I want to make and older pc pickup a wireless signal what do i need
    President:
  • 1,187 Answers
Darren,
There are several ways to achieve what you want!
One method does not require wireless equipment on your old PC. The Older PC must have a wired network interface and be connected to the netwotk that has the wireless device to which you want to connect. If that is the case, please comment back.
Otherwise, the older PC probably has a PCI bus on the motherboard, or the PC may have USB ports. I suggest that obtaining a USB Wireless interface may be the least difficult. A USB WiFi interface looks just like a flash drive and costs about the same as an 8GB flash drive.
An example of one would be an IoGear GWU523 USB WiFi adapter for less than $20 at Office Depot.
There are other brands, such as LinkSYS, NetGear, etc. It's best to obtain the same brand as the wireless device you may be trying to connect to.
Thanks for using FixYa!!
-Gort.
Posted on Oct 15, 2010
Need a solution to provide wireless access for an older HP Pavilion 760N
Dieter:
You can buy a wireless receiver at most computer stores. The receiver plugs into a USB port and receives the signal from your router. If you are hoping to connect to WiFi hotspots, be careful and make sure that you have good security software!
Aug 07, 2015 | HP Pavilion Computers & Internet
Sometimes pickup doesn't work depends on what amp I use. Thanks, Ed
These pickups have a very high impedance so you must run into a high impedance input. Many amps expect low impedance guitar outputs and these piezo pickups just can't drive them.
We currently use an X2 wireless system which has over a 1.5 megohm input impedance which works well with these piezo pickups. Long guitar cables degrade the signal as well and running into a DI just won't work.
Mar 12, 2011 | L R Baggs Violin Pickup W/ Carpenter Jack...
My 1991 toyota pickup signals arent working but the hazards work. The signals will work but then they will die. What is the problem?
Your problem lies within your steering column. The blinker switch inside the colums is probably worn out. You have an older vehicle. How many times a day while driving do you think that you use your blinker switch just to go to the store and back? Quite a few huh. Its not hard to replace. Refer to your owners manual for instructions.
Nov 22, 2010 | 1991 Toyota Pickup
I am trying to help my mom who is an older person, she doesn't live nearby. Her wireless keyboard got locked up, and the wireless mouse is not working. She tried to follow instructions located underneath...
replace all batteries and with the computer turned on unplug and replug the usb to the pickup hub press the button on the pickup hub then the keyboard link button then the mouse. that should do it then re boot the computer to save the usb directory.
good luck
please take the time to rate this repair guide. thanks
Aug 03, 2010 | HP Computers & Internet
Trying to hook up older dell computer to wireless network (2wire) laptop has wireless card inserted, will not pick up signal from desk top connection.....this laptop did pickup signal from other network in...
Does the older Dell have a wireless radio?
If not, you'll have to use an ethernet cable to the 2wire router or buy a wireless USB card for about $35 or less for the old Dell. I'm assuming you are running XP SP2 or higher system.
Aug 03, 2010 | Dell Computers & Internet
Need a pc card for wireless internet connect.Have tried netgear does not work in computer. any suggestion. model of computer 570e imb thinkpad. old computer work great but need internet connection. thanks
You can order pretty much any PCMCIA Wireless network adapter. If the machine is older, you may want to try the "802.11g" or "802.11n" wireless notebook network card.
Try Belkin F5D7010, it uses the "g" signal band.
Apr 28, 2010 | IBM ThinkPad 570E Notebook
Aspire 4315-2963 can i install wireless network adopter? do i need usb adopter or big card adopter? i have N router but still it do not pickup signal in upstairs rooms.
You don't need anything like USB adapters or an external adpater, wireless Network Adapter comes inbuilt in your notebook.
Just download the the wireless driver,
If you are using Windows Vista, for Atheros chipset Click here
If you are using Windows Vista, for broadcom chipset click here
If you are using Windows XP, for Atheros chipset
Click here
If you are using Windows XP, for Broadcomm chipset
Click here
Your Wireless network will work.
Note : Install the driver according to your chipset and the Operating System.
That's it..
Feb 09, 2010 | Acer Aspire 4315-2963 Notebook
My PC cannot see the wireless signal.
The reason why your PC can't see the wireless signal is because it is too far from the router. Or your wireless card is too weak to detect the signal from the router, its either the antenna it bad or loose, you may need to double check that. You may consider changing the channel on the wireless router to channel 11. Try to power cycle the router as well.
Jun 20, 2009 | SMC Barricade g SMC2804WBR Wireless Router
Inspiron 6000 has trouble picking up wireless signal
Some wireless cards are better than others at picking up weaker signals.
The problem with any wireless transmissions is that radio signals cannot pass through metallic surfaces.
You should position your wireless router away from metallic surfaces/walls and position your laptop so it can receive the radio signals without it passing through any metallic walls. If possible place the wireless router higher than at desk level.
Dec 26, 2008 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
