Question about Brother Office Equipment & Supplies
Brother lc61 printer will not print in black even wit a new cartridge installed
  • Brother Master
  • 783 Answers
Hi innercepter,
1) Open the printer
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water to thoroughly clean the print head and each ink cartridge.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
If that does not work then you have one of two possibilities:
(1) One of the ink cartridges is defective and causing the error
(2) If it's definitely not that, then the print head will need to be replaced.
Posted on Jan 30, 2014
2 Suggested Answers
TechAll
  • 99 Answers
SOURCE: I installed new b&w & color cartridges and the
in your printer try to press on the restart button and hold it for about 8 to 10 seconds. by the way the ink cartridges that you installed are the genuine ink cartridges, if not then its gonna be normal that it won't detect as new.
Posted on Jul 11, 2011
I have a all in one color LC61 printer, do all colors have to be filled to print blk only?
Greyscale is color not black only.
You can print in black and it will look grayscale only darker, printers are a pain to work with after a year has gone by, I can expect almost a half hour to print something with my $400 epson because one of the colors is out even though I never printed in the last year a colored page. I take the color cartirges out and they are empty, but I only print a page 2-3 times a year. I use the scanner all the time. Brother and epson have their print heads in the printer not the cartridge so make sure your inks are always have something in it or it will be miricle for the printer to last more than a year. Check colors every other week. One Epson printer only lasted 3 months because I never used it(print head dried up). Never use the set up with tubes running outside printer to small tanks of ink if you only use it occationally.
May 11, 2014 | Unknown 10pk 4B,2C,2M,2Y Compatible LC61...
Black ink 0n LC61 PRINTER HEAD
most likely the printhead needs replacing, it is possible that it might be covered under warranty, call brother and check.
also make sure you have black ink in the cartridge and if you did only 1 cleaning, you may need to do 3 or 4 to see if its better, ink has to flow through the tubes.
Apr 06, 2014 | Brother MFC 420CN All-In-One InkJet...
Color ink is out can I still Print with Brother LC61
Hello. Yes, if your color ink is out and your black ink is still working, you can still print but in black only. I recommend changing your color cartridge sometime in the near future, but it will not affect your ability to print.
Thanks for using FixYa!
Jul 12, 2011 | Brother MFC-5440CN All-In-One InkJet...
My Brother LC61, bought in Nov.2010, won't print black. Recently replaced black ink along with all color inks...replaced black ink again when it quit printing...still won't work. Machine whirs...
This is common problem with Brother Printers. I am going to assume you are using Non-Brother branded ink cartridges. Brother cartridges have a cleanser in the ink that most generic cartridges don't have. This in turn causes the jets to clog and not allow ink to pass through them. The fix is to go buy a couple of Brother cartridges and do a cleaning with those cartridges. You may spend some money doing this as a cleaning wastes a lot of ink, but it will clean the injection lines and fix the printer. You could also consider buying a new printer. I know this is not the answer you were looking for, but it is the true answer. I just bought a new printer due to this fact.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 11, 2011 | Brother Multi-Function Center MFC-240C...
I want to use Black ink only but it will not print because the colors are empty. Do I need to replace all cartridges (LC61) for Brothers print, copy, fax machine. Thanks
If you don't want to replace the color cartridges, you can fool the printer instead. Sensors in the printer shine light through a thin area on the cartridges. The empty (or even just low, even though there may be plenty of ink still inside) cartridges allow the light to get through, the printer sees the empty cartridges, and it won't print anymore. You can cover this part of the cartridge with a piece of black electrical tape to block the light. Voila! No light gets through and the printer thinks you have full cartridges again. This site has pictures showing where to put the tape. I've used this trick on the printer we have here in our office and it works great.
Feb 11, 2011 | Office Equipment & Supplies
Am I able to print on my LC61 with just black ink?
Most printers require the tiniest bit of color to print in black to keep the color jets from drying out.
If your color cartridges are fine, and you're only asking about settings, then, when you have a document positioned to print, left click one in the window you want to print, hold down the CTRL key and press P
You'enter the printer window
Select "Preferences"
Then "Black and White"
then "Print only from black cartridge"
Ciao,
TheSelkie
Oct 04, 2010 | Brother MFC-290C Printer
My Brother LC61 Series printer does not print - printer is less than 1-yr. I purchased new ink cartridge a couple days ago, however, all of a sudden, the printer will not print.
1st question that should be asked, is was it a genuine Brother approved cartridge with the right value of filtered ink?
If not then the jets will be possibly clogged.
if you return it for repair to brother under warranty, make sure its fitted with genuine cartridges otherwise warranty is void
please rate my help++++thanks for using fixya
Apr 16, 2010 | Brother MFC-290C Printer
Lc61 black ink not printing
please just your have refling black cartriaged ? If yes
then again refling cartries black and add printer.
and you go printer page and select to B&W and ok select and
aply print.
other no result in black print then you parchase a new black only
cartries and use.
Sep 27, 2009 | Battery Technology Office Equipment &...
214 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
