Question about Brother ML-100 Typewriter
How do install the new ink cartrige
I had to replace it for the 1st time and do not know how to riinstall it.
  • 462 Answers
Most go in with the part towart the keyboard first then just snap down.
Posted on Jun 04, 2008
HOW DO I FIX THE INK CARTRIGES WHEN REPLACED ?
Could be improper installation, or cheap cartriges, or could be failed print head which I had and replaced with good results.
May 21, 2014 | HP Photosmart C6380 All-In-One InkJet...
Black Cartrige Missing
Did you use a brandname ink cartridge - or is it a knock-off brand? If it is a brand name - then the cartridge is most likely defective. If it is a knock-off brand - some printers do not recognize the electronic in the cartridge and therefore don't see it as one being installed.
This may also help
Dell 922 AIO Black Ink Cartridge Missing Message
May 02, 2017 | Dell AllinOne Multifunctional (v515w)...
Epson C63 will not print despite having changed all the inks. It tries but the paper is blank
I think there are 2 causes epson c 63 printer not print problem.
First one is: Your ink cartrige are not install properly.
Solution: Try to install ink cartrige properly, in this time please clean ink cartrige chip as well as connector.
Secoundly: printer main board problem. Print data does not pass through main board.
Solution: Please replace new one.
I think you will relive from the problem.
Thank yoou.
Feb 28, 2011 | Epson Stylus C63 InkJet Printer
Since installing new ink cartrige every time I turn on the printer it prints an alignment page
Hi:
This problem is usually caused by one of the colors in the installed cartrige not printing out on the alignment page. You need to have red, blue and yellow working to get a good alignment. Try removing the cartridge, and wiping the print head with a wet paper towel to try to start the ink flowing. You should see three bands of color ink oozing out the bottom. If not, the cartridge is bad and needs replaced again!
Apr 19, 2010 | HP Photosmart C3150 Printer
Ink cartrige cannot be recognised
make sure you've taken the protective tape off the cartrige. Usually its orange and noticeable.
Sometimes generic cartriges have a small chip and a registration that allows the printer to talk between the cartrige from what I under stand maybe ink levels and to protect profits on not allowing generic companies to make a more economical product competitively
the printer can sometimes be power cycled to allow it to accept the generic cartrige.
there are normally settings on a printer to see if you can change the internal settings can be altered to allow non Original Electronic Manufacturors products in a Canon Printer.
make sure that the type of printer you have is compatible with the printer. the computer may require a black cartridge or a color cartrige in a very specific location. they might not be allowed to be switched.
make sure the cartrige can slide in and out of it's slot comfortably.
FOR office printers. there are also protective tabs holding the ink in the cartrige. this side tab on the cartrige is there for shipping. these are normally on large 30 pound printers. top front loading Office printers. the tab needs to be turned hard and swift either clockwise or counter clockwise if you can't cleaning pull it out. Also remember your boss paid a lot for that cartrige dont break something your not comfortable breaking. be warned in advance this dry ink will spill and is hard to clean and harder to clean from clothing.
as per a fast solution a smaller printer and certainly a cartrige can actually be brought into a computer and electronics store whilst looking to buy a new print cartrige. Make sure if you do bring a piece of your own electronics into a store you check in with security. let them know its yours; wave it in front of a camera if youd like.
the seller normally should be able to recognize if their product will fit in your device it will save both of you time and inconvience.
cartriges cost about the same as a new printer with new ink.
dont be afriad to buy an extra ink at the time of purchase and risk letting it dry but having the back up that you know works-
you'll have a package for the next time you need a new cartidge. gives you more research material.
accept moores law
feel good about flossing on a new printer.
print some pictures and frame them-
pictures are some of the most important thing in our lives! Smile!
Mar 10, 2010 | Canon Office Equipment & Supplies
Will not print in black.
1st clean heads, on printers menu, then check if you have instaled non canon ink cartridges, you maybe burn out ink printheads. ONLY USE ORIGINAL INK CARTRIGES ALWAYS.this a normal failure on NON CANON INK SPARES.
Nov 22, 2009 | Canon Office Equipment & Supplies
Its saying im out of ink and i just installed new cartridges all 4 and printer is fairly new
when replacing the cartrige and install it in your printer have you select the option their saying new cartrige installed?
Oct 08, 2009 | Epson STYLUS CX5900 Printer
Replaced Ink on Samsung SF-330 and still says install ink
There is something wrong with the cartrige head. First try to take out the cartrige and in the head there is contact points. You can try and clean it with a dry cloth.
Aug 18, 2009 | Samsung SF-330 Plain Paper Inkjet Fax
Says new bnlack ink cartriges are empty when they are new
1st check the little gold plates on back of the cartridge.
clean them off and were they make contact to the printer.
If that don't work.
Download SSC Service Utility. (Voids warrenty use at own risk free program)
http://www.ssclg.com/epsone.shtml
If that don't fix it there is still one more thing you can do.
Get a chip restetter for your cartridges.
http://dsacme.blogspot.com/2008/10/service-tool-for-reset-canon-i320.html
(this one is not free)
This will reset the chip on your cartridge and make the printer think its a new one.
I use both programs works great.
Jan 09, 2009 | Epson Stylus Photo R220 InkJet Printer
Keeps saying to replace cartidge
you have to go int the ink leval thing i think and tell it you installed a new ink cartrige that should fix it
Dec 10, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother ML-100 Typewriter Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
