Question about Bosch HBC 86Q650B Electric Single Oven
Hello we have bosch hbc 86 and every time i want to turn on the microwave it suddenly stops, even when im trying to defrost,it starts and then in 3 seconds it turns off, please do you have a solution for this problem?
My HBC 86 showed this behavior, after a fuse for the microwave operations was blown (remove the top cover and you will see it on a board close to the door). It's an 8A, medium speed. There might be different reasons, why the fuse is blown. In my case, the switches that detect whether the oven door is closed or open caused the problem. There are two connected with the microwave, one on the left (a bipolar switch) and another on the right. The switches will cause a short-circuit (and thus a blown fuse), if the left one detects an open door and the right one a closed door - it's an additional security feature. The problem can be caused by a blocked or slowly reacting switch. You might want to clean/replace the switches and/or put the right switch as far as possible away from the door so that it detects a close later (and open earlier). A good thing for testing: the problem occurs without actually starting the microwave.
Posted on Oct 27, 2011
Hi my Bosch Quantam speed microwave keeps tripping the electric when the oven is used. The grill and microwave settings both work fine. Any clues. ??
Yes, sounds like your oven element may be faulty and needs testing/replacing etc. However microwaves are best left to the qualified engineers. When you remove the cover, certain parts inside the microwave may still have live current present even with the plug disconnected and could cause serious injury or even electrocution!!
Oct 25, 2014 | Ovens
Oven and grill stop working no indication lights even turn on
Hello,if the whole oven longer then first see if there is power if it is to supply the fuse, which can be measured volt meter but maybe there will be one more heat than it is to heat that I helped, maybe would help if I could type.
May 02, 2013 | Bosch HBL 435 Stainless Steel Electric...
After a powercut my microwave has managed to lock itself! How can I unlock it? Really urgent as i have a small family, my husband is in Afghanistan and I need it all the time for sterilization etc. ...
Hi Sally,
I have a sequence for my Sharp Carousel that will lock or unlock. Press "Auto Start" > "1" > "Stop"
If you have a different microwave, leave the unit manufacturer and make and I will do my best to find the answer for you
Joe
Sep 21, 2011 | Ovens
How do I remove the child lock message on my Panasonic Inverter Microwave?
Press {Stop/reset} button 3 times to unlock the unit. Or un-plug it for a little while. To put the unit into child lock press the start button 3 times.
Aug 20, 2011 | Ovens
Oven cuts out as soon as it reaches temperature
not expert on bosch but sounds like cooling fan not working, either fan defective or cut in themostat not working.
Jul 22, 2010 | Bosch Ovens
Where can i get my bosch microwave oven repaired now mfi have gone bust
Our Bosche microwave has failed to work, it was bought 5 12 06 and failed, it was repaired on 20 12 06 , bottom hinge faulty,eng no 70792. It has the same symptoms, some days it would work after several attempts, butnow it will not work at all. Can you give me any hints as to how I might get it to work? Is it out of guaranttee? How much would it cost to repair it, the last time was 36 mins? It seems to me to be a faulty model to start with and at the price we paid, three times what an average one cost a poor deal.
Nov 11, 2009 | Bosch Ovens
Turntable not rotating
Ours has a turntable On/Off button. Check yours.
After that, you will need to take it out and either see if it has frozen up due to dried liquids, or if it's just gone bad.
If just bad, replace. If full of dried liquids, then clean up with WD40 until you can get it to turn.
Feb 01, 2009 | Bosch HBC 86Q650B Electric Single Oven
KitchenAid Superba Microwave/Oven, Microway Door message
"I get a "Door" message when I try to start it. The Message only shows when I try to set the time with one of the function buttons, like and dosent work
Dec 20, 2008 | Ovens
OTR Microwave Magnetron Fan and Interior Light Run with Door Open
Could be a defective door interlock or control board.
Mar 06, 2017 | Ovens
Bosch HBC 86Q650B Electric Single Oven Logo
225 people viewed this question
Top Bosch Ovens Experts
ashburton
paulcarew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
