Question about Dacor ECD230 Epicure Electric Double Oven
What is a L22 overheat? - Dacor ECD230 Epicure Electric Double Oven
Electric fan oven
Sounds like the oven thermostat stuck, for whatever reason and then the oven overheat thermostat kicked in. At the very least, I think you will need a new oven thermostat and possibly an overheat one as well. On the 720 there are two, one for each oven, so when you take the oven to bits, check both out.
Dec 17, 2011 | Stoves Ovens
During cooking the oven goes off. There is often a lot of water/steam present. Sometimes after a while it comes back on?
It could be that the overheat thermostat is kicking in, albeit earlier than it should do. Have you checked to see that the oven thermostat is working correctly and is not heating the oven up too much ( does the neon go off and on) and is the oven cooling fan running ok in the background. If these two appear to be ok, then you may need to replace the overheat thermostat.
(The oven cooling fan should remain on for about 5 to 10 mins after either oven or grill has been used. If this isn't happening or it is not running correctly then that is why the overheat device is shutting the oven off). As a thought, are the top oven and grill working ok? if they are, then it narrows it down to either the oven thermostat or the overheat sensor.
Nov 19, 2010 | Stoves 720EF Electric Double Oven
When turning the oven on it will not start up
Assuming the clock/timer has not been accidentally set, and this is what is turning it off, does everything go off on the oven including the lights and the display on the oven control?
If it does, then it could be the oven overheat thermostat kicking in.
Also is the cooling fan running normally in the background because if it isn't, this will cause the oven to overheat.
Nov 13, 2009 | Stoves 720EF Electric Double Oven
Hello, My Jenn Air oven overheats. When I set
The temp probe resistance should read between 1050 and 1150 ohms. If not. Replace it.It causes the overheating situation you describe.
Jul 16, 2009 | Jenn-Air Ovens
GE JKP15 Oven Overheats Randomly
50 degrees is not reprogrammable so you must replace the control. sounds like the relay may be sticking on the control board.
Jun 12, 2009 | GE JKP15 Electric Single Oven
Electrolux EOG7330 gas cooker - electric timer fails?
Pull off bottom knob of oven shine torch down at 45degrees u will see a red plate turn off power suply and use a small screwdriver to push the plate turn power back on job done.PS Check all vents are clear to stop it over heating good luck.
Jul 18, 2008 | Electrolux EOG7330WN Gas Double Oven
GE Spectra XL44 Oven Overheating
It is a thermistore problem, if you replace the faulty thermic switch inside oven, it should work fine a gain
May 25, 2008 | Ovens
EOB6630X ELECTROLUX ELECTRIC BUILT IN OVEN
which stat is it - overheat stat or temperature stat?
May 13, 2008 | Electrolux EOB6636X Ultrafan Electric...
Overheating?
yes - it is cutting out on overheat. there are two fans - which one was replaced - cavity fan or casing fan?
possible reasons are:
faulty casing fan
not enough ventilation
faulty overheat stat
faulty fan stat
oven operating stat faulty but you would be burning your cooking in this case
Dec 21, 2007 | Electrolux EOB5665G Ultrafan Electric...
My Hotpoint UY46 main oven overheats
cant't think it is anything other than the thermostat - a routine fault
Mar 11, 2007 | Hotpoint UY46 Style Line Stainless Steel...
Dacor ECD230 Epicure Electric Double Oven Logo
27 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
Vitaliy Gins
Vitaliy Gins
ashburton
Are you a Dacor Oven Expert? Answer questions, earn points and help others
