Question about Sanyo DP32746 32 in. LCD Television
Light hit close to the house tv went off know the green light just bliks
    Genius:
  • 1,622 Answers
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Good luck in solving the problem.....
Posted on Oct 15, 2010
Two of my smoke alarms went off (no fire/smoke in or near house), one has a green light blinking and one has a solid green light, which need a new battery/reset?
The constant green LED means the alarm has AC power.
A flashing green light every 2 seconds without an audible alert means the unit recently sounded ( was the one activated ) and is now in latching mode to let you know that it was the unit that detected the problem. To clear the latching mode hold down the test button for 5 seconds.
Red LED flashing once per minute means that the back-up battery is connected and functioning.
Red light flashing constantly during alarm means that it is the unit that initiated the alarm siren.
Sep 04, 2014 | Cars & Trucks
I have the sony bravia KDF E50 A12U The tv went pop and wont work. On switching on the tv, the light stays green, then goes over to 3 red light flash then green. What is this and is it easily fixed?
  • This model had a problem with the lamp door warping from the heat.
Remove the door and hold it edgewise to see if warped..
There is a peg on the back of the door that engages a lever when the door is closed---if door warped set will not come on.
A simple way to confirm or deny this is to use something not metal to with the door removed ENGAGE and hold the lever forward.
DO NOT IF THE THIS SET COMES ON LOOK AT THE LIGHT OR OPERATE IT FOR PROLONGED PERIODS OF TIME.
Do not put the outer shield cover back on without the door as heat can get it also.
If set comes on with door lever engaged you need to replace the door--widely available on the internet and or from Sony---not a bad idea to buy a spare one.
let me know what happens.
Mar 15, 2012 | Sony KDF-E50A12U 50" LCD HDTV
My mitsubishi tv W55613 won't turn on. green light keeps blinking even after resetting
Hit the front of the tv near the blinking light... give it a good rap or two. See if this helps. Helped mine. I had the same problem and the tech who came out to the house told me that it would work and it did! I could hardly believe it but it worked.
Feb 13, 2012 | Mitsubishi WS-55613 55" Rear Projection...
Status light is blinking red, power button orange nec vt700
Hello
Look at the number of blinks of the status light.
[1] If it blinks at one cycle (0.5seconds On and 2.5seconds OFF) : Lamp cover error or lamp housing error. Replace the lamp cover or lamp housing correctly.
[2] If it blinks 2 cycles (0.5 seconds ON and 0.5 seconds OFF): Temperature error. The projector is overheated. Move the projector to a cooler position.
[3] if it blinks at 4 cycles (0.5 seconds ON and 0.5 seconds OFF): Fan error. Fans sill not work correctly.
[4] If it bliks at 6 cycles (0.5 seconds ON and 0.5 seconds OFF): Lamp fails to light. Wait a full minute and then turn on again.
[5] If it blinks continous (Red): Lamp has reached the end of its life. Lamp replacement messege will be displayed. Replace Lamp with same type and number. After replacement reset lamp hour. OK.
Sep 10, 2011 | NEC VT700 Projector
I have a green screen and shuts down after only about a minute
This model had a lot of problems with bad picture tubes--it has a red, green and blue picture tube--only now available on a rebuild basis.
There is something you can try if you are only a little bit handy--a do it yourself thing that involves no replacement of parts---
If set comes on and screen goes bright green and shuts off--it is shutdown circuit-detects too much current is being drawn and protects set.
I am able to post instructions here for you to try something simple that may let the set work again for a period of time.
Let me know if you want the instructions and I will post them here for you.
If this information has helped you rate this solution as I do this here for free.
SD TECH
Dec 23, 2009 | Sony KP-51WS500 51" Rear Projection...
Green timer light wont go away
Hi.
The TV is in protect mode because there is an internal fault.
The TV must be tested and repaired at component level.
Call Mitsubishi at the number listed on the user manual.
You can also read my comment explaining more on protect mode here:Why my TV does not start up and remains in...
Dec 13, 2009 | Mitsubishi WD-52525 52" Rear Projection...
WD-62525, continous amber lamp light. No picture. Lamp is good.
Hello:
Make sure u replace the lamp cover as the safety switch need to be closed to make the set work. If new lamp did not repair your problem , then it may well be the Ballast Board, Sometimes call the Lamp Driver.
Nov 28, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Sony KDF-E50A10 Green picture.
For BnrMan213,
I believe your issue with Light engine.(KDf-E50A10) If you have warranty on this unit contact seller.
Good luck
Dals123.
Same unit different problem
Customer replaced Lamp ***'y still unit bliks, there is two reason.
1.if your lamp door not closed properli it will blink.
2.watch for ballast ***"y fires the triger to on the Lamp? if not your old lamp is good repalce Ballast..
Good Luck
Dals123
Jul 31, 2008 | Samsung HCN4226W 42" Rear Projection...
Ge universal remote
HERE IS THE PDF LINK FOR THE ORIGINAL FOUR DIGIT CODES INCLUDED IN THE PACKAGE AT THE TIME OF PURCHASE.
http://www.jascoproducts.com/support/download-files/RemoteCode-4-digit.pdf
Feb 25, 2008 | GE RM24912 Universal Remote Control
Sharp ac adapter uadp-a048wjpz not working
The general problem with LCD type TV's is that the power supply fails. They are very sophisticated designs that are difficult to troubleshoot and generally best to just replace the module, but sometimes there is visible damage in some of the electrolytic capacitors (visibly bulged) and higher voltage rated parts can be substituted.
Hope Ya Fix It
Feb 19, 2008 | Sharp Aquos LC-22SV6U 22 in. LCD EDTV
Sanyo DP32746 32 in. LCD Television Logo
295 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
