blowing. It could be clogged up behind the lint screen, in the vent pipe behind the machine, or at the vent outside the house.
If it's blowing lots of cold air (go to the outside vent to find out) then your dryer isn't heating. This would mean some part inside the dryer has failed. If so, the first thing you want to determine is, does the ignitor glow? There's a hole at the very bottom front edge where you might see it glow. You may have to place a mirror in front of the hole to see it glow.
Write back with more symptoms, and I'll help you through the rest.
Mar 23, 2008 | Dryers
No heat
mcwilliams if you pull the over off the front of the dryer at the bottom you can see the gas burner assy. Put the dryer on time dry and start the dryer, you should see a glow from the ignitor, then hear a click, then the heat come on. In the auto dry mode, the timer advances along with the dryness level. No heat, No timer advancing. If you don't see a glow, there should be a thermosat on the heater can, see if it is tripped. If so if it is resetable, reset then try again. You may have a bad ignitor.
Feb 03, 2008 | Estate TGDX640JQ Gas Dryer
Dryers Logo
79 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
