Question about Sony CDP-XA7ES CD Player
Can't open it it is jamed - Sony CDP-XA7ES CD Player
    Genius:
  • 1,325 Answers
Have you tried pinhole to open the unit (use paperclip or large sewing pin
Posted on Oct 15, 2010
One person in my address book contacts several times with several old numbers and his name several times how do i delete all but one
My daughter is Lisa Taylor!
I can tell you for iPhone and it will be similar on others.
Open Contacts - Click on the Outdated name - Click Edit - Scroll right down to the bottom which is out of view - Delete Contact.
Jan 21, 2016 | Cell Phones
Why is my machine jamed
Sounds like a thread jam ! Open bobbin case housing remove bobbin and clean away thread ! Do not force the balance wheel to turn or you will knock out the timing !
Aug 25, 2014 | Tacsew 20U43 Sewing Machine
Compact disc drawer on unit does not open
Drawer was jamed,It will have to be taken in to a repair shop, To be realigned, Unless the gears are jaming up, Then you might as well just look for a different one, You could take the cover off to see what it is doing,
Nov 04, 2012 | Denon Audio Players & Recorders
It says clear paper jam
what brand of fax machine do you use?
try to open the fax machine ande see if there is any paper jamed or piece of paper jamed at the sensor.
Nov 11, 2010 | Office Equipment & Supplies
My 308 winchester 99e lever action jamed, had to
found someone on internet that sent me the plan for free. by searching you can save money.
Oct 24, 2009 | Sport & Outdoor - Others
I have paper jamed and I can't get it out. Can't
goto the www.hp.com there you find your products usermanual & software etc try it
Oct 10, 2009 | HP PSC 1610 All-In-One InkJet Printer
Driver Door Jamed and automatic lock is working.
actuator rod clip either disconnected or broke-use key to unlock door and open if key dont unlock then rod to door catch disconnected or broken and will have to take off door panel off to manually open and repair
Oct 05, 2009 | 1998 Acura CL
PAPER JEM WHILE PRINTING. I NEED A HEIP TO REPAIR THE PRINTER.
first, if thare any paper is jamed in the paper tray, pull the paper stright out. take out the remaining paper. close the paper tray.
opne the front cover pull out the toner cartirdge, remove the jamed paper.
open the inner door (where the paper exit). make sure there is not paper jamed it.
close the front door. if any paper jamed inside of the machine, it should automatically eject it out.
Note: reset the printer by opening and closing the front door.
Apr 03, 2009 | Samsung ML-2510 Laser Printer
Ink System Failure
I just had this problem with a HP C5150 and I found this bit of conversation on the web and it worked for me.
My error code was 0xc18a0501 and the following steps did resolve my issue, hope it helps you as well.
  • OK I had the hp error code 0xc18a0001 problem and here is the conversation I had with the tech.....
    james cowan: hp error code 0xc18a0001
    Earnest: I will assist you in this regard
    james cowan: great
    Earnest: I understand that a error code with 0xc18a0001 with "Ink System failure" is displayed on the front panel of the All-In-One printer. Am I correct?
    james cowan: correct
    Earnest: Thank you for confirmation
    Earnest: May I have the model number of All-In-One you are using?
    james cowan: c6250
    Earnest: Thank you for information.
    Earnest: James, please let me know the room temperature in which printer is replaced
    james cowan: 67 degrees f
    Earnest: Okay
    Earnest: Please perform the below steps on the front panel of the printer to resolve the issue
    james cowan: ok
    Earnest: Press and hold the "left arrow" key.
    Press the "Setup" key and release both keys, Display should say "Enter Special Key Combo"
    Press and release the "OK" button.
    Earnest: Please ignore the above steps, James
    james cowan: ok yes nothing seemed to do anything
    Earnest: Press and Hold the "Print Photos" &"Red Eye Removal" buttons. Release both buttons. Display should say"Enter Special Key Combo"
    Press and release in sequence"Red Eye Removal","Print Photos","Red Eye Removal"
    Earnest: Display should say “Support” and display the FW rev (something like R0616R)
    james cowan: COxxFN0723BR j
    Earnest: Okay
    Earnest: 2. Press and release the right arrow button until the display says “System Configuration Menu
    james cowan: ok
    Earnest: 3. Press and release the "OK" button.
    james cowan: ok and it says hardware failure status
    Earnest: Display should say "Hardware failure status: Clear. Press OK to clear".
    Earnest: Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
    Earnest: Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
    james cowan: ok
    Earnest: Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
    Earnest: Let me know once you are done with the above steps
    james cowan: ok its unplugged
    Earnest: Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
    Earnest: Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE".
    james cowan: ok
    Earnest: Let me know the message displaying on the front panel of the printer
    james cowan: printer preparation occuring - do not interrupt
    Earnest: Okay
    james cowan: ok its done
    Earnest: Let us print a self test page from the printer now
    james cowan: ok deal
    Earnest: 1) Load letter, A4, or legal unused plain, white paper into the input tray.
    2) Make sure that the printer is on and loaded with unused plain, white paper.
    3) Press Setup . The Setup menu appears.
    4) Press the down arrow button to select Tools , and then press OK .
    5) Press the down arrow button to select Self-test Report , and press OK .
    james cowan: ok printing
    Earnest: Okay, please check whether all the colors pritned perfectly on the test page
    james cowan: perfect
    Earnest: Great..Cheers!!!
    james cowan: thank you very much
    Earnest: James, now you can continue using the printer
    Earnest: I appreciate your efforts and patience in trying to resolve the issue."
May 26, 2008 | HP Photosmart 3210 Printer
Sony CDP-XA7ES CD Player Logo
44 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
