Question about Sony VAIO VGC-LS21N PC Desktop
I checked the ram modules and the thing is when i press to start the computer the led on the screen doesn't turn green , i get either one long beep or 3 beeps, and the screen remains black and it doesn't even start.
  • 707 Answers
One long beep + 3 short beeps denotes a video problem for Sony Vaio. Unfortunately it doesn't get more specific. If you have a video card, try re-seating the card. Try using a different monitor. Try upgrading the drivers (probably here: http://www.driverboost.com/lp/drivers/update/ati-video-drivers.php ) of course you will have to go to a different PC to download them onto a CD/dvd and try to run them. You might consider trying to boot into safe mode and doing a system restore. It could be many things. Without more information I can't really be of much more help. Hope one of these works for you.
Good luck
Posted on Oct 15, 2010
How to fix a laptop that doesn't turn on but beeps 1 long beep and 3short beeps
This POST cade is related to RAM problem
one beep, three short beeps
three short beeps, one beep
  • Memory problem: bad DIMM or bad DIMM slot
Try reseating the RAM, if this does not work then remove the RAM module and take it to your friendly computer repair shop and get them to test the RAM for you.
May 12, 2012 | HP Pavilion ze2000 Notebook
One short beep one long beep continuous and power green led flashes continuos
I would say you have a failed memory (RAM) module. Probably a module in one of the secondary slots since the computer is able to POST and will attempt to boot.
Mar 20, 2012 | HEWLETT-PACKARD Computers & Internet
My HP G60-230US Computer will not start. The computer is a little more than 2 years old. Every so often when I would start the computer it would say "No boot device found". I would restart the...
sounds like your motherboard malfunctioned. the board was probably starting to go out. thats why it would see the hdd then not.
you sound like youre familiar with computers. you may want to invest in diagnostic cards to troubleshoot problems like this. theyre fairly inexpensive on ebay. basically you insert the card into pci slot and it displays an error code. then you look up the code in a book. works like the obd2 reader for your car.
good luck
Feb 28, 2017 | HP G60-230US Notebook
When i turn the computer on it beeps 4 times and repeats this, nothing comes up on the screen.
one of the periferals is defective (RAM, PCI card, video, CD or Hard Drive, etc...) remove everything that you can leaving just the board, CPU, one stick of RAM and power supply, than boot if all goes well, shutt down than re-plugg one thing at a time, than re-boot, start with the RAM modules (one stick of RAM at a time as well) to see which device is causing the failliure... if it is not booting on the first try, switch RAM modules by starting with only one RAM stick at a time...
Cheers!
Sep 18, 2011 | Dell Inspiron 537 ST PC Desktop
When starting up the computer, I get 5 short beeps then continous
These beeps seem to show that your system did not detect any RAM (memory) modules connected to it. Please check.
  1. Open the CPU case (turn the PC off first)
  2. Remove the RAMs from the slot.
  3. Turn ON your computer without the RAMs installed. Then observe if it gives the same beeps. If it is the same, then the RAMs might fail to register.
  4. Try to plug in carefully the RAMs in place. If you have 2 RAM modules, try to test 1 RAM at a time to see if the combination of the 2 mess up your system.
Feb 13, 2010 | Computers & Internet
My computer doesn't load on the screen as I turn it in
A solid amber power LED on a Dell System is indicative of a no post. There are 4 diagnostics LEDs on most Dell Towers (Either on the back marked ABCD, or on the front marked 1234) they can give more details of what the POST problem is.
Troubleshooting: Disconnect all external connections to tower except power, turn it on, see if the LED indications changed. If they change, then connect disconnected items one at a time till the failed item is found. If no change, the open tower, remove all PCI expansion cards, see if system will boot. If still no change, then most likely a motherboard failure. Take RAM out, see if you get a Beep error code when powered on, if no beeps, replace motherboard. If it does beep, try RAM modules one at a time, if it boots with 1 but not the other, replace the effected module. If no boot, with either replace MB
Oct 08, 2009 | Dell E173FPb 17" TFT LCD Monitor
My Dell 100L will not switch on and battery will not charge.
since the LED is orange it might be a ram issue. try to locate the memory modules in your computer then try to reseat them. or if you have 2 ram modules try to remove 1 first then try to turn on the laptop check if it will do the same thing. then try removing 2 ram modules check if it will beep. if no beeps ask for mobo replacement. if it has beeps take note of the beep codes.
Oct 03, 2009 | Dell Latitude 100L Notebook
Intel D815EEA: Won't Boot / Blank Screen / Three Beeps
3 short beeps means Base 64K RAM failure.
try to replace the RAM.
Jun 24, 2009 | Intel Desktop Board D815EEA2 (BOX815EEAA2)...
Screen won't appear upon start up and I get 3 beeps but no screen
3 beeps POST code (power on self test) means RAM problem.
Reseat the RAM module/s and boot up your computer.
If you have two RAM modules, remove them both and insert one at a time to test them, to determine which module is faulty.
If it still doesn't work then replace the RAM module/s
Apr 02, 2009 | Everex StepNote NC1500 Notebook
Intel D945GCNL Board No display
Dear user, this problem can be coused by many things.
1, The memory you have installed is not compatible with your system.
2, Power supply failure.
3, Contact issue between the socket and the module.
Try thease:
Take a brush and clean the sockets.
Power on your computer without the memory modules, if you hear beep it could be a health signal :D.
Power off the system.
Clean your memory module pins with alachol or other cleaner liquid.
Wail till it dry, inster it back to the socket and move a little ud and down to catch ancontact.
Power on and now shold be work fine.
If this ain't works. Try other brand of memory, kingmax or kingston. They usually shipps with 99 of good modules from 100.
Good luck.
Mar 22, 2009 | Intel D945GCL Motherboard
Sony VAIO  VGC-LS21N PC Desktop Logo
127 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
