Question about Bugaboo Frog Stroller
I put the car seat with adaptors and seems to be wobbly
How do you put quinny zap adapters into the frame?
if you are wanting to put the adaptors on the pram to use the mai cosi car seat then you put the adaptors in where the pram goes in the holes if the pramseat is in already you see the silver bits at either side of the pram hold them in and lift the seat then put your adaptors in and clip the car seat to the adaptors once on its stable hope this help s
Jul 28, 2012 | Quinny Buzz Three Wheel Stroller
Does the maxi cosi car seat wobble a little when fixed onto the quinny zapp frame
Slight movement is necessary as this allows for a hammock effect to prevent the baby in the carseat feeling every jolt on the way. With the weight of baby in the carseat on the chassis the movement will be less noticeable. As long as the adaptors are fitted correctly to the chassis and the carseat has been placed onto the adaptors correctly there should be no cause for concern. If you are worried that it seems to move a lot, compare your model to a shop display model and if it does seem excessive you can send your product in for our engineers to provide inspection & repair under the Quinny warranty.
Feb 09, 2012 | Quinny ZAPP Stroller
Bugaboo Bee's car seat adapters for Maxi Cosi allows the car seat to rock. Is this normal?
No adaptors have not fully engaged into frame the white button should go in then pop out with a distinct click when you fit them.
Dec 26, 2011 | Bugaboo Bee Baby Gear
I have a quinny buzz as well as a bebecomfort pepple car seat and i cannot combine them. i used the adaptors but they dont seem to fit on the baby car seat..
Good Morning
The adaptors that came with the Quinny Buzz should fit the Pebble carseat; If you're having any problems at all, we recommend you contact the retailer you made your purchase from and have a chat with them to confirm that the adaptors have been put on the right way round. Also its worth noting that the carseat will only fit onto the adaptors parent facing, some customers try to fit it on world facing but this won't work.
May 25, 2011 | Quinny Storm Buzz 3 Wheel Baby Light...
How can I attach the car seat to mama& papas Zola buggy using adaptors?
Hi - Maxi Cosi don't produce the adaptors that put the Maxi Cosi carseat onto a chassis produced by another manufacturer. It would be the manufacturer of the buggy that you need to contact to ask them about fitting directions as they produce the adaptors.
Feb 24, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
How to install Maxi Cosi Car Seat Adapter for Bugaboo strollers. I just bought the adapter but can't seem to know how to install it.
Hello - Maxi Cosi do not produce the adaptors to fit their brand carseats onto another brand stroller. For advice on how to fit your Maxi Cosi carseat to this stroller please contact the manufacturer of the stroller as they would be the company who produce the adaptors.
Feb 18, 2011 | Maxi-Cosi Mico Infant Car Seat
Can you buy an adaptor to put a mutsy safe2go car
No, there is no base for the Safe to Go. Your best bet may be to use a CabrioFix car seat instead.
Hope this helps.
Jul 26, 2010 | Baby Gear
Wobbly seat!?!?
Hi did it click into place when you put it on? Also take the seat out & just check the holes it fits into, if the 2 grooves match up then you need to put your finger inside it & move it forwards very slightly say 1" now try to attatch the seat.
Apr 15, 2009 | Quinny BUZZ 3 Jogger
Maclaren car seat adaptor
if someone has the adaptor bar for the global buggy and is not using it... I would love to buy it. I have lost mine.
Jan 08, 2009 | Maclaren Global Buggy Atlantic Umbrella...
Valco Tri Mode Stroller - car seat adaptor
the car seat goes in so that the baby is facing you if you are pushing. the bar on the adapter goes into the two plastic pieces sticking out of the back of the car seat. the red hook in the graco seat will latch on. it is confusing because the baby is seemingly far from the person pushing.
Mar 02, 2008 | Valco Runabout Tri Mode Jogger
Bugaboo Frog Stroller Logo
90 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
