Question about Yamaha RX-V661 Receiver
Remote I need the codes to control rx-v661 with my comcast tv box remote
  • jonathanrell Feb 28, 2009
    i have the same problem and can't find any code that works.
  • 1,512 Answers
Hi jimvandy
Most yamaha codes will work some of your unit functions. try 0176 or 1176. These are for a dvr3 comcast remote. You can get the whole list and manual from here
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you still have problems, before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on Jun 03, 2008
I want my Comcast remote & Yamaha RX-661 to communicate??
30176 or 31176
I am guessing at what remote you are using, so the code may not work. If that is the case, go to the following link and pick your remote from the picture list.
http://www.comcast.com/corporate/customers/customer_support/remotes.html
Jul 13, 2010 | Yamaha Audio Players & Recorders
Can't get my hannspree remote to work with comcast
10030 for the comcast dvr remote. Code is from NEC
Oct 02, 2009 | Hannspree HT09 28 in. LCD TV
Need a code for my Comcast Universal Remote
30176 is the code you need . Press Aux and then hold setup until Aux lights up. Enter code. If you want the remote to control the receiver all the time, press Aux and then hold setup until Aux lights up. Enter 993 then press Aux. Aux will flash, now press Cbl and Aux should light up when you use the volume.
Jun 16, 2009 | Yamaha RX-V463 Receiver
Zone 2 volume control
Sounds like the Zone 2 amp was set to external, see below for instructions on setting it back up.
How do I setup Zone 2 on the RX-V661 Using the internal power amp.
Setting the RX-V661 remote control to operate Zone 2
1. Using a ballpoint pen or similar object and press the Code set
button. The Transmit indicator on the remote should flash twice.
2. Using the numerical key pad on the remote and key in 9992, the
Transmit indicator should flash.
You will now need to assign the receivers internal amp for Zone 2.
1. Set the remote control selector to AMP. Selector is on side of remote.
2. Press the Set Menu Button.
3. Arrow down to Manual Setup.
4. Press the Enter button.
5. Arrow to the Sound Menu option and press Enter.
6. In the Sound Menu arrow to Speaker Set and press Enter.
7. Arrow to the EXTRA SP ASSIGN and select ZONE2. This may require using LEFT or RIGHT arrow.
8. Press the Return button to exit out and return to the Manual
Setup.
Apr 05, 2009 | Yamaha RX-V661 Receiver
Remote to control comcast, DVD and TV
The answer here is very simple, there are plenty universal remotes that can control any device and upto 10 devices. You can even record macro's with these, this means by simply pressing 1 button all your devices will switch on, select correct channels and volume and start playign or recording.
Just check Logitech website for Harmony or Philips for Pronto.
Mar 23, 2009 | Yamaha RX-V663 Receiver
Need remote codes for emerson lc320em9 so can program cable remot
If you only wish to power the TV off/on with the remote, there is an alternative. Plug the TV into the outlet on the back of the Comcast box. In the Setup Menu for the Comcast box there is an option to make the outlet switched or unswitched. Select SWITCHED then the TV will turn on/off with the Comcast box. The
LC320em9 will maintain the previously selected input.
Jan 16, 2009 | Televison & Video
Sharp TV (LC52D64U) remote control Comcast cable (DVR) box ?
I had the same problem with my remote. I would enter the code and there would be no response from the remote. I looked up the manual for the other comcast remote and the codes are 5 digits instead of 4. Try codes 10093 or 11602. The reason why there is no response from your remote is because it is waiting for you to enter the last digit of the code. Hope this helps.
Dec 01, 2008 | Sharp Remote Control
Comcast remote
The volume keys should be working by default, but you may have volume punch through turned on (meaning the remote is sending signals for TV or CABLE volume function no matter what mode you are actually on). To unlock volume control for AUX mode, do the following:
1. Press and release AUX
2. Press and hold SETUP until the remote blinks twice
3. Type 993
4. Press and release VOL-
The remote should blink four times to confirm unlock.
Jul 05, 2008 | Yamaha RX-V1400 Receiver
Need codes for comcast remote to ilo tv
When programming your Comcast universal remote for your TV, the programming guide states that you should enter the 4-digit code provided for your equipment, and if you did it correctly, the TV button will blink twice.
What you have to do is put a "1" in front of your 4-digit code, making your code a 5-digit code. For instance, the code for my Panasonic is listed as 0250. I tried and tried. Then I entered 10250 and it worked perfectly the first time. I did it again to make sure I wasn't seeing things, and it worked.
Good luck.
Apr 10, 2008 | Audio Players & Recorders
Yamaha RX-V661 Receiver Logo
329 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
