Question about Kenmore Dryers
Dryer h4 does nor response to any input from pannel, light works when open door?
I fix my by taking the three screws out of the back of the unit and blowing a hair dryer on the front control panel. There must have been a build up of moisture in there because that fix it. I hope this works for you.
Posted on Oct 05, 2012
  • Kenmore Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Oct 15, 2010
GE heavy duty dryer - I pulled the knob off and turning the shaft with pliars, but now the shaft is broken too. How can I fix it???
These are very easy to work on. I threw one out a few years ago, everything worked on it apart from the motor! Look for a home appliance spares retailers close to you or order online. from someone like here
http://www.reliableparts.ca/catalog/475015
Specifically, this is the part but you have to input the right model number.
http://www.appliancepartshelp.com/GE-Dryer-Knob-Timer_c_2658.html
Feb 19, 2015 | Dryers
Whirlpool duet dryer doesn't work after power surge
Hello, well that sounds a fuse problem, you can try check inside, be shore you unplug the power socket before you do it, if the inside fuse is ok ,so the control board is damage and needs to be replaced, and don't think it worth .
Thanks
Nov 22, 2013 | Whirlpool Duet WED9150WW 6.7 Cu. Ft....
Whirlpool model LER8648LW0 - the dryer will not stop when door is opened and the interior light does not light. I have changed the bulb on the light but it still does not work. I suspect the problems are...
I suspect the problem with your dryer is the door switch as opposed to the timer...its the responsibility of the door switch to stop the dryer when the door is opened as well as turning on the light too when the door is opened.
The part number for the door switch is 3406107 it could be purchased at your local appliance parts store or online at;
apdepot.com
repairclinic.com
searspartsdirect.com
apwagner.com
partselect.com
This youtube video will show ya how to replace the door switch http://www.youtube.com/watch?v=gWQhuQXa6d0
GENE
Sep 12, 2011 | Whirlpool LER8648L Electric Dryer
I have a loud squeal in my GE dblreeee2w dryer. Can you tell me how to take the back pannel off to gain acess?
front panel .. the back panel dosent come off open door two phillips screw in top of door shroud opening the top lifts up screws in corners remove front door assy....
Jan 31, 2011 | Dryers
How do i open up the front of the dryer to repair igniter
On this model, the burner assembly is located in the back left corner. You can access it by removing the back pannel. To remove the front pannel you can lift the front of the top pannel and remove the two screws that hold the front to the sides. Keep in mind the top is held by plastic locks and clips, so be gentle but forceful. Also, the from holds the spring assembly for the door.
Feb 24, 2010 | Whirlpool LGR8648L Gas Dryer
How do I gain access to the motor on my Neptune dryer
Open the dryer door.
Remove four screws - two are holding the door and two are holding plastic pieces opposite the door.
With the screws released, the front pannel of the unit will tilt forward and can be removed.
With the front pannel out of the way, two metal retainers found at the top front of the dryer can be released which allows for the top of the unit to be lifted up and removed if desired.
From this point, four more screws found on the front face were removed which allowed the front ducting and front part of the drum to be removed.
The drum was pulled out (work the belt to the rear of the drum while extracting it - optionally, you can release the belt tension by reaching in and removing the belt from the idler)
The motor is accessable.
Professionals may want to pull all the screws from the side pannel and remove it for easier access.
Jan 12, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My dryer runs about 10 seconds and then stops
"DO" indicates Door Open
Door monitor switch in door lock mechanism is not able to communicate to the control board is open.Try taking the following action
1.Make door is closed.
2.Check for loose wire connections at switch and/ or machine control board.
3.Check for failed door monitor switch.
4.Check inputs and outputs at machine control board.
5.Replace responsible component.
Good luck.Please do rate my answer if liked.also please post comments for further queries.
Jan 18, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
No response when start button is pushed
check you door switch make sure it there and not broke off,,,onthejob
Dec 23, 2008 | Whirlpool GGQ8831L Gas Dryer
How do I fit a new drive belt for my Kenwood KVT1W Tumble Dryer
I am not familiar with this machine but most dryers have to have the front removed so that you can slip the belt over the drum. I would imagine they have the screws hidden pretty well. Perhaps their is a removable front panel. Some have a few screws on top then you raise the controlpanel exposing the front screws. Just a guess.
Dec 22, 2008 | LG DLE2514 Electric Dryer
Dryer will NOT start
1st reconnect the door switch for that is a safety element. 2nd check the terminals in the back of the machine and unplug it before you open the back pannel . Make sure they are clean and not corroded, then reattach and make sure they are secure. if this dose not solve the problem, you may have a bad or dead spot in the motor. Happy holidays biigg53566
Dec 01, 2008 | Whirlpool Dryers
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
