Question about Pitco Frialator 35CS Deep Fryer
Buner does not shut completly off. flame lingers near orifice. how determine if its the gas valve or temp control?
    Sergeant:
    Novelist:
  • 193 Answers
The thermostat is a snap action. It is either completely on or completely off. The combination valve may be letting a little extra gas pass by the main valve. Unless it is a significient amount of flame or it continues for more than a minute or two, just keep an eye on it. It is not unusual to see a tiny flame at the orifice, but it usually dies out in less than a minute or so. You can get a rebuild kit for the gas valve. The complete valve is around $150.00. You will need to get the model number and the serial number of the fryer, to buy either the valve or the rebuild kit. If you are very confident in your abilities to do a gas valve rebuild it should take a couple of hours to remove the valve by removing the main gas line, then the manifold that runs to the burners. You will also have to remove the wires that run to the high limit switch and thermostats. Be sure to mark the wires as you remove them. The gaskets are very fragile. As you take the valve apart lay everything in order so that you may retrace your steps in putting it back together. There is an exploded view of the valve in the rebuild kit. You MUST check for gas leaks before lighting the fryer after you have rebuilt the valve. With the gas pressure on, but the pilot not lit, spray the entire valve with liquid leak detector, available at the same place you get the rebuild kit. You can also use dishwashing liquid, but either way look for bubbles at all the gasket locations as well as the gas pipes and manifold that you removed. If you see ANY bubbles, don't light the pilot. Start over with new gaskets. Hope this helps
Posted on Oct 17, 2010
Where is the flame sensor location on a Rheem RGDA-075C-ER Gas Furnace made in 1991
Flame sensors are always located directly in the flame, as it leaves the burner/in shot. The flame comes directly in contact with the flame rod/sensor. It's usually near the last orifice on the manifold, farthest away from the gas valve.
Mar 18, 2017 | Heating & Cooling
My gas stove seems to have what i would call a after burn
If it is just short final flare, it is probably just the gas still in the supply pipe to the burner. That last bit of gas will burn off rapidly right after the valve is turned off.
Jan 03, 2015 | Kenmore Kitchen Ranges
Pilot light lights but is a low flame
There is an adjustment screw on the main gas valve, usually under a cover screw. It will be near where the small pipe that goes to the pilot light.
Jul 03, 2014 | Frymaster Dean Kitchen Appliances - Others
Grill burner will not burn like the other
Dynasty burners are replaceable and they are very good appliances (when they're actual dynasty, manufactured by jade).
About 90% of the time someone complains about burner flames or heat it is the check valve needing to be reset. I explained this earlier but let me know if you need to know how to do this.
On the rare occasion the check valve is not the problem (and 90% could actually be very low because this is almost always the problem!) the burner could need to be cleaned or replaced or the gas orifice and valve could need to be cleaned or replaced.
Dynasty burners are very heavy cast iron, single venturi "H" burners. Although coated cast iron is quick to oxidize and sometimes because of the coating the rust will start from the inside out. Lift the burner from the back of the barbecue and slide it away from you. Check to see if it is corroding from within.
The single venturi tube extends from the bottom of the burner into the control panel where it slides over the gas orifice at the tip of the control valve. It is possible for the gas valve to get a small insect crawl in through the orifice and build a nest inside the small cavity inside the control valve.
Remove the burner to reach through the inner firewall with a ratchet to pull the orifice and then check the inside of the orifice and the inside of the valve behind the orifice. If something is clogging the orifice the gas will flow unevenly and you may have flame-flashing inside the control panel which will destroy the lubrication in the control valves and will destroy the ignition parts inside the control panel.
I suggest the check valve solution with the drip tray removed so you can look from under the control panel for gas leaking through the air holes in the venturi tubes. Also, remove the control panel and leak-test the valve with soapy water because if previous flashing occurred the first casualty is usually the seal between the valve and the gasket which can lead to more leaking gas.
Check valve:
Turn everything off (tank and bbq).
Disconnect hose and regulator from LP tank.
With tank disconnected, turn the BBQ on. Turn every valve to "high" and leave it for 5 minutes.
Turn everything off -- completely off.
Reconnect tank but turn the tank on very, very slow. The check valve problem occurs when gas "hits" a swing arm too hard as the gas leaves the cylinder so turn the cylinder on very slow and then relight the grill.
Jan 25, 2014 | Dynasty DBQ-30 (LP) Grill
Having just converted my Vulcan Endurance G36L Range from Nat. Gas to LPG Using the following parts recommended by Vulcan : New 1/2 psi pressure regulator, 6 size 51 hood type top burner orifices,1 size...
The oven safety valve has to be cranked down for propane.themobilian_815.jpg
Get a good fitting wrench and tighten this spud down and open the air shutter on the burner.
This video shows how to tackle a crank down and flip type LP conversion whilst yours might be a bit more fancy it still must be adjusted like any other stove:
Jan 10, 2011 | Vulcan G36L Gas Range
Furnace cuts off before reaching set temp.
You can make sure it is not the thermostat by crossing or jumping the R and W terminals (or associated wires) together. This will keep the furnace calling for heat. As it is approaching set temperature, get in front of the furnace and inspect the air filter to make sure it is clean, watch the control module for any error codes that may be turning off the system prematurely.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Mar 07, 2010 | Honeywell Programmable Thermostat Heater
Carrier furnace ,burner not staying on after 4th try shuts down completely.cleaned the flame sensor but noticed the 3rd and 4th burner has a delay in lighting by the time the 4th burner lights and hits the...
Remove them and scrub them with a wire brush.
Jan 10, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
No flame on left side/main valve. Right side lights, flames up
Try taking out the orifice on the burner that is not lighting and make sure it isn't blocked.
Mar 12, 2009 | Heating & Cooling
Furnace pilot problem
check the pilot gas pressure, might be too weak and blowing out when the blower starts, the clicking noise is the gas valve shutting down when it detecks no pilot flame, that park is normal.
Jan 10, 2009 | Honeywell Power Humidifier: Furnace...
Pitco Frialator 35CS Deep Fryer Logo
109 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Treefrog15
Treefrog15
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
